Finding a Good A&P
Old February 1st 04, 03:52 PM
O. Sami Saydjari
Default Finding a Good A&P
OK, I have a controversial question. How does one find a good A&P
mechanic. I just bought a Piper Turbo Arrow III recently and I want to
find a mechanic in my area (Central Wisconsin) that I can trust and is
competent. I am interested in hearing about how folks find the good
A&Ps out there, other than by pure luck.
I have had a couple of disappointing experiences with A&Ps where they
missed some pretty significant problems. I found one through word of
mouth. The other, well, I found the closest Piper Service Center near
me (figuring that they had special knowledge and expertise with Pipers
-- turned out to not be so).
-Sami
Old February 1st 04, 06:45 PM
Newps
Luck has something to do with it. You need to get out and about and
have various mechanics work on your plane. When you find one you like
you stick with him. My main mechanic is at an airport 30 miles SW of
where I am based. For relatively minor stuff I have 3-4 mecahnics near
here that I have come to my hangar to do stuff.
Old February 1st 04, 08:42 PM
Ben Haas
"O. Sami Saydjari" wrote in message ...
-Sami
This is exactly why a large percentage of owners now are building and
mantaining our own planes. I have owned several certified planes and I
will be damned if I ever want to see a yellow tag again. I found a
great A&P/ IA when I used to live in Fla. I was alomst killed by a
couple of bad A&P's before I found him. If I go out I want to be the
one who does it to myself, not someone who just barely passed a test
to work on a plane but is not smart enought to get a PPL to test fly
what he just worked on. My two cents worth...
Ben Haas N801BH
Old February 3rd 04, 06:57 PM
John Purner
Ben,
I agree. I don't let anyone touch my airplane unless I am there to
supervise.
John Purner
Editor - The $100 Hamburger
http://www.100dollarhamburger.com
"Ben Haas" wrote in message
om...
-Sami
Ben Haas N801BH
Old February 1st 04, 08:54 PM
Jay Honeck
mechanic.
In my case, it was trial and error. Several very expensive errors, too.
If Bob Demski is still around at Sylvania Field (C89) between Racine and
Burlington, he'll take care of your Arrow. Good guy, honest, and won't pad
your bill too much. Pretty crusty, though -- but don't let that fool you.
He's got a big heart, under that rough exterior.
He used to own the airport, but has now sold it so he can do nothing but
putter around with airplanes all day.
THAT'S the kind of A&P you want. I've got one here just like that, and he'd
play with airplanes for free if his business partner would let him...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 2nd 04, 03:34 PM
Michael
mechanic.
By personal recommendation from someone who shares your maintenance
philosophy and has dealt with the individual (NOT the shop) before -
and no other way.
You should no more let a randome stranger work on your airplane just
because some fed issued him an A&P ticket then you would let a random
stranger fly your airplane just because some fed issued him a pilot
ticket.
Michael
Old February 2nd 04, 03:21 PM
Mark Astley
As hokey as it sounds, my first criteria is the condition of the shop floor.
The shop which does my work has two hangars both with pristine white floors.
The shops I didn't choose have dirty unpainted floors. I believe there's a
correlation between clean/neat facilities and competent work, but maybe I'm
just fooling myself.
I also reviewed the comments on airnav. It's sometimes hard to tell a shill
from a real customer but I found the comments to be fairly accurate. And
once you find a shop, post it here, you'll likely find someone who's been
there before. You can also ask other owners at your home base. Most are
fairly candid about such things.
When I made my choice, I was lucky enough to do a trial with some simple
maintenance (if something major breaks you may not have this option): I got
an oil change and a strut refilled, and also talked to the mechanic about
some plug fouling issues. My chat with the mechanic convinced me that this
was a competent individual whom I could rely on in the long term. To be
honest, though, I don't think you can really know until your first annual,
which is a sort of test of how thorough your mechanic is.
Finally, I resolved to become more knowledgable about my aircraft. I joined
a type club, acquired the parts and maintenance manuals, and did some
independent research each time I had a squawk. I suggest you do the same,
regardless of where you get your maintenance done. You'll feel much better
if you can do some high-level problem determination on your own and compare
with what the shop wants to do to the plane. A type club is also great for
guessing where your next problem might be, and provides some hints as to
what your mechanic should be looking for.
best of luck,
mark
-Sami
Old February 2nd 04, 04:05 PM
Michelle P
You are fooling yourself. This sounds more like a personal comfort issue.
There is an FBO with a fairly large Maintenance shop with pristine
floors and a lousy reputation. They look good but there quality of
service is lousy. They are also the most expensive in the area. Guess
that must be the time they spend cleaning the floor.
An A&P I used to work for could not keep the place clean if they wanted
to. THey were too busy fixing airplanes.
When the airport had issues after 9/11, the Shop moved outside the ADIZ
and many of the based aircraft went with the shop. Now that's loyalty!
Michelle
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old February 3rd 04, 03:26 AM
O. Sami Saydjari
I have found the airnav comments to be nearly useless. Almost all of
them relate to the FBO ramp service and whether the receptionist greeted
them with a smile or not. I have seen precious few on the competence of
the A&Ps. Also, I think people are reluctant to make negative postings.
It is hard to tell the difference between true incompetence and an
honest mistake. Who wants to trash someone's business so publically on
the basis of one experience? I know I am reluctant to make negative
postings even though I have had three negative experiences.
Well, unfortunately, I am not knowledgable enough yet to really tell the
difference between someone who sounds like they know what they are
talking about and someone who actually does. I am learning, but it is
not a quick road to travel.
Yes, good suggestion. This newsgroup is very helpful in that regard. I
have also joined the Piper type club. Everytime I learn more, I become
even more disappointed in the service I have had.
best of luck,
mark
-Sami
Old February 3rd 04, 06:04 AM
Newps
It doesn't just sound hokey, it is hokey.
I believe there's a
There ain't.
Free Volksplane to good home, located in Chino Hills CA Bryan Zinn Home Built 3 July 18th 04 02:55 AM
looking for good brake master cyls for homebuilt. clare @ snyder.on .ca Aviation Marketplace 0 March 28th 04 05:13 AM
New novel and it's a good one Lone Eagle Military Aviation 7 October 2nd 03 04:13 AM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
Commander gives Navy airframe plan good review Otis Willie Military Aviation 0 July 8th 03 09:10 PM
