Are there any working designs for an air extractor for the Ventus 2?
On Aug 21, 9:35*pm, Tim Taylor wrote:
Are there any working designs for an air extractor for the Ventus 2? What is an air extractor? Bill Snead |
On Aug 24, 6:53*pm, " wrote:
On Aug 21, 9:35*pm, Tim Taylor wrote: Are there any working designs for an air extractor for the Ventus 2? What is an air extractor? Bill Snead It's an air exit for the cabin air. Some of the new gliders are being offered with them. The DG website had quite a writeup on them a couple years ago. In theory, without the extractor, the cockpit is at positive pressure with the intake vents open and the air finds ways to escape that are not helpful drag-wise. By using an extractor, cabin pressure is dropped, and airflow is not disturbed by the air trying to escape through aileron hinges, spoiler boxes, or whatever. I have a simple 'Mandl Extractor' I made for my glider, and I have NO idea what it does for performance, except that it encourages airlfow in the cockpit, and keeps me from roasting to death on those high temp, strong inversion layer Jean summer days. |
On Aug 21, 9:35*pm, Tim Taylor wrote: Are there any working designs for an air extractor for the Ventus 2? What is an air extractor? Bill Snead A picture of a simple 'Mandl Extractor' similar to what DG employs. http://griderpirate.smugmug.com/Airp...55235760_LUSmZ |
On Aug 21, 7:35*pm, Tim Taylor wrote:
Are there any working designs for an air extractor for the Ventus 2? Tim, Sisu1A on RAS makes extractors for the ASW20 (some models), and has made one (or more) for his SZD. In both of those cases, the extractor replaces an access panel or hatch that happens to be in a position that is 'good enough'. I made a simple 'Mandl Extracor' for my Speed Astir http://griderpirate.smugmug.com/Airp...55235760_LUSmZ and it does increase cockpit comfort significantly. Does the Ventus have a conveniently placed access hatch, or will there be cutting involved? Cheers, Jim |
On Aug 24, 9:09*pm, jim wynhoff wrote:
On Aug 21, 7:35*pm, Tim Taylor wrote: Are there any working designs for an air extractor for the Ventus 2? Tim, * Sisu1A *on RAS makes extractors for the ASW20 (some models), and has made one (or more) for his SZD. In both of those cases, the extractor replaces an access panel or hatch that happens to be in a position that is 'good enough'. *I made a simple 'Mandl Extracor' for my Speed Astirhttp://griderpirate.smugmug.com/Airplanes/Glider-stuff/3702283_Rsct24... and it does increase cockpit comfort significantly. Does the Ventus have a conveniently placed access hatch, or will there be cutting involved? Cheers, Jim Jim, There will be cutting involved and most Schempp-Hirth's are Standard Airworthiness. I am looking at something similar to the Jonker's design for my Ventus 2 to improve the airflow and cooling in the cockpit. Tim |
On Aug 24, 8:31*pm, Tim Taylor wrote:
On Aug 24, 9:09*pm, jim wynhoff wrote: On Aug 21, 7:35*pm, Tim Taylor wrote: Are there any working designs for an air extractor for the Ventus 2? Tim, * Sisu1A *on RAS makes extractors for the ASW20 (some models), and has made one (or more) for his SZD. In both of those cases, the extractor replaces an access panel or hatch that happens to be in a position that is 'good enough'. *I made a simple 'Mandl Extracor' for my Speed Astirhttp://griderpirate.smugmug.com/Airplanes/Glider-stuff/3702283_Rsct24... and it does increase cockpit comfort significantly. Does the Ventus have a conveniently placed access hatch, or will there be cutting involved? Cheers, Jim Jim, There will be cutting involved and most Schempp-Hirth's are Standard Airworthiness. *I am looking at something similar to the Jonker's design for my Ventus 2 to improve the airflow and cooling in the cockpit. Tim Good luck in your search Tim! |
I have an LS-8. I had a Mandle Air Extractor installed on my aircraft
after reading all the comments on the DG website. DG bought the rights to produce the LS-8. Of course, to purchase the installation kit I had to join the maintenance program and still pay significant money for the parts. Then having it installed cost more. The Mandle is installed on the bottom of the fuselage just behind the wheelwell. The device made virtually no difference in my cockpit ventilation or noise. BIG Disappointment. Then, I bought the Butler vent and had it installed. It is installed on the top of fuselage just behind the canopy. WOW. I can feel air moving past my ears while flying. The canopy vent does not pop open at high speeds. There is virtually no noise. This is essentially the same type of vent that Sisu1A is using. It was worth the effort and money. I can't tell you if it improved my L/D by 5points or more, but the movement of air through the cockpit is greatly improved. Guy "DDS" |
On Aug 24, 9:21*pm, guy wrote:
...Then, I bought the Butler vent and had it installed. *It is installed on the top of fuselage just behind the canopy. *WOW. *I can feel air moving past my ears while flying... Huh. So, exhausting air into the low pressure area above the wings works better than trying to exhaust it into the high pressure area below the wings. Who'd'a thunk it? ![]() Thanks, Bob K. |
On Aug 25, 4:31*am, Tim Taylor wrote:
On Aug 24, 9:09*pm, jim wynhoff wrote: On Aug 21, 7:35*pm, Tim Taylor wrote: Are there any working designs for an air extractor for the Ventus 2? Tim, * Sisu1A *on RAS makes extractors for the ASW20 (some models), and has made one (or more) for his SZD. In both of those cases, the extractor replaces an access panel or hatch that happens to be in a position that is 'good enough'. *I made a simple 'Mandl Extracor' for my Speed Astirhttp://griderpirate.smugmug.com/Airplanes/Glider-stuff/3702283_Rsct24... and it does increase cockpit comfort significantly. Does the Ventus have a conveniently placed access hatch, or will there be cutting involved? Cheers, Jim Jim, There will be cutting involved and most Schempp-Hirth's are Standard Airworthiness. *I am looking at something similar to the Jonker's design for my Ventus 2 to improve the airflow and cooling in the cockpit. Tim http://www.easternsailplane.com/east...lplane/TheVent Couldn't fit that legally in Europe nowadays John Galloway |
FS Ventus 2cx 15/18 | SAM AND LEIGH ZIMMERMAN | Soaring | 0 | April 29th 08 02:10 PM |
FS: Ventus C | James Hamilton | Soaring | 0 | September 13th 06 09:18 PM |
FS: Ventus C 17.6 | John Shelton | Soaring | 0 | November 16th 04 12:55 AM |
FS: Ventus C 17.6 | John Shelton | Soaring | 2 | November 16th 04 12:53 AM |
FS Ventus C 17.6 | John Shelton | Soaring | 0 | August 18th 04 03:39 PM |
