Battery Replacement and Cold Cranking Amps
Old January 27th 04, 06:19 AM
O. Sami Saydjari
Default Battery Replacement and Cold Cranking Amps
I have a Gill G25 battery in my Piper Arrow III (PA28R-201T). I
recently had a situation where I ran out of juice after 4 attempted
starts. While I am sure that I can improve my starting technique (I am
a newbie for this particular plane), I would like to have a bit more
power in my battery, especially in very cold conditions such as we have
up here in central Wisconsin.
An A&P told me recently that I am "stuck" with my G25 battery. He said
that he tested it and that it was "fine."
Based on a recent article in "Aviation Consumer", I learned that the G25
has only about 225 cold cranking amps. I noted that the G35S has 250
cold cranking amps.
(1) Is it true that I am stuck with a G25 battery and that NO OTHER
battery in the world can go in my plane? I find that a little hard to
believe.
(2) If there are other possibilities, can someone recommend one that has
better cold cranking amps that the G25?
Thanks in advance.
-Sami (N2057M, Piper Turbo Arrow III owner)
Old January 27th 04, 07:27 AM
starts.
Since you live in central Wisconsin, you know how cold can sap a battery's
charge, particularly if left idle for a few days. But when you say it "ran
out of juice after 4 attempted starts" I am wondering (a) what you mean by
no juice, and (b) what constitutes an "attempt." If you mean that the
battery is discharged to a point where the prop will no longer turn with the
starter, that could mean a lot of things, including a defective starter. If
you mean the battery is completely flat (for example, will not power the
radios), then It could be a problem with your charging system or the leads
to the battery.
Four prolonged start attempts with a very cold engine could easily drain a
very cold battery. How, if at all, do you preheat?
I have an Arrow IV, also with an IO-360. I have found that when the engine
is cold (and "cold" here in the Seattle area is pretty mild by your
standards) it likes a very healthy shot of priming. I leave the mixture
rich and the electric pump on until fuel pressure begins to register (it
takes maybe 7-8 seconds), then pull the mixture back and crank. Then it
usually starts without difficulty. I presume that you have studied the
start procedure shown in the manual. The most critical (and perhaps
counter-intuitive) thing to remember is that the mixture needs to be in full
LEAN (i.e. cutoff) position while cranking. You need to keep your right
hand on the mixture while you turn the key with your left hand so that you
can quickly move the mixture to full rich as soon as the engine begins to
fire.
believe.
The battery box in a normally aspirated Arrow is pretty tight -- not much
room for a larger battery. Weight and CG are also considerations.
-Elliott Drucker
Old January 28th 04, 04:49 PM
On 27-Jan-2004, "O. Sami Saydjari" wrote:
But when you say it "ran out of juice after 4 attempted starts" I am
by no juice,
I mean that the battery would no longer turn the engine over. The
instruments were still powered.
An attempt was about 30 seconds of turning the engine over in attempt to
get it to start.
Well, from what you say your (cold) battery is able to crank the engine for
a total of about 2 minutes before it gets run down. That doesn't sound too
bad to me. You should note, however, that cranking non-stop for 30 seconds
is way too long. You are probably over-heating your starter. Anyway, the
real problem isn't your battery but that your (preheated) engine failed to
start. Properly preheated, it SHOULD start with no difficulty. I would
strongly suspect the impulse gear in the left mag. Or you may be flooding
the engine because of improper start technique (a preheated engine needs
only a little bit of priming) or because of a mechanical problem with the
fuel injection system. After cranking unsuccessfully for a bit, try the
"flooded engine" start technique. (Electric fuel pump OFF, Throttle FULL
OPEN, mixture to IDLE CUT-OFF.)
If you mean that the battery is discharged to a point where the prop
the starter, that could mean a lot of things, including a defective
starter.
Hmmm, how does one determine if the starter is the problem?
That doesn't sound like your problem, but a starter would be suspect if it
failed to vigorously crank the engine with a freshly charged battery. Of
course, that problem could be caused by other problems such as loose
electrical connections or corroded battery terminals.
-Elliott Drucker
Old January 27th 04, 11:02 AM
Ron Natalie
"O. Sami Saydjari" wrote in message ...
starts.
The other thing you may wish to look at is the cable between the
battery and the engine. I believe that a lot of the Cherokee's benefit
from having this replaced.
Of course, your other option is to get an APU cable for your plane.
Used to help the Saratoga in the next tie down start his plane on
cold mornings.
Old January 27th 04, 10:53 PM
O. Sami Saydjari
That is done, but good thought!
cold mornings.
I was hoping to avoid parasitism
Old January 27th 04, 02:55 PM
Michelle P
Sami,
You can install a Concorde www.concordebattery.com CB-25, CB-25XC, RG-25
or RG-25XC.
1) Four attempted starts depends on how long you were trying. Most
starters have a 30 second continuous limit.
using that that is 2 full minutes of cranking. That would just about be
the limit for battery capacity.
2) Has your aircraft had the original battery cable (Aluminum in most
models) with the Bogert Copper Cable kit? This improves starting speed
and longevity.
3) Find a more open minded A&P Concorde recently modified the battery
cases so they will fit in the Piper Battery Box.
4) Place your battery on a Charger for an hour a day. Low current. A
standard appliance timer works fine.
5) Use a battery heater.
Michelle (A&P)
am a newbie for this particular plane), I would like to have a bit
more power in my battery, especially in very cold conditions such as
we have up here in central Wisconsin.
said that he tested it and that it was "fine."
G25 has only about 225 cold cranking amps. I noted that the G35S has
250 cold cranking amps.
believe.
has better cold cranking amps that the G25?
Thanks in advance.
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
