The Cherokee 6-260 has a shorter book takeoff roll than the -300. Any
suggestions as to why? The gross weight is the same. Props slightly different. |
Greg Esres wrote: The Cherokee 6-260 has a shorter book takeoff roll than the -300. Any suggestions as to why? The gross weight is the same. Props slightly different. Better test pilot that day? -- Ben Jackson http://www.ben.com/ |
That occurred to me as well. ;-) |
Seems unlikely. What are you using for a data source?
Mike MU-2 "Greg Esres" wrote in message ... The Cherokee 6-260 has a shorter book takeoff roll than the -300. Any suggestions as to why? The gross weight is the same. Props slightly different. |
Nothing authoritative. I don't have the POH's. But a pilot of my acquaintance first asserted the difference to me. He claims to have researched the issue thoroughly before he bought his -260. He claims that bush pilots prefer the -260 for that reason. The only supporting evidence I have found is a web site that had performance specs on the a/c and it validated what he said. I agree that it seems unlikely, but I'd prefer to be able to show the guy some data. Every now and then, something unlikely turns out to be true. ;-) |
There seem to be a scattering of web sites that supply the same data.
I suspect they're using one common data source. However, I found one web site that showed the -260 as a worse performer, as you would expect. I'm going to see if I can acquire a -300 POH so I can compare with my acquaintance's -260. Maybe whoever created the original database used for the internet info got it wrong. |
![]() Greg Esres wrote: The Cherokee 6-260 has a shorter book takeoff roll than the -300. According to _The Illustrated Buyer's Guide to Used Airplanes_, by Bill Clarke, the takeoff roll for the 300 is 110' *shorter* than that of the 260. Since that's what one would expect, I tend to believe him. George Patterson Great discoveries are not announced with "Eureka!". What's usually said is "Hummmmm... That's interesting...." |
So do I. Thanks for that. |
My really old copy of the Aircraft Bluebook Price Digest shows the following T/O ground runs:
PA28-300 '73 and later 900' PA28-300 '72 and earlier 1050' PA28-260 '74-'78 1200' PA28-260 '73 and earlier 740' All four show a gross weight of 3400 lbs. Max T, MCFI Greg Esres wrote in message ... The Cherokee 6-260 has a shorter book takeoff roll than the -300. Any suggestions as to why? The gross weight is the same. Props slightly different. |
"Max T, CFI" wrote in
news:Fl1Sb.138398$nt4.616428@attbi_s51: My really old copy of the Aircraft Bluebook Price Digest shows the following T/O ground runs: PA28-300 '73 and later 900' PA28-300 '72 and earlier 1050' PA28-260 '74-'78 1200' PA28-260 '73 and earlier 740' PA-28? ... did you mean PA-32? -- John Godwin Silicon Rallye Inc. (remove SPAMNOT from email address) |
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance | [email protected] | Owning | 5 | July 22nd 03 12:35 AM |
