Outstanding Soaring: California Mojave, Owens Valley, Western NV -Fri-Sun 08/26-28
Old August 26th 11, 01:45 AM posted to rec.aviation.soaring
WaltWX[_2_]
Default Outstanding Soaring: California Mojave, Owens Valley, Western NV -Fri-Sun 08/26-28
Take a look Dr Jack...
Outstanding soaring weather Fri through Sun. Lift rates 700-800fpm
average... much stronger in those 10 per cent...
It's a toss up between Fri and Sunday. The Mojave Desert, Owens
Valley and Western NV show full cu coverage bases 15,500 to 17,500. It
appears to be dry enough that only isolated thunderstorms will form in
the normal "hot spots". Early trigger times also.
I reviewed Dr Jack this afternoon with a long ago crew of mine, John
Halcrow. For Crystalaire, the pattern on Friday looks as good as I've
ever seen it. BL (thermal) max heights 17,500msl (of course cloud
bases will limit altitudes to a little lower).
I'm coming back out Saturday to give my 750 km triangle another try
from Inyokern (please... leave me room for an 11:30am takeoff
Walt Rogers, WX
Old August 26th 11, 06:08 AM posted to rec.aviation.soaring
gen
Just FYI in case you plan to head north, Minden airport will be closed for airshow from Friday noon through Sunday. There will be TFR around airport, too.
-Gen
Old August 26th 11, 07:51 AM posted to rec.aviation.soaring
Ramy
Default Outstanding Soaring: California Mojave, Owens Valley, Western NV- Fri-Sun 08/26-28
Outstanding soaring weather Fri through Sun. *Lift rates 700-800fpm
It's a toss up between Fri and Sunday. *The Mojave Desert, Owens
the normal "hot spots". *Early trigger times also.
Halcrow. *For Crystalaire, the pattern on Friday looks as good as I've
ever seen it. *BL (thermal) max heights 17,500msl (of course cloud
Walt Rogers, WX
I don't see the same outstanding conditions when reviewing the NAM
blipmap, especially for going north towards Minden. Bases only 15-16K,
lots of moisture with potential for overcast and OD and stronger wind
to the north. Could still be good but probably not as good as it was
the last few days.
Ramy
Old August 26th 11, 04:35 PM posted to rec.aviation.soaring
WaltWX[_2_]
Ramy,
I agree with your assessment. My focus for the good weather is aimed
at the Owens Valley, and Mojave Deserts (south of Bridgeport). More
moisture spreading over entire area on Saturday with cloud bases
15,000-16,000 north of Bishop instead of 17,000msl. Widely scattered
TS in the usual hot spots but the cells should be fairly small and
short lived. Sunday, as Alex pointed out below, looks a little drier
everywhere... still at least a very good to outstanding day.
Walt, Wx
Halcrow. *For Crystalaire, the pattern on Friday looks as good as I'v ever seen it. *BL (thermal) max heights 17,500msl (of course cloud
Walt Rogers, WX
the last few days.
Ramy
Old August 26th 11, 09:39 PM posted to rec.aviation.soaring
JS
From 34000' over the Coaldale route into SFO, the Monitors, Diamonds
and Rubys looked like a drag strip at 1145AM Friday.
East of there looked pretty overcast.
At Huntoon Dry Lake (SE of Hilton) there were four rows of lennies.
Old August 26th 11, 11:04 PM posted to rec.aviation.soaring
Ramy
On Aug 26, 8:35*am, WaltWX wrote:
Ramy,
at the Owens Valley, and Mojave Deserts (south of Bridgeport). *More
short lived. *Sunday, as Alex pointed out below, looks a little drier
Walt, Wx
Walt Rogers, WX
the last few days.
Ramy- Hide quoted text -
- Show quoted text -
One little known secret of Dr Jack Blipmap is the "Total Cloud Cover"
parameter. This is one of the most reliable parameters I've seen to
detect overcast. If there are white areas you are pretty much
guarantee that there will be at least some level of overcast. It does
not tell if it will be high cirrus or mid level overcast, and how
thick it will be, nor if it will be persistent or short lived. But it
hardly ever fails to detect that there will be some degree of overcast
in the area. It indicated successfully today pockets of overcast
especially in the southern zones of region 11 and 12, and more so
tomorrow over the central Sierra. None for Sunday.
For those who prefer looking at the RASP, besides the Avenal one,
there is one which covers the whole Sierra:
http://www.norcalsoaring.org/BLIP/SIERRA/index.html
It has 'BL Cloud Cover' but I did not use it enough to confirm if it
provides the same as the NAM Total Cloud Cover.
