Any time this topic comes up the discussion is about the contents of
the list. This post is about the physical attributes of a glider checklist. No matter what items are on a checklist, it doesn't matter if you can't find it when you need it. It doesn't matter if the type is too small to read. It doesn't matter if you can't hold it while you fly. If it's not convenient to use, it won't be used. Lists with large, easy to read type are usually too large to put on a glider panel. The CAP K-21's I fly have checklists dangling from the right side of the panels on parachute cord so just grabbing for the cord puts the list in your hand. Dropping the list lets it fall against the cockpit side between the pilots right leg and the side of the cockpit where it is completely out of the way yet easily found again. They are laminated in plastic so they are very durable. At just 2.5" wide and 10" high, they are easy to hold while marking an item with your thumb as you perform the check with the left hand. The lists use large, high-contrast type which is easy to read in all lighting conditions even by presbyopic seniors wearing dark sunglasses. The pre-takeoff checklist list is on one side and the landing checklist is on the other. This dangling checklist is so convenient, all pilots can be seen using it on every flight. Using it becomes so habitual it feels very uncomfortable to fly another glider without one. |
| Pre Takeoff Checklists | Tony[_5_] | Soaring | 40 | March 26th 10 03:56 PM |
| checklists | Private | Piloting | 5 | February 6th 08 01:48 PM |
| Pre-Lunch checklists | 01-- Zero One | Soaring | 9 | January 28th 06 11:38 PM |
| maintenance checklists | tony roberts | Owning | 2 | January 25th 05 11:59 PM |
| Where to buy MU-2 Checklists and books? | Rob C. | Owning | 3 | March 15th 04 02:08 AM |
