Hello,
Has anyone seen any data/research showing the performance gains of filling the fiberglass weave of a composite aircraft such as a KR-2? For example, if a KR is built with a RAF-48 or NACA wing (non-laminar), if layups were done over a smooth substrate (smooth foam), and the weave of an "average" weave glass was left unfilled (after peel-ply), how would speed be effected? Dacron-covered planes of course get by with a bit of weave showing. If the cruise speed of a given KR-2 was 120mph "filled," any idea on how much slower it would cruise if left bare but painted? The looks would probably suffer, but how about performance and safety? All opinions and ideas are welcome. |
On Sat, 20 Dec 2003 15:47:22 -0800, LakeCapt wrote:
Hello, Has anyone seen any data/research showing the performance gains of filling the fiberglass weave of a composite aircraft such as a KR-2? For example, if a KR is built with a RAF-48 or NACA wing (non-laminar), if layups were done over a smooth substrate (smooth foam), and the weave of an "average" weave glass was left unfilled (after peel-ply), how would speed be effected? Dacron-covered planes of course get by with a bit of weave showing. If the cruise speed of a given KR-2 was 120mph "filled," any idea on how much slower it would cruise if left bare but painted? The looks would probably suffer, but how about performance and safety? All opinions and ideas are welcome. I'm not sure I would want to try this. The results would probably be somewhere between like having frost on the wing and 40 grit sand paper. Many people have gone off the end of the runway when trying the "I wonder if it will fly with frost on the wing" experiment. 40 grit sandpaper is used to simulate a thin layer of rough ice on the leading edge of the wings as part of the icing approval flight testing on recent transport category aircraft. I've flown these flight tests on two different types, and there is a very large lift loss if the slats are retracted - something like 40% loss in maximum lift IIRC. So, I would spend the time to get a fairly smooth surface, at least up to the point of maximum thickness of the wing. The aft part of the wing is less critical, so you might get away with leaving the weave unfilled there. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ e-mail: khorton02(_at_)rogers(_dot_)com |
Roger Halstead wrote in message . ..
On 20 Dec 2003 15:47:22 -0800, (LakeCapt) wrote: I'm not sure I follow all this and maybe I'm missing what you are asking but... Sorry I wasn't so clear. You've generally touched on the major points. The level of surface finish I am suggesting is as follows: 1) Construct a KR wing with an outside surface of one contiguous piece of foam for the structure in front of the forward spar (the D section), and a second single contiguous piece of foam between the front and rear spars. 2) Cut this foam with hotwire from polystyrene similar to A) Mike's KR wing (Ez-style): http://www.fortunecity.com/marina/anchor/270/wing.html or B) Mark's sanded-down urethane method: http://home.hiwaay.net/~langford/owings.html 3) Sand the foam with a long straigt edge, as shown on Mark's page (leaving out the joggle around the spar). This should leave a *relatively* flat substrate/airfoil on which to glass. 4) Glass the wing wing a span-wise layer of glass top and bottom. When layed-up from root to tip, this removes any possible glass overlap joggle except on the leading edge. 5) Use peel-ply over the entire glass surface, leaving the fine reciprocal weave of the Dacron exposed once the peel-ply is removed. This is roughly the same roughness as your standard rag-and-tube dacron covered plane (before dope). 6) Paint the wing with a primer like Smooth Prime. This should fill just a little, and leave a good surface for a top coat. 7) Paint the wing with a final finish, which would provide minimal filling ability but protect the surface. So why all this hassle? The alternative is, of course, hundreds of hours of sanding and filling micro to get that glass finish, which may take as much time as building the rest of the structure on a plane like a KR. If one was happy with a 100mph cruise, this seems like a quick way to produce a set of wings. The question is, again, is this safe from a "draggy" surface standpoint on a NACA 4-digit airfoil. Thanks for your input. |
I believe what you are seeking is a better way to achieve smooth
wingskins. I will propose two methods which have achieved varying levels of success. Method One: Per the late aircraft designer/builder/pilot/writer Alex Strojnik, outlined in his book, Low Power Laminar Aircraft Technologies, lay up on a sheet of plexiglass, when the skin has partially cured peel it off the plexiglass and place it over the wing smooth side up, stretch another cloth - not fiberglass - over the wing weighting the overhanging edges until the skin cures. He used about 40 lbs of weight total on 4 foot sections. Strojnik claims this will work, given practice, three out of four times. His idea of "working" was a skin with virtually no defects, correct to "within 0.01 in." Your own idea of acceptable might be much more reasonable. He also cautions that at first it will work only half the time. Again when he says "work" he means virtually perfect skins. He used this method to produce d-cell leading edge skins continuous from upper spar to lower spar. His d-cell was pointed toward the ceiling when he formed these skins. He bonded them after forming them. As another poster pointed out, it is the leading edges which is most important. Method Two: Perform a normal layup directly on the wing, cover the wing with mylar sheet, bag the wing, apply moderate vacuum until cured. This method works very well on smaller sections and can work with larger sections if they are accurately formed and sufficient care is taken. Among RC modelers this method produces consistent mirror like finishes with very little sanding. The two most important factors to achieving a smooth surface a A smooth underlying surface. A smooth surface contacting the outer surface of the layup while it cures. Any method that manages to create these two things will succeed. It would be prudent to experiment with these ideas on smaller test sections to hone your skill before doing a "real wing". Fly right. nc |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | March 1st 04 07:27 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | Home Built | 0 | December 12th 03 12:01 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | Aerobatics | 0 | December 12th 03 12:00 AM |
OT- beech starships still flying? | patrick mitchel | Home Built | 6 | November 30th 03 03:30 AM |
the thrill of flying interview is here! | BW | Aerobatics | 0 | October 22nd 03 12:35 PM |
