The airplane I just bought gave me a nice little surprise went out to do my
pre flight and noticed that my right rudder cable had some slop in it I did not feel comfortable flying it with the lack of tension on it so the mechanic is going to look at it tomorrow. Also what holds tension on the rudder cables? I know the cost of a new cable is only $80.00 + labor. Is there any source on the net ware I can find out how the cable system works on a later model Cessna 150M kinda curious and would like to know my airplane inside and out. Ware do I find me a factory service manual? I want to learn every thing about this little 150. |
![]() "MRQB" wrote in message ... The airplane I just bought gave me a nice little surprise went out to do my pre flight and noticed that my right rudder cable had some slop in it I did not feel comfortable flying it with the lack of tension on it so the mechanic is going to look at it tomorrow. Also what holds tension on the rudder cables? I know the cost of a new cable is only $80.00 + labor. Is there any source on the net ware I can find out how the cable system works on a later model Cessna 150M kinda curious and would like to know my airplane inside and out. Ware do I find me a factory service manual? I want to learn every thing about this little 150. You can get a factory service manual from www.esscoaircraft.com. It will cost you about $40, but it is well worth it. Every aircraft owner should keep a copy of the maintenance manual. Maintenance manuals for newer aircraft are a lot more expensive. |
"C J Campbell" writes:
Maintenance manuals for newer aircraft are a lot more expensive. I got a printed manual for free with my SR20, and a CD-ROM version for free (arguably preferable for my purposes) when I upgraded to an SR22. |
Dave Katz wrote:
"C J Campbell" writes: Maintenance manuals for newer aircraft are a lot more expensive. I got a printed manual for free with my SR20, and a CD-ROM version for free (arguably preferable for my purposes) when I upgraded to an SR22. For the cost of a Cirrus, you *should* get all the books and stuff for free!!! |
was the nosewheel turned to the right from when you parked it? allowing the
right cable to "appear slack"? just a thought.. BT "MRQB" wrote in message ... The airplane I just bought gave me a nice little surprise went out to do my pre flight and noticed that my right rudder cable had some slop in it I did not feel comfortable flying it with the lack of tension on it so the mechanic is going to look at it tomorrow. Also what holds tension on the rudder cables? I know the cost of a new cable is only $80.00 + labor. Is there any source on the net ware I can find out how the cable system works on a later model Cessna 150M kinda curious and would like to know my airplane inside and out. Ware do I find me a factory service manual? I want to learn every thing about this little 150. |
I will go and check that before it goes in to the mechanic but I am still
going to have the cables checked out I may just have both cables replaced anyway so that I know what is in there cables are scary to me I already have a screw in my wrist because of a faulty cable on a Motorcycle. "BTIZ" wrote in message news:UIu7c.22078$Nj.6936@fed1read01... was the nosewheel turned to the right from when you parked it? allowing the right cable to "appear slack"? just a thought.. BT "MRQB" wrote in message ... The airplane I just bought gave me a nice little surprise went out to do my pre flight and noticed that my right rudder cable had some slop in it I did not feel comfortable flying it with the lack of tension on it so the mechanic is going to look at it tomorrow. Also what holds tension on the rudder cables? I know the cost of a new cable is only $80.00 + labor. Is there any source on the net ware I can find out how the cable system works on a later model Cessna 150M kinda curious and would like to know my airplane inside and out. Ware do I find me a factory service manual? I want to learn every thing about this little 150. |
"MRQB" wrote: I will go and check that before it goes in to the mechanic but I am still going to have the cables checked out I may just have both cables replaced anyway so that I know what is in there cables are scary to me I already have a screw in my wrist because of a faulty cable on a Motorcycle. Pull the rear bulkhead out behind the baggage area. You'll be able to see down the fuselage to the tail and can check the rudder and elevator cables (as well as your ELT). If you decide to crawl back in the fuselage be sure to support the tail before you do. (The wife will never do THAT again G). You can also pull the carpets out and remove the inspection panels in the floor exposing some of the control cables/pulleys/etc. You'll need a light and a mirror...and the maintenance manual would be a good idea so you have a "map" of where everything is. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Dale wrote: the floor exposing some of the control cables/pulleys/etc. You'll need a light and a mirror...and the maintenance manual would be a good idea so you have a "map" of where everything is. Don't overlook the parts manual, even if you never expect to buy parts. The exploded drawings are often more detailed than the illustrations in the service manual. -- Ben Jackson http://www.ben.com/ |
"MRQB" wrote: Also what holds tension on the rudder cables? A spring. Those springs sometimes break. If the spring is broken the pedal will be "loose"...no resistance. When you move the pedals on the ground the resistance you feel is from the springs. Control cables are low cost but the labor is going to be rather high. It's a lot of work replacing control cables. -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
The airplane I just bought gave me a nice little surprise went out to do my pre flight and noticed that my right rudder cable had some slop in it I did not feel comfortable flying it with the lack of tension on it so the mechanic is going to look at it tomorrow. Also what holds tension on the rudder cables? I know the cost of a new cable is only $80.00 + labor. Is there any source on the net ware I can find out how the cable system works on a later model Cessna 150M kinda curious and would like to know my airplane inside and out. Ware do I find me a factory service manual? I want to learn every thing about this little 150. Every 150 I ever flew seems to have a lot of "slop" in the rudder cables when sitting on the ground. It's usually due to the way the nosewheel steering is spring-linked to the rudder controls, and the nosewheel not being centered when the plane was parked. Twist the nosewheel so it's pointing straight ahead and see if your "slop" disappears. Even our 172 does this, but the phenominon doesn't seem so pronounced as on the 150. |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
How I got to Oshkosh (long) | Doug | Owning | 2 | August 18th 03 12:05 AM |
