Anyone have an address in the Chicago area to obtain aviation grade
oxygen? I have a friend who is having a heck of a time finding it. You would think that some of the smaller airports handling executive jets would have it. Thanks, John |
On Jul 12, 4:39*pm, ContestID67 wrote:
Anyone have an address in the Chicago area to obtain aviation grade oxygen? *I have a friend who is having a heck of a time finding it. You would think that some of the smaller airports handling executive jets would have it. Thanks, John Go to your local welding supplier. The oxygen is just the same as you get from an FBO and a fraction of the price. Andy |
![]() Go to your local welding supplier. *The oxygen is just the same as you get from an FBO and a fraction of the price. Andy I don't believe that it can be welders oxygen. It can't even be medical oxygen. It must be "Gaseous aviator’s breathing" (AVB) oxygen. I read it has to do with the moisture content to prevent freezing. True? It there an FAA regulation on this? I can't find it. Some info here http://www.faa.gov/pilots/safety/pil..._Equipment.pdf. |
![]() I don't believe that it can be welders oxygen. *It can't even be medical oxygen. *It must be "Gaseous aviator’s breathing" (AVB) oxygen. *I read it has to do with the moisture content to prevent freezing. *True? False. The only oxygen available is just pure oxygen. There are no classes, categories or separate "paper trails". I have been told the familiar blue "Aviators Oxygen" oval sticker is applied at the retail level solely for the purpose of setting a higher price. There are no government regulations requiring it's use. It there an FAA regulation on this? *I can't find it. There are no FAR's addressing oxygen composition. The words "aviation or aviators oxygen" do not appear in the FAR's nor in any other regulation I can find. The FAR's only describe when and where 'oxygen' is to be used. |
On Jul 12, 7:51*pm, ContestID67 wrote:
Go to your local welding supplier. *The oxygen is just the same as you get from an FBO and a fraction of the price. Andy I don't believe that it can be welders oxygen. *It can't even be medical oxygen. *It must be "Gaseous aviator’s breathing" (AVB) oxygen. *I read it has to do with the moisture content to prevent freezing. *True? It there an FAA regulation on this? *I can't find it. Some info herehttp://www.faa.gov/pilots/safety/pilotsafetybrochures/media/Oxygen_Eq.... As Bill states, this is completely wrong. Its an old wives tale that has been repeated here before and I've tried to shoot it down then as well. I have some background in low-temperature physics/cryogenics research so let me play whack-a-mole with this. Oxygen is manufactured by fractional distillation of liquid air (the Linde process). This generates highly pure oxygen. This produces an inherently dry gas product. The same liquid oxygen is boiled off and packaged as compressed oxygen for welding, aviation, medical, other industrial and scientific applications. All the handling system for these cryogenic liquids and gasses are very very clean for saftey reasons. None, nada, zilch of these end-use gasses have moisture added to them. Compressed oxygen is a dangerous oxidizer. You would be beyond insane to want to introduce moisture and resultant corrosion problems to a compressed oxygen storage system. And under high pressure the moisture would condense out. Expensive compressors and other equipment would be damaged by this liquid condensation. Adiabatic cooling as the gas is release through valves and regulators would cause condensation--if there was moisture in aviators breathing oxygen regulators and flow meters etc. could freeze up at cold temperatures found at altitude. It just makes absolutely no sense to imagine any addition of moisture to the compressed gas for any purpose. What seems to be the source of this confusion is medical applications where water is vaporized and added to the dry gas or the dry gas is bubbled through water etc. at delivery time--all done at very low pressure. So can we bury this one please? Darryl |
On Jul 12, 9:11*pm, Darryl Ramm wrote:
So can we bury this one please? Darryl You may have to talk to someone at FAA. The link provided by the OP includes this: "Aviator’s oxygen must meet certain standards to ensure that it is safe to be taken to altitude. Only aviator’s-grade breathing oxygen meets this specification. Neither medical grade nor industrial grade oxygen is safe to substitute because they do not meet the same stringent standards as ABO." Of course it's been said many times in many places that this just isn't true but FAA does seem to want to keep up the illusion. Maybe their concern is that someone will top off with some other gas, such as nitrogen which is available at many FBOs, if they don't insist on ABO labeling. Andy |
