Cheap self-rig system demonstration
Old July 14th 11, 04:42 AM posted to rec.aviation.soaring
Frank Paynter[_2_]
Default Cheap self-rig system demonstration
Evan Ludeman (T8) took this video of me assembling my Ventus 2bx at
Wurtsboro last week, using my el-cheapo single-rig system. The video
has not been edited in any way, and assembly that morning was actually
a little slower than usual ;-)
http://www.youtube.com/watch?v=bcRipsiPgdk
TA
Old July 14th 11, 05:06 AM posted to rec.aviation.soaring
mike
Wurtsboro last week, using my el-cheapo single-rig system. *The video
TA
Pretty slick!
Old July 14th 11, 05:31 AM posted to rec.aviation.soaring
CLewis95
TA
Pretty slick!
VERY NICE! ... Frank you can sure tell all those contest assemblies
are paying off ... ~7minute On-Man Assy.
Curt - 95
Old July 14th 11, 05:34 AM posted to rec.aviation.soaring
Mike the Strike
TA
Pretty slick!
Yes indeed - very slick indeed.
How would you do that on a rock and gravel surface?
Mike
Old July 14th 11, 06:10 AM posted to rec.aviation.soaring
Gary[_5_]
TA
Wow!! We're going to talk when you get home! What are the tubes?
Gary Adams GA2
Old July 14th 11, 06:14 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Very nice! But why do you put the gear down before rigging? Wouldn't it
be easier if the fuselage was lowered as much as possible?
Also, with the hydraulic jack, there is the possibility it will leak
down (or someone will accidentally trip/kick the release lever) before a
wing is on it, and let the fuselage tip over.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old July 14th 11, 10:16 PM
Ventus_a Ventus_a is offline
Senior Member
First recorded activity by AviationBanter: May 2010
email me)
Pretty slick Frank
Further to Eric's point about leaving the wheel up, I use the jack to raise or lower the fuse for final wing alignment on my Nimbus3D. Saves walking out and adjusting the wing stands and the main pin goes in real easy. I also put the left wing in first so the partially inserted pin keeps the wing in place
Cheers
Colin
Old July 14th 11, 07:51 AM posted to rec.aviation.soaring
GM
TA
Hi Frank,
amazing! What are these rolls you are using to lay the wings on?
Anyhow, the time to beat is ...... ;-) http://www.youtube.com/watch?v=wG_nE...feature=fvwrel
GM
Old July 14th 11, 03:16 PM posted to rec.aviation.soaring
Andy[_1_]
TA
How much wear do you have on the bottoms of the spar stubs and the
base of the fuselage spar box?
Even lifting the wing root into place during 2 man rig will produce
some rubbing there. One of the nice things about a good one man rig
is the the wear in that area is almost eliminated.
Andy
Old July 14th 11, 04:20 PM posted to rec.aviation.soaring
Dan Marotta
Holy wing stand, Batman...
I was rigging my Mosquito B like that out of a Pfeiffer trailer 25 years
ago. It's good to see that there are other geniuses in the world besides
just me! ;-)
Of course, I only did it on grass...
"Frank Paynter" wrote in message
TA
CHEAP Los Angeles C-172 Flying Club CHEAP [email protected] Aviation Marketplace 7 May 7th 09 04:32 PM
CHEAP Los Angeles C-172 Flying Club CHEAP [email protected] Owning 1 May 7th 09 04:32 PM
CHEAP Los Angeles C-172 Flying Club CHEAP Sunho Owning 2 May 7th 09 01:13 AM
CHEAP Los Angeles C-172 Flying Club CHEAP xyzzy Owning 0 April 6th 09 04:31 PM
The Unmanned Combat Air System Carrier Demonstration Program: A New Dawn for Naval Aviation? Mike[_7_] Naval Aviation 15 July 16th 07 06:05 PM
