Mooney info
Old March 11th 04, 06:38 AM
eddie
Default Mooney info
Seems like I never have any good info to offer but always seem to find a
question or 10.
I'm a long time PA28 and C172 / C182 driver and I'm looking for something
faster with a little longer legs. I've never flown a Mooney but I like the
style, performance and gph numbers and some of the older ones are in my
price range.
My questions a
1.) Ballpark, what can I expect to spend on maintenance? I know the gear
and the prop add expense. Overall how does the hourly cost compare with my
PA28-161? Insurance only changes about 400.00 a year.
2.) Are there certain years/models to stay away from.
3.) Do they have any expensive, recurring AD's
4.) I know everything happens a little faster, but, other than that do they
have any nasty little gotchas. (like the narrow CG range on some Bonanzas)
5.) Are replacement parts more expensive than a Piper or Cessna?
I've looked at Mooney.com and mooneyowners.com but no really useful info
there. Just looking for experienced Mooney drivers to shed a little honest
light.
Ed
Old March 11th 04, 12:13 PM
Ron Rosenfeld
question or 10.
price range.
My questions a
light.
Ed
Real world numbers for an M20E (1965 Super 21) flown approximately 150
hrs/year, for the six years 1998-2003.
Over that entire time period, I spent about $120K on maintenance, fuel and
insurance.
The maintenance included a new engine, prop overhaul, and I am generally
meticulous about maintenance.
Of course, all costs are going up these days, and I do not perform any of
my own maintenance. And it takes several hours to do an oil change on my
bird.
On the "mature" electric gear Mooney's, there is a recurring AD on the gear
actuator.
Parts are generally available but expensive. I recently had to spend $350
for a starter relay from the factory.
Old March 11th 04, 02:43 PM
Bob Miller
Eddie,
It's not clear what end of the market you're looking for, Mooneys
range from a mid 60's vintage 4-cyl. Lyc @ $60,000 for a nice one to a
deiced 190 kt Ovation for $400,000+. What part of the market are you
targeting?
You can also try www.aviating.com/mooney for way more information than
you can possibly assimilate.
Bob Miller
'65C
Old March 11th 04, 02:44 PM
Dave Butler
question or 10.
price range.
I switched from a PA28-180 (sole owner) to a M20J (partnership) about 3 years ago.
My questions a
Don't have much experience with this as I'm not doing either the maintenance or
the bookkeeping in the partnership, but my general impression is positive.
No, I think they're all good. There's a big gap between the M20J, and the
"pre-J" models in performance. The J got the benefit of the Roy LoPresti mods.
The Precise Flight speedbrakes are helpful to get you slowed down to gear
extension speed, at least on the J. http://www.preciseflight.com/sb.html
light.
http://www.mooneypilots.com (MAPA) might be more helpful. mooneyowners.com is a
group of disgruntled former members of MAPA.
I offer http://www.employees.org/~dgbutler/201/201.html for some possibly useful
information. Check the article "how to do a prepurchase inspection on an M20J,
under "maintenance".
Dave
Remove SHIRT to reply directly.
Old March 12th 04, 01:24 AM
Jim Carter
"Dave Butler" wrote in message
question or 10.
something
price range.
years ago.
My questions a
gear
my
maintenance or
mods.
I had a Mooney mechanic (that's all he worked on) tell me to avoid the older
wooden tailed birds. I believe he said that parts had to be hand fabricated
as needed, but those are pretty scarce any more.
they
Bonanzas)
honest
light.
is a
useful
M20J,
Dave
Old March 11th 04, 10:59 PM
JDupre5762
There are still some early models with wooden tail groups around. I would stay
away from those unless my A&P was really current on inspecting and repairing
wooden structures.
One common problem is leaks from the wet wing. This can grow from a mere
annoyance to a serious problem. If they need to be resealed find someone with
current experience on doing the job right.
