Spoiler Signal
Old July 24th 11, 07:15 AM posted to rec.aviation.soaring
Default Spoiler Signal
Perhaps we should consider teaching that the first thought with a
sudden signal (fan, wag, rock, ...) should be check your
configuration, particularly the spoilers. It should not take more
than a second or two. If the signal really is to release, there would
be a very slight delay to pull the knob, but it would avoid some bad
consequences, and the the tow pilot still has the ability to dump the
glider.
Old July 24th 11, 10:59 AM posted to rec.aviation.soaring
Ramy
configuration, particularly the spoilers. *It should not take more
than a second or two. *If the signal really is to release, there would
glider.
This sounds like a good idea, especially giving that the tow pilot may
also give the wrong signal under stress.
There really should be only one signal as suggested in another thread,
which means something wrong, close spoilers or release! But in any
case, radio call should come first, than climb to safe altitude (if
possible) before giving any signal. Safe altitude should be much more
than 200 feet, more like pattern altitude since a glider with fully
opened spoilers will sink like a brick.
Ramy
Old July 24th 11, 01:07 PM posted to rec.aviation.soaring
150flivver
glider.
Ramy
I disagree. There should be an urgent, serious emergency type signal--
the wing rock, and a not-so-serious, advisory type signal such as the
rudder waggle. If you can't keep the two separated, then perhaps you
need to take up a different hobby where you're actions don't impact on
the lives of the tow pilot or yourself. I don't have the luxury of
getting the glider up to 1000 feet if I throw a valve at 200. It's
much more common for the glider to survive a release at 200 feet, than
a tow plane having a serious problem down there and having a good
outcome.
Old July 24th 11, 02:04 PM posted to rec.aviation.soaring
Andy[_1_]
On Jul 24, 5:07*am, 150flivver wrote:
I disagree. *There should be an urgent, serious emergency type signal--
rudder waggle. *If you can't keep the two separated, then perhaps you
the lives of the tow pilot or yourself. *I don't have the luxury of
outcome.
I'd be interested in hearing from tow pilots that had a real in flight
emergency and used the wave off signal. It's always seemed to me to
be a bit like the "too slow" winch signal i.e. if you need to give it
then you're not in a situation to do so.
If there's time to negotiate I'll use the radio, if not I think I'll
be pulling the release.
Andy
Old July 24th 11, 07:25 PM posted to rec.aviation.soaring
T[_2_]
outcome.
emergency and used the wave off signal. *It's always seemed to me to
Andy
I've never been much in favor of the wing rock with a tow emergency,
but I teach it, we demonstrate it and we encourage proper training so
glider pilots don't release on a rudder wag.
I've had one real tow problem and witnessed others. I had engine
vibration from a stuck valve at about 100ft, got the solo student in
the 2-33 to above 200ft and called over the radio for a release. Which
he did and we both returned safely. We teach 200ft rope break returns
to the airport. If the radio was jammed with other chatter, the wing
rock was next.
Other tow problems I have witnessed include a blown cylinder, the
glider pilot saw the puff of smoke from the tow plane, and almost as
instantly the tow pilot dropped his end of the rope, no radio call, no
wave off. Both returned safely.
Not on tow, but a broken aileron cable on the tow ship after release.
It would have been difficult to do the wave off. The pilot landed
safely in the desert with only a few punctured tires.
As a tow pilot and CFIG, I feel that if I have a true emergency, the
glider pilot will get one radio call, maybe, and then see the rope
dropped from the tow end.
I have used the wing rock to signal a release when the radio was
blocked by other chatter. When we tow a 1-26, we get at least 1000fpm,
so the 1-26 pilot cannot determine if we are in good lift because his
vario is always pegged. Other than what he feels in the seat of his
pants from the climb rate increase. So, with precoordinatio, "Hey tow,
tell me when to get off", I'll rock the wings above 2000ft AGL when
the climb-o-meter shows 1500fpm and increasing.
T
Tow Pilot
CFIG
Old July 24th 11, 09:48 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
emergency and used the wave off signal. It's always seemed to me to be
a bit like the "too slow" winch signal i.e. if you need to give it then
Slightly OTT, but....
In the UK the 'too slow' winch signal is simply the glider lowering its
nose. Some years ago it was wing rocking, but that was changed once it
was realised that this can cause tip stalls which are the the last thing
we want on the cable. Lowering the nose is perfect because its dual-
purpose, being both a pre-emptive corrective action *and* suggesting to
the winch driver that more power would be nice.
We still use the fish-tailing 'too fast' signal, though its really only
useful for a fairly mild, slowly increasing overspeed. If its more than
mild I want to be off quicker than most winches can slow down.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old July 24th 11, 10:17 PM posted to rec.aviation.soaring
outcome.
Andy
I have had 3 real ones, all engine related. In all cases the glider
responded promptly and correctly.
I have done 2 rudder wags for spoilers out. One responded correctly
and fixed the problem. The second released.
Our club includes these signals in our Spring check.
Given all this, I will not do rudder wag until I have placed the
glider pilot in a position where misinterpretation will not be a cause
of an accident.
If I really need him off, it's wing wag and every man for himself.
UH
Old July 25th 11, 02:35 PM posted to rec.aviation.soaring
Mike[_28_]
"Given all this, I will not do rudder wag until I have placed the
cause
of an accident."
Now that is a good idea. If you are climbing at all don't wag until
well over 200' AGL. If the climb is that slow the glider pilot should
realize it and be checking his spoilers.
Mike
Old July 25th 11, 06:22 PM posted to rec.aviation.soaring
Dan Marotta
"Andy" wrote in message
outcome.
Andy
I've only *had* to wave off one glider - when the front seal on the engine
failed, coating the windscreen with oil and filling the cockpit (Pawnee)
with smoke. I gave the wing rock and started a spiral down to the field.
Talking with the instructor after the fact and thanking him for the quick
release, he laughed and said he saw wingtips rocking in a cloud of smoke.
He released at the initial puff of smoke.
Dan
Old July 26th 11, 03:14 PM posted to rec.aviation.soaring
Tom[_12_]
Last year, I wrote articles regarding this and other topics which are
widely distributed through the SSA's Soaring Magazine:
"Preventing Launching Accidents" and "Preventing Landing Accidents."
Further, I presented the same topics at the FAA Safety Facility at
Lakeland Florida. These presentations (and others) are available on
DVDs and printed booklets from our web site, WWW.EGLIDER.ORG
Both the DVDs and the printed booklets are inexpensive and make
excellent source material for club safety meetings.
These two issues dominate glider accident statistics.
The real problem is getting people to take the few minutes to become
educated and to adopt the simple, life-saving practices that will save
their lives. The well-known 5 hazardous thoughts, Anti Authority,
Impulsivity, Invulnerability, Macho and Resignation dominate glider
accident causes.
I will be conducting several FAA approved, Flight Instructor
Revalidation courses begining in November. (First in Minden, Nevada,
Nov 12/13.) Any pilot interested in learning about safety issues and
standardized procedures can attend.
Tom Knauff
using less spoiler just before the flare??? Gary Emerson Soaring 16 October 29th 07 01:08 PM
Landing with one spoiler [email protected] Soaring 82 October 7th 05 12:58 AM
Nimbus 3 25.5 tip spoiler cable replacement tango4 Soaring 0 May 3rd 04 09:05 PM
Spoiler placement and design. B2431 Home Built 9 November 11th 03 04:02 PM
