connecting bendix-king 94 gps unit to a pc
Old March 31st 04, 06:31 PM
Baron Man
Default connecting bendix-king 94 gps unit to a pc
anyone done this...avionics guy says it outputs
nmea over rs232.
any special software needed?
Old March 31st 04, 08:24 PM
mikem
Most GPSes have an NMEA RS232 output; all mine do.
Wire GPS_Data_Out to Pin 2 of your computer Serial Port.
Wire GPS_Ground to Pin 5 " " " " "
Fire up HyperTerm, establish a "connection" to the
appropriate Com port using 4800,N,8,1 (it might be
9600,N,8,1?).
Everything the GPS sends will print on the screen.
You can capture it in a file, if you want.
Google for "NMEA sentences" if you want more info
about what is printed.
MikeM
nmea over rs232.
GWB and the Air Guard JD Military Aviation 77 March 17th 04 10:52 AM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
value of Bendix / King klx100 mah Aviation Marketplace 1 December 19th 03 03:19 AM
Bendix King GPS Updates Matthew Waugh Instrument Flight Rules 1 August 5th 03 06:11 PM
Bendix King GPS Updates Matthew Waugh Owning 1 August 5th 03 06:11 PM