Oil changes are easily an hour to two hours more than any other aircraft. The
filter or screen is tough to get to and almost impossible to remove without
spilling all over the engine compartment. If you add the suction screen as
well that could be another hour.
Do yourself a favor and find a really good Mooney shop for your first annual.
Make sure they really go through the gear system. If done right once it should
be trouble free for a number of years.
I knew of one Mooney owner who brought his to a really expert Mooney shop every
three years for a top notch annual and let his regular shop do the intervening
two annuals. Seemed to me to be a good compromise between safety and the
pocket book.
John Dupre'
Old March 12th 04, 12:21 AM
markjen
Before you get very far with this, see if you can find a model in your price
range for a test flight, or at least a ride.
Mooneys are great planes on paper, but they have a lot of compromises to
achieve their speed and efficiency: a relatively cramped cabin with very
low seat height, poor outward visibility with an obtrusive center strut in
the panel (particularly on the early models), stiff controls, and skitterish
ground manners on their biscuit gear. To a lot of pilots, these things are
part of the Mooney "sports car" experience and no big deal - for me, they
make Mooney's unacceptably uncomfortable and unsatisfying to fly. A lot has
to do with your size/stature. Big guys tend to like Bonanzas and little
guys like Mooneys.
A 2nd thing to check into early-on is whether you have a good Mooney shop in
your area. To a shop which knows Mooneys, their maintenance/repair is no
big deal and you can get great service - these are well-built airplanes.
But shops that don't regularly work on Mooneys tend to hate working on them
because things are hard to get to.
If you pass these two tests, then go for one. I'm guessing that you're
perhaps looking into a $100K airplane, so I'd be looking at one of the early
201s which were good airplanes and well worth the premium over the earlier
Rangers and other 180-hp models. I really like the Ovations, but I'm
guessing they're in the $150K+ range.
- Mark
Old March 12th 04, 04:03 AM
Dude
.. Big guys tend to like Bonanzas and little
guys like Mooneys.
Being 6'3" and 200 pounds, I have to disagree with this. The seats are low
to the floor, and this and some other elements give people an impression
that it is tighter than it really is. Comfort is subjective, and your brush
is too wide. I liked the view from the Bo, but in spite of the low seats,
the Mooney won in every other comfort category. Having heard many other
people make similar remarks to yours, I was rather suprised.
Mooneys have the best cabin for the extremely tall pilot. I sat in a new
one, and had plenty of room to push my seat farther back. Also, the yoke
was not hitting my legs as it does in some Beech planes. You might want to
check the actual cabin width as well, as I believe the Mooney is larger.
Its the high windscreen and window arrangement that gives the Bo driver an
impresssion of more size.
Old March 12th 04, 05:05 AM
markjen
Impression or not, I feel terribly cramped in a Mooney and feel like I can
relax and move around in a Bonanza. Peering over the glareshield in a
Mooney makes me feel like I'm in a tank. But you're absolutely right - it
is subjective.
- Mark
Old March 12th 04, 03:18 PM
Dude
I know exactly what you mean. I feel cramped in a 182. I find that I
started squirming to get comfortable, though I did find plenty of room to
squirm.
Guess I will stick with low wings
PS, as someone who has driven a tank, I would have to say the Mooney is much
roomier and has less sharp things to bang yourself on. Also, the Mooney has
better visibility than either the M60 or the M1, except to the rear.
"markjen" wrote in message
news:Byb4c.11371$zS4.72266@attbi_s51...
an
is subjective.
- Mark
POSA Carb Info and HAPI Engine Info Bill Home Built 0 March 8th 04 08:23 PM
Looking for info on Flyins Chris Whitley Home Built 21 February 11th 04 09:21 PM
Mooney to Offer Light Sport Airplane Rick Pellicciotti Home Built 4 September 24th 03 01:08 PM
Cirrus vs Mooney Charles Talleyrand Owning 6 July 8th 03 11:35 PM
