fuselage dolly caster
Old September 9th 11, 03:40 PM posted to rec.aviation.soaring
Brad[_2_]
Default fuselage dolly caster
I need to make a tail dolly for the HP-24, am looking for a place to
get a castering wheel like I see on the factory made tail dolly's.
Anyone have some ideas?
thanks,
Brad
Old September 9th 11, 03:50 PM posted to rec.aviation.soaring
Tony[_5_]
thanks,
Brad
http://www.mcmaster.com/#pneumatic-w...asters/=dzke11
Old September 9th 11, 04:52 PM posted to rec.aviation.soaring
Bill D
thanks,
Brad
McMaster Carr is good. E-bay and Amazon are also a sources and
sometimes less expensive.
While designing your hangar dolly, take a look at the clever jackable
fuselage trailer dollies used on fixed gear 2-seaters. Replacing the
trailer dolly's straight-rolling wheels with casters would make a very
easy to use hangar dolly since you wouldn't have to push the glider up
onto a freely castering dolly.
Old September 10th 11, 12:35 AM posted to rec.aviation.soaring
Bruce Hoult
fuselage trailer dollies used on fixed gear 2-seaters. *Replacing the
Some pics I took of the one that came with our DG1000 trailer.
http://www.flickr.com/photos/bruceho...00clubtrolley/
Old September 10th 11, 02:48 AM posted to rec.aviation.soaring
Brad[_2_]
thanks for all the suggestions and link guys...............much
appreciated. ended up with a Harbor Fraud unit, 6" semi-solid tire,
under $20.00. also ordered a bunch of stuff from M&C for the wing
wheel dolly, the nose capture bowl and the control system circuit.
Brad
Old September 9th 11, 04:42 PM posted to rec.aviation.soaring
MN50
thanks,
Brad
Northwest Caster and Equipment.
On Aurora Ave. north of the Aurora bridge in Seattle.
Don't say its for aircraft or ground support equipment. You may get
some hesitation.
I got a caster with a pnuematic wheel there. Tire was chinese, and
its 15 yrs old now.
Good for the cracks in the ramp at EPH. Never had a leak.
Old September 9th 11, 05:16 PM posted to rec.aviation.soaring
Craig Funston
thanks,
Brad
Don't say its for aircraft or ground support equipment. *You may get
some hesitation.
I got a caster with a pnuematic wheel there. *Tire was chinese, and
its 15 yrs old now.
Good for the cracks in the ramp at EPH. *Never had a leak.
Grizzly
http://www.grizzly.com/products/10-P...vel-Tire/G7078
Craig
Old September 9th 11, 07:31 PM posted to rec.aviation.soaring
Cliff Hilty[_4_]
harbor Freight tools $ 18
At 16:16 09 September 2011, Craig Funston wrote:
On Sep 9, 8:42=A0am, MN50 wrote:
On Sep 9, 7:50=A0am, Tony wrote:
to
thanks,
Brad
http://www.mcmaster.com/#pneumatic-w...ters/=3Ddzke11
Don't say its for aircraft or ground support equipment. =A0You may get
some hesitation.
I got a caster with a pnuematic wheel there. =A0Tire was chinese, and
its 15 yrs old now.
Good for the cracks in the ramp at EPH. =A0Never had a leak.
Grizzly
Craig
Old September 9th 11, 08:21 PM posted to rec.aviation.soaring
Mike[_37_]
thanks,
Brad
http://www.harborfreight.com/8-inch-...ake-46819.html
Old September 9th 11, 09:55 PM posted to rec.aviation.soaring
Bob Kuykendall
On Sep 9, 12:21*pm, Mike wrote:
http://www.harborfreight.com/8-inch-...-caster-with-b...
I'd go with either the 8" or 10" pneumatic casters, myself:
http://www.harborfreight.com/8-inch-...ter-42485.html
http://www.harborfreight.com/10-inch...ter-38944.html
Thanks, Bob K.
ASK-21 fuselage dolly bildan Soaring 8 August 1st 10 05:43 PM
LS4 tail dolly Leigh Soaring 0 May 30th 08 02:02 AM
WTB: used tail dolly David Campbell Soaring 5 April 17th 06 03:19 PM
assembly dolly Udo Rumpf Soaring 0 April 29th 05 04:17 PM
L-23 tail dolly Mark Zivley Soaring 1 November 27th 04 11:16 AM
