Radio Removal
Old March 19th 04, 05:18 PM
MRQB
Default Radio Removal
Hello, i would like to know how to remove the Cessna ARC NAV/COM 300 radio
out of my 150? Ware are the screws bolts ect located? So I can take it in to
be serviced or replaced it with a slide in replacement. I here it is simple
to remove it, is it?
Old March 20th 04, 03:27 AM
Kyle Boatright
In general there will be a hole in the face of the radio where you insert an
allen wrench. Turn the screw clockwise to release the radio.
"MRQB" wrote in message
to
simple
Old March 20th 04, 01:46 PM
Jay Honeck
an
On my radios I've turned them counter-clockwise to release them.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 20th 04, 07:57 PM
Kyle Boatright
"Jay Honeck" wrote in message
news:tWX6c.47246$1p.751674@attbi_s54...
insert
an
Jay Honeck
Iowa City, IA
Pathfinder N56993
Absolutely correct. Amazing that the fingers don't always type what the
mind intends..
Old March 20th 04, 10:43 PM
Don Tuite
On Sat, 20 Mar 2004 14:57:25 -0500, "Kyle Boatright"
insert
an
Jay Honeck
Iowa City, IA
Pathfinder N56993
mind intends..
There's another setup where you have to poke down the hole with a
long rod and push to disengage a spring latch. I can't remember what
that was on -- an audio panel, maybe?
Don
Old March 21st 04, 12:03 AM
G.R. Patterson III
NARCO Mk12-D. One catch on each side, so you need two rods.
George Patterson
Battle, n; A method of untying with the teeth a political knot that would
not yield to the tongue.
Old March 21st 04, 06:20 AM
MRQB
I found the screw it was right in the center lower part of the radio below
ware it said RT 308 it was not deep inside it was really close to the
surface unless it was the wrong screw I turned it it did nothing it would
just spin either direction there was a really smaller hole next to it. Is it
broken? or was i on the wrong screw?
"Kyle Boatright" wrote in message
an
radio
in
to
simple
Old March 21st 04, 01:52 PM
Jay Honeck
it
Are you sure it's a screw you're trying to turn? Our radios require an
allen wrench to remove.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old March 21st 04, 03:57 PM
G.R. Patterson III
Do you have ARC equipment, Jay?
I didn't think so.
George Patterson
Old March 22nd 04, 03:39 AM
John
You have the correct screw. It requires a short 1/8 inch flat blade
screw driver. However it is the cam lock screw. It does not push the
radio out. Clockwise to lock and counter clockwise two or three turns
to unlock. Generally you can feel the lock disengage. When
unlocked you must grab two of the larger knobs then shake while
pulling to remove the RT-308. The very small hole is for the VOR
centering adjustment.
Some of the other ARC radios require a 12 inch long flat blade screw
driver.
an
radio
in
to
simple
(sorta OT) Free Ham Radio Course RST Engineering Home Built 51 January 24th 05 08:05 PM
Good panel mount COM radio and intercom w/push-to-talk? John Huebbe Home Built 10 November 27th 04 07:58 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Radio silence, Market Garden and death at Arnhem ArtKramr Military Aviation 4 February 12th 04 12:05 AM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
