Time Measurement for Inspections
Old April 2nd 04, 08:39 PM
O. Sami Saydjari
Default Time Measurement for Inspections
OK, dumb question. For 100-hour inspections (or 50 hours until oil
change), is this measured in Hobbs time or Tach time?
-Sami
N2057M, Piper Turbo Arrow III
Old April 2nd 04, 08:54 PM
Dennis O'Connor
The tach is the instrument for measuring engine hours...
denny
"O. Sami Saydjari" wrote in message
-Sami
Old April 5th 04, 04:54 PM
Ron Natalie
"Dennis O'Connor" wrote in message ...
Not necessarily. The FAA just wants a consistent reasonably accurate way of
recording time in service. Some aircraft, like late model Bonanza's (and now my
Navion) don't even have a recording tach (no tach time at all). We use the elapsed
time meter (hobbs).
Old April 5th 04, 09:13 PM
Tom Sixkiller
"Ron Natalie" wrote in message
m...
of
now my
the elapsed
time meter (hobbs).
What do you consider "late model Bonanza"? Every one I've looked at (from
1987 onward until they stopped making them in 1994 has one (at least in the
F33A model).
Guessing that Hobbs time is 25% higher than Tach time, I'd put a recording
tach in if it didn't have one already.
Old April 6th 04, 03:03 AM
JDupre5762
F33A model).
How about a 2003 model A36? I service a 1998 A36 and it has no recording tach
only a hobbs meter. All the engine instruments have been reduced to about 1.5"
diameter dials, no room for a tach counter.
John Dupre'
Old April 6th 04, 04:19 PM
Ron Natalie
"JDupre5762" wrote in message ...
F33A model).
Yep, that's the ticket. My Navion now has the prop, engine, and engine instruments from
a 2003 A36. Got it with 9 hours total (just enough time to get it from Kansas down to
the conversion shop to put the turboprop on). My old tach wouldn't have worked anyhow.
It was set up for the old Gopher-35 engine which cruises at 2800 RPM. The hours on the
tach weren't the total time anyhow (not the original tach, had to add something like 4000 hours
to the value).
Old April 2nd 04, 08:57 PM
G.R. Patterson III
Everyone I know uses whichever gives them the longest period between inspections.
This is usually tach time, but I know a few people who have wired a Hobbs to the
squat switch on a retract so that they can schedule maintenance based on time spent
in the air.
Me, I use calendar time, since I never log over 50 hours in a 4 month period and have
annual inspections, rather than 100 hour.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Old April 2nd 04, 10:39 PM
Jim Weir
Not a dumb question at all. You can use a sand hourglass if you want, just so
long as you use the same method all the time. That is, use hobbs OR tach OR
wris****ch, just be consistent.
No, the regs do not REQUIRE you to use the same method every time, but you'll
play hell explaining your method to the FAA if they come a'snoopin'.
"O. Sami Saydjari"
-OK, dumb question. For 100-hour inspections (or 50 hours until oil
-change), is this measured in Hobbs time or Tach time?
--Sami
-N2057M, Piper Turbo Arrow III
http://www.rst-engr.com
Old April 2nd 04, 10:44 PM
Rich
Technically, neither...
In Part I, Definitions,
"Time in Service, with respect to maintenance time records, means the
time from the moment an aircraft leaves the surface of the earth until
it touches it at the next point of landing."
As a practical matter, for Part 91 operations, I've never heard of
anybody using anything but tach time.
Rich
-Sami
Old April 4th 04, 02:24 AM
kage
There is no tach on a jet. Lots of part 91 operations.
Karl
"Rich" wrote in message
Rich
-Sami
American nazi pond scum, version two bushite kills bushite Naval Aviation 0 December 21st 04 10:46 PM
FS: 2002 "Ghosts: A Time Remembered" (Aviation) Calendar J.R. Sinclair Aviation Marketplace 0 June 14th 04 06:22 AM
FS: 1990 Cracker Jack "War Time Airplanes" Minis 6-Card (CJR-3) Set J.R. Sinclair Aviation Marketplace 0 April 12th 04 05:57 AM
It's that time of year again. Capt. Doug Home Built 19 September 3rd 03 10:53 PM