Ramy
Old August 27th 11, 12:58 AM posted to rec.aviation.soaring
Alex[_5_]
Ramy,
Walt, Wx
Walt Rogers, WX
the last few days.
in the area. It indicated *successfully today pockets of overcast
there is one which covers the whole Sierra:http://www.norcalsoaring.org/BLIP/SIERRA/index.html
Ramy
Also on the Dr. Jack RASP sites, if the operator has set up locations
for plotting forecast
soundings as Skew-T diagrams, you can see on the left side of these
diagrams
black lines corresponding to forecast cloud layers. These try to
forecast both the heights and thicknesses of cloud layers. These
include cloud layers that
are above the "boundary layer" that most of the blipmap diagrams
concern themselves with, such as high cirrus layers. If there is
also a similar layer marked in green over on the left side
representing "cloud water in g/k", that seems to correspond with the
chance of
precipitation. An example of this could be seen today on some of the
soundings from the Avenal RASP, such as this one:
http://alcald.homelinux.org//RASP/AV...1400lst.d2.png
Alex Caldwell
Old August 28th 11, 02:19 AM posted to rec.aviation.soaring
Mike the Strike
Ramy,
Walt, Wx
Walt Rogers, WX
the last few days.
Ramy
soundings as *Skew-T diagrams, *you can see on the left side of these
diagrams
black lines corresponding to forecast cloud layers. *These *try to
forecast both the heights and thicknesses *of cloud layers. * *These
include *cloud layers that
concern themselves with, *such as high cirrus layers. * *If there is
representing *"cloud water in g/k", that seems to correspond with the
chance of
precipitation. * An example of this could be seen today on some of the
http://alcald.homelinux.org//RASP/AV...8.curr.1400lst...
Alex Caldwell
Rapid Refresh plots have this and more and are a lot more accurate
than RUC or NAM based Blipmaps. It'll be nice when RR goes online and
replaces RUC.
Mike
Old August 26th 11, 04:01 PM posted to rec.aviation.soaring
Alex[_5_]
Walt Rogers, WX
Walt,
I ran a 4KM resolution RASP last night for AVENAL that goes 2 days
out. It is centered on AVENAL, but covers the
high desert area around Edwards and the S. Sierra and Owens Valley up
to N. of Mono Lake. If I'm interpreting
it right (which is highly open to question), it's saying Friday and
Saturday, there should be good cumulus in the desert area in Region
12, but it should be drying out in Region 12 by Sunday. On Sunday,
the better cumulus will be more up North in Region 11. On Friday,
there may be some higher level overcast from subtropical moisture
coming in from the SW with some chance of OD along the coast range
near Castle Peak and New Cuyama and over the S. part of the Sierras.
The higher level overcast shows up on the Skew-T sounding forecasts on
the RASP, but not on the regular blipmaps. This should be gone on
Saturday and Sunday. Would be interested in what you think about it.
Also any pilot reports after the weekend is over would be interesting
to hear to correlate with the forecast.
http://alcald.homelinux.org/RASP/AVE...RASPtable.html
Alex Caldwell
Central Calif. Soaring Club
Avenal, CA, USA
Old September 2nd 11, 09:55 PM posted to rec.aviation.soaring
Ramy
Default Outstanding Soaring: California Mojave, Owens Valley, Western NV- Labor Day Weekend
Walt Rogers, WX
Walt,
12, *but it should *be drying out in Region 12 by *Sunday. *On Sunday,
the better cumulus will be more up North in Region 11. *On Friday,
the RASP, *but not on the regular blipmaps. *This should be gone on
Saturday and Sunday. *Would be interested in what you think about it.
Alex Caldwell
Avenal, CA, USA- Hide quoted text -
Well the forecast for this labor day weekend looks epic for the
Sierras, much better than last weekend. High base cu along the whole
length of the sierra on Saturday and accross the Great Basin as well
on Sunday. Monday should be similar.
California Sierras /Western Mojave: Good to Great Soaring weatherWed-Fri 08/19 to 08/21 WaltWX Soaring 4 August 19th 09 04:45 AM
R2505 restricted airspace...Owens valley. fredsez Soaring 1 September 23rd 08 06:00 AM
R2505 restricted airspace...Owens valley. fredsez Soaring 0 September 23rd 08 05:22 AM
Soaring in Owens Valley Tuno Soaring 8 August 24th 07 01:33 PM
Owens Valley E. Douglas Whitehead Soaring 1 August 21st 07 05:44 AM
