why are you asking rules for Customs here... you are asking about Customs
requirements.. not flying related.. if you are passing through and not landing.. not a problem... if you are landing.. you must first land at a "port of entry" airport in either direction... and when you are coming from Canada to US.. you must provide at least one hours notice and arrive within xx minutes of your ETA.. and there are other rules... you need to be talking to US Customs office to get your answer.. and then contact the Customs office at the airports you will be using to get their slant on it. BT "O. Sami Saydjari" wrote in message ... I expect this question has been asked many times here....but here goes. Exactly what, if anything, do I need if I want to fly into Canada? Does the answer change if I want to land in Canada or if I am just flying through their airspace? I expect to be on an IFR flight plan, so I will already have a squawk code...if that helps. The last time I contacted FSS, I got different answers everytime I asked. I read on a previous thread that perhaps I need a radiotelephone operators license, but that nobody will actually check for it. is that right? If I want to land in Canada, do I have to first land in some designated port of entry to be inspected in some way? Do I have to land at some U.S. inspection point on the way back to the U.S.? Just to be concrete, I am flying from central Wisconsin to Maine this weekend. I will likely fly over Canadian airspace. Then, when I get there, I am considering a trip up to the Saint John/Bay of Fundy area. If anyone knows a good airport up there, I would appreciate a pointer. Thanks in advance! -Sami N2057M, Piper Turbo Arrow III |
![]() On 15-Mar-2004, "O. Sami Saydjari" wrote: Exactly what, if anything, do I need if I want to fly into Canada? Does the answer change if I want to land in Canada or if I am just flying through their airspace? I expect to be on an IFR flight plan, so I will already have a squawk code...if that helps. First of all, the simple stuff. Discrete transponder codes are required for cross-border VFR flights, but, as you correctly surmise, if you are IFR that is not an issue. If you are just flying over Canadian airspace and not landing in Canada, customs is also not an issue. However, if you use Canadian ATC services (which are semi-privatized), you will later receive a bill for a few bucks, payable by credit card. If you want to land in Canada, you need to do so first at an airport of entry, i.e. one with customs service. Canadian customs is really fairly simple. Before departing the US (at least 1 hour in advance) call Canadian customs at 1-888-226-7277 (888-CANPASS) to advise them of your intentions. They will want to know stuff like the aircraft number, point of departure, airport of arrival, ETA, number and nationality of occupants, etc. When filing your US flight plan, under "comments" note that you will require customs service. (This really doesn't do anything, but it's apparently still in the regs.) When you arrive at the Canadian destination, ask ground control for taxi to customs. (At uncontrolled fields, there should be signs.) How customs is handled from that point seems to vary by location, but the process is fairly painless and free. I strongly recommend that you bring passports for all aboard -- not STRICTLY required for US citizens, but makes things much easier. Customs will give you a registration number that you should write down and keep in the airplane. This provides evidence of clearance if any issues arise. Unfortunately, returning to the US is not nearly as simple. First of all, you have to alert US customs in advance where and when you will be arriving. It has to be an airport of entry, but such a designation does not mean that customs service will be there, even during normal business hours. Furthermore, unlike Canadian customs, there is no central number to call. Instead, you have to call the customs office at the airport you intend to land at and negotiate a time of arrival. What's the phone number for that customs office? You would think that the US Customs service would make that information available online, but I've never found it. Fortunately, AOPA members can find a complete listing at http://www.aopa.org/members/files/guides/custaprt.html. This calling ahead can sometimes be challenging because, as I noted, the customs offices at smaller airports are often unmanned. Then, you need to arrive precisely at the negotiated time, give or take a few minutes, to assure that the customs agent will be there. File a Canadian flight plan, and be sure to check the "ADCUS" (advise customs) box. When you arrive for US Customs inspection, you will have to fill our two lengthy forms. Customs charges an annual $25 fee for each airplane, for which you get a very ugly decal that you are supposed to plaster on the outside of your airplane near the passenger door. If you don't have the decal, the customs agent will collect the $25 and you will be sent the decal by mail for any future (same year) use. The bill for Canadian ATC services will come some time later. For light aircraft, the charges will typically be around US$13 or so. -- -Elliott Drucker |
Documentation:
From the EAA: "The US and Canada have agreed not to require US or Canadian pilots to have a restricted radio-telephone license or an Aircraft Radio Station License." http://members.eaa.org/home/homebuil...0Aircraft.html From AOPA: The AOPA/COPA Guide to Cross-Border Operations (United States/Canada) - Arrival Requirements: http://www.aopa.org/members/files/tr...ada/can02.html Aircraft Documentation Aircraft registration certificate (temporary "pink slip" registration forms are not valid for international flights); Aircraft airworthiness certificate (for aircraft with a C of A); Aircraft operating limitations (including the "Standardized Validation of a Special Airworthiness Certificate - Experimental, for the Purpose of Operating a United States-Registered Amateur-Built Aircraft in Canadian Airspace); Weight and balance information; FAA 337 form when the aircraft has been fitted with extra fuel tanks in the baggage or passenger compartments. Don |
Mountain flying instruction: McCall, Idaho, Colorado too! | [email protected] | General Aviation | 0 | March 26th 04 11:24 PM |
Progress on Flying Car | Steve Dufour | General Aviation | 5 | December 19th 03 03:48 PM |
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 12:07 AM |
French block airlift of British troops to Basra | Michael Petukhov | Military Aviation | 202 | October 24th 03 06:48 PM |
Flying from US to Canada | Aarfy | Owning | 8 | July 22nd 03 06:13 AM |
