My club wants to equip all our planes with jacks so people can plug
their handhelds into an external antenna in case the panel radios fail. In the past, what we've done is had a length of coax run into the cockpit with a BNC connector crimped onto it. The problem there is it tends to get kicked around, the connector gets smashed, etc. When you need it, it's not usable. One alternative I've thought of is to have the antenna cable run to a BNC jack on the panel. The problem with that idea is then you need a length of cable to go from the jack to your radio, which will in turn get lost, smashed up, etc. Has anybody come up with a good solution to this problem? |
![]() Roy Smith wrote: Has anybody come up with a good solution to this problem? Jim Weir has. Check out http://www.rst-engr.com/kitplanes/KP0203/KP0203.htm George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
Oh GRIEF, George. Posting a website with free information that is linked to my
business? HORRORS. {;-) Jim (But thanks for saving me the time of having to look it up for the guy.) "G.R. Patterson III" shared these priceless pearls of wisdom: - - -Roy Smith wrote: - - Has anybody come up with a good solution to this problem? - -Jim Weir has. Check out http://www.rst-engr.com/kitplanes/KP0203/KP0203.htm Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
BTW, in the 182 the "emergency" cable to connect the handheld to the panel
connector is made from the little tiny RG-174 coax with BNC crimp on one end and the 3.5 mm connector on the other end, both with shrink sleeving to keep the ends from breaking at the connector. It is then coiled up, tied up with an "asparagus" tie and put in the glove box. Don't use a tie-wrap because the odds of your having a knife to undo it in an emergency is inversely proportional to the seriousness of the emergency. Unless you have Cessna-Crafted® radios, you won't be using this cable but four or five times in the airplane's life, so why are you worried about it breaking? OTOH, if you DO have Cessna-Crafted® radios, I'd make it out of steel jacketed material welded together with a torch. Jim -- -- Has anybody come up with a good solution to this problem? -- --Jim Weir has. Check out http://www.rst-engr.com/kitplanes/KP0203/KP0203.htm Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Roy Smith wrote:
My club wants to equip all our planes with jacks so people can plug their handhelds into an external antenna in case the panel radios fail. In the past, what we've done is had a length of coax run into the cockpit with a BNC connector crimped onto it. The problem there is it tends to get kicked around, the connector gets smashed, etc. When you need it, it's not usable. One alternative I've thought of is to have the antenna cable run to a BNC jack on the panel. The problem with that idea is then you need a length of cable to go from the jack to your radio, which will in turn get lost, smashed up, etc. Has anybody come up with a good solution to this problem? Have each member carry and be responsible for their own cable, and maybe they'll take better care of them 8-) FWIW, I have used a lot of "crimp on" BNC connectors on Ethernet cables, and if moved or handled a lot, the shield braid usually breaks right at the connector. Adding a piece of heat shrink tubing as a strain relief improves their longevity quite a bit. |
Roy Smith wrote in message ...
My club wants to equip all our planes with jacks so people can plug their handhelds into an external antenna in case the panel radios fail. In the past, what we've done is had a length of coax run into the cockpit with a BNC connector crimped onto it. The problem there is it tends to get kicked around, the connector gets smashed, etc. When you need it, it's not usable. One alternative I've thought of is to have the antenna cable run to a BNC jack on the panel. The problem with that idea is then you need a length of cable to go from the jack to your radio, which will in turn get lost, smashed up, etc. Couldn't the jack-to-radio cable be coiled up and kept in the glove compartment? Or, make each person w/ a handheld responsible for rolling (and toting) their own radio-to-bnc cable -- we have an extra length ourselves wrt the bnc connector in the panel, one Grumman I saw had a lower-tech solution. The cable between the radio and the antenna looped through two holes in the panel. at the 2nd hole, it was cut and a BNC connector put into place. So there was no switch involved. It was very neatly done and looked reasonable. I'll try to find a picture. Cheers, Sydney |
In article , Snowbird
wrote: On our Champ, we just coil up the coax and stuff it space between the wing root and the windscreen. |
Retractable Comm Antenna | Ron Wanttaja | Home Built | 11 | September 6th 04 06:59 PM |
ELT antenna -- Pitts | Al MacDonald | Home Built | 0 | July 15th 04 03:27 PM |
Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 01:10 PM |
External GPS Antenna | Jim Weir | Owning | 0 | November 29th 03 04:12 AM |
External GPS Antenna | Jim Weir | Aviation Marketplace | 0 | November 29th 03 04:10 AM |
