Lack of power in Cessna 172-R
Old February 12th 04, 07:02 PM
Chuck
Default Lack of power in Cessna 172-R
Hi, all,
Could someone please provide some suggestions on this.
Last summer we bought a 1997 160 HP Cessna 172-R. The test flight
(with 3 adults) went just fine.
When I picked the plane up from the shop after the service (required
to fix certain things that needed it [such as a loose tail!], the
performance was very sluggish. It did not seem like the same plane -
quite underpowered.
Even below gross weight, it couldn't take off from a 2200' runway
without scaring the heck out of me thinking we weren't going to make
it. OK it was hot but the book said we should be over a 50' obstacle
at about 1800' - we were not even close!
All rpm indications were within spec (for static run-up, etc). When on
the takeoff roll, rpm was about 2100, which seemed low, but there is
no spec in the POH for rpm for the takeoff roll. The rpm went much
higher after we were cruising (2300 or so).
Also, there was a "burbling" sound from the exhaust.
The prop was removed, inspected and put back on (with pleanty of
scratch marks which weren't there before.
Any suggestions would be greatly appreciated.
TIA Chuck
Freedom Chuck - The Man of 1,000 Songs
see my website at: www.freedom-chuck.com
Old February 12th 04, 07:55 PM
Gary
Hi, all,
quite underpowered.
TIA Chuck
Do a compression check on all cylinders. Find out from the factory what RPM
you ought to get on full power static runup. When you get to know an
airplane and one day it seems sluggish, it probably is and you need to
figure out why.
Old February 13th 04, 12:57 AM
Dan Thomas
"Gary" wrote in message ...
Maybe loose baffle in muffler restricting the outlet. Could have
broken loose between the time you tried it and the time you took it
away.
Other things to check might be one mag retarded somewhat, perhaps
caused by a broken impulse coupling spring.
Did you try leaning the mixture a bit to see if there was better
RPM in the static runup?
Dan
Old February 14th 04, 01:27 PM
Jay Honeck
I leaned the mixture for the static runup and consequently got good
results. I did NOT lean before takeoff. Perhaps that is significant.
That can be very significant on a hot day.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 12th 04, 08:02 PM
No Spam
Look at the TCDS (3A12) and you'll find static RPM limits. Go he
http://www.airweb.faa.gov/Regulatory...keModel.nsf/0/
EE81A0B13ADB620986256E2B0054B119?OpenDocument
Static RPM, I would think - flame on, is a pretty good indication of overall
engine health. At least it's a place to start. Only 2100 during the takeoff
roll sounds like something ain't right.
Has it been this way since last Summer?
No Spam
Old February 12th 04, 09:42 PM
Victor J. Osborne, Jr.
Are you getting enough fuel flow/pressure?
Thx, {|;-)
Victor J. (Jim) Osborne, Jr.
take off my shoes to reply
Old February 12th 04, 10:17 PM
Roger Long
If the lifters spall, become rough, and wear down the cam, there will be
almost no roughness. The engine will simply lose power as you describe. It
may make static RPM but not reach full RPM in cruise (it's a bit more
complex with a CS prop).
Oil analysis will not show the big pieces of metal that come off the lifters
and may miss the cam shaft wear as well. Have the filters been cut open and
carefully inspected at each oil change? It takes more than just a look.
They need to be drained and inspected very closely. Washing in solvent and
running a magnet around in the pail is recommended by some.
This is just one possibility but it's very much on my mind since our engine
is currently spread out on a rebuild bench.
Roger Long
Old February 12th 04, 11:28 PM
Aaron Coolidge
Chuck wrote:
: Hi, all,
Hi Chuck!
: All rpm indications were within spec (for static run-up, etc). When on
: the takeoff roll, rpm was about 2100, which seemed low, but there is
: no spec in the POH for rpm for the takeoff roll. The rpm went much
: higher after we were cruising (2300 or so).
: Also, there was a "burbling" sound from the exhaust.
There have been numerous cases of the 172R's fuel injection running
excessively rich, causing poor idle, loss of power, etc. Do ground
witnesses see a trail of black smoke from the exhaust at full power?
You might want to ask a mechanic familiar with the 172R fuel injection
about how it might be tested.
IIRC, the 172S, the 180 HP version, has a much lower incidence of this
issue.
Aaron Coolidge (N9376J)
Old February 12th 04, 11:39 PM
G.R. Patterson III
Fuel spilling in. It's running way too rich.
George Patterson
A diplomat is a person who can tell you to go to hell in such a way that
you look forward to the trip.
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 03:40 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 12:57 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 12:57 AM
Cessna 150 lost power with AD 96-12-06? Ozzy Countin Owning 3 August 17th 03 05:41 AM
