I was flying yesterday and noted on my GEM that on cyl #1, the EGT was
normal, but the CHT was very low. Most of the time the CHT was off the scale low, so there was essentially no reading, but occasionally it would come up enough to be at the bottom or one bar from the bottom of scale. I can't think of a scenario which would cause normal EGT, but CHT 150 deg lower than normal. The engine runs normally. So I'm suspecting a bad CHT sensor although it if failed outright the GEM manual says it would just be missing all the time. Any other ideas? (This is on an IO-520 in a Bonanza, BTW.) - Mark |
On Wed, 03 Mar 2004 17:36:59 GMT, "markjen"
wrote: I was flying yesterday and noted on my GEM that on cyl #1, the EGT was normal, but the CHT was very low. Most of the time the CHT was off the scale low, so there was essentially no reading, but occasionally it would come up enough to be at the bottom or one bar from the bottom of scale. I can't think of a scenario which would cause normal EGT, but CHT 150 deg lower than normal. The engine runs normally. So I'm suspecting a bad CHT sensor although it if failed outright the GEM manual says it would just be missing all the time. Any other ideas? (This is on an IO-520 in a Bonanza, BTW.) - Mark Loose connection. Bad probe Bad channel in the GEM. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
You nailed it.
Jim Ron Rosenfeld shared these priceless pearls of wisdom: -Loose connection. -Bad probe -Bad channel in the GEM. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
"markjen" wrote:
I can't think of a scenario which would cause normal EGT, but CHT 150 deg lower than normal. The engine runs normally. I'm betting on Ron's #1 choice: a bad connection. First place to look is the splice between the wire coming from the GEM and the lead coming from the probe. These are often screw/star washer/ring terminal/nut affairs that can become loose. They're usually in the engine compartment covered by sleeves. -- Dan C172RG at BFM (remove pants to reply by email) |
When my mechanic had my JPI installation half finished, I noticed in the
installation manual that JPI specified the star washer be _between_ the ring terminal from the probe and the wire to the display. I thought that was interesting and unusual. He had been putting them under the nut. After I pointed that out, he made the remaining connections with the star washer between the terminals. I've noticed no difference in operation so far. Jon "Dan Luke" wrote in message ... "markjen" wrote: I can't think of a scenario which would cause normal EGT, but CHT 150 deg lower than normal. The engine runs normally. I'm betting on Ron's #1 choice: a bad connection. First place to look is the splice between the wire coming from the GEM and the lead coming from the probe. These are often screw/star washer/ring terminal/nut affairs that can become loose. They're usually in the engine compartment covered by sleeves. -- Dan C172RG at BFM (remove pants to reply by email) |
"Jon Woellhaf" wrote:
... I noticed in the installation manual that JPI specified the star washer be _between_ the ring terminal from the probe and the wire to the display. I've had one become loose, but I don't remember what the assembly order was. Next time I've got the cowl off, I'll check a couple. Thanks for the tip. -- Dan C172RG at BFM (remove pants to reply by email) |
Thanks for all the good ideas guys, appreciate it.
- Mark |
![]() On 3-Mar-2004, "markjen" wrote: I can't think of a scenario which would cause normal EGT, but CHT 150 deg lower than normal. The engine runs normally. So I'm suspecting a bad CHT sensor although it if failed outright the GEM manual says it would just be missing all the time. Any other ideas? Is it possible that the probe is not making good thermal contact with the cyl. head? -- -Elliott Drucker |
Blackbird v. Mig-25 | Vello Kala | Military Aviation | 79 | September 15th 04 04:05 AM |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Accelerated spin questions | John Harper | Aerobatics | 7 | August 15th 03 07:08 PM |