On Jul 13, 6:31*am, Andy wrote:
On Jul 12, 9:11*pm, Darryl Ramm wrote: So can we bury this one please? Darryl You may have to talk to someone at FAA. *The link provided by the OP includes this: "Aviator’s oxygen must meet certain standards to ensure that it is safe to be taken to altitude. Only aviator’s-grade breathing oxygen meets this specification. Neither medical grade nor industrial grade oxygen is safe to substitute because they do not meet the same stringent standards as ABO." Of course it's been said many times in many places that this just isn't true but FAA does seem to want to keep up the illusion. *Maybe their concern is that someone will top off with some other gas, such as nitrogen which is available at many FBOs, if they don't insist on ABO labeling. Andy No thanks I don't want to talk to anybody at the FAA about this. The claims are just not correct for all practical purposes. The comment may be referring to other manufacturing processes used sometimes for some low-purity industrial oxygen (which you could not buy if you tried). But the stuff that goes out into the supply chain for welding, medical, aviation etc. applications is all sourced from Linde processing and is highly pure. As Richard says it comes from the same big container - go talk with your gas supplier (but some naturally won't want to sell you welding O2 if you tell them its for aviation...). Mixup or contamination of any oxygen source is a potential risk. Since the same suppliers are handling the bottles I don't see one as as safer than the other. For whatever use the cylinders better be clearly labeled as O2. Maybe more useful discussions on saftey are not related to the O2 labeling but the handling of the cylinders, trans-filling procedures, maintenance and servicing etc. I've seen some pretty blase/scary handling of O2 by glider pilots, old steel bottles last inspected God knows when, etc... Darryl |
Go to your local welding supplier. *The oxygen is just the same as you get from an FBO and a fraction of the price. Andy I don't believe that it can be welders oxygen. *It can't even be medical oxygen. *It must be "Gaseous aviator’s breathing" (AVB) oxygen. *I read it has to do with the moisture content to prevent freezing. *True? It there an FAA regulation on this? *I can't find it. Some info herehttp://www.faa.gov/pilots/safety/pilotsafetybrochures/media/Oxygen_Eq.... go to this link for info about O2 http://www.mhoxygen.com/attachments/...nformation.pdf I provide O2 service for our towing operation at Montague. I purchase large bottles from a gas distributor, (who is also a welding gas and other gas distributor), The O2 is the same, ie comes out of the same source except Medical O2 requires a prescription, bottle is labeled Medical O2 Welding O2 Aviation O2 bottle is green and labeled ABO Aviators Breathing Oxygen. There is absolutely no difference in the product inside the bottle. Richard www.craggyaero.com |
On Jul 12, 7:39*pm, ContestID67 wrote:
Anyone have an address in the Chicago area to obtain aviation grade oxygen? *I have a friend who is having a heck of a time finding it. You would think that some of the smaller airports handling executive jets would have it. Thanks, John If he can find a Technical Dive shop in the area that mixes gases for deep water diving then they will fill tanks with aviators oxygen. Best and easiest, and cheapest source I have in TN. Usually walk in and walk out with a full tank instead of having to leave the tank at a gas supply. Kevin |
Anyone have an address in the Chicago area to obtain aviation grade oxygen? *I have a friend who is having a heck of a time finding it. You would think that some of the smaller airports handling executive jets would have it. Thanks, John The O2 for welding, medical and ABO comes from the same source at the GAS Supply Vendors the only difference is: Medical: Bottle is labeled Medical O2 and requires a prescription. Welding: Bottle is lableled O2 ABO: Bottle is labeled ABO (Aviatiors Breathing Oxygen) There is absolutely no difference in the O2. I supply O2 for our Soaring Operation at Montague, CA. I Purchase O2 from a local Gas Distributor. I have watch them fill the bottles. Also info from Mountain High: http://www.mhoxygen.com/attachments/...nformation.pdf Richard www.craggyaero.com Richard www.craggyaero.com |
Chicago Area Mini-Contest | Sean Fidler | Soaring | 0 | April 16th 11 10:45 PM |
Aircraft looking for help in the Chicago area | steveukman | Home Built | 1 | April 15th 07 11:53 PM |
Chicago area from the southwest - advice? | Chad Speer | Piloting | 39 | December 31st 06 08:17 PM |
Soaring in the Chicago area in November | Gordon Schubert | Soaring | 1 | October 15th 04 03:58 PM |
Chicago area soaring november ? | Marc Till | Soaring | 3 | October 12th 04 03:58 AM |
