Tossing factory EGT, replacing with JPI or similar
Old April 5th 04, 02:03 AM
Ben Jackson
Default Tossing factory EGT, replacing with JPI or similar
I understand that if I had a CHT, and it had a redline (I don't have one
at all, probably because the PA-24 doesn't have cowl flaps) I would need
to keep my CHT or get something certified to be a primary CHT.
Are there any rules regarding EGT? The one I have is pretty useless. It's
an analog gauge that displays only relative EGT (it's marked in 100s of
degrees F, and a thumbwheel lets you adjust the position of the indicating
needle). I'd just leave it, except it's a 2.25" instrument right where
I'd like to put the digital replacement.
Ben Jackson
http://www.ben.com/
Old April 5th 04, 02:13 AM
Tom Sixkiller
"Ben Jackson" wrote in message
news:Xm1cc.181337$1p.2150841@attbi_s54...
It's
Lycoming IO-540, right?
Definitely the EDM-700. http://jpinstruments.com/edm_700.html along with a
set of GAMIjectors.
You can probably get one cheaper, but not likely _better_.
Old April 5th 04, 03:41 AM
Ben Jackson
set of GAMIjectors.
That's what I'm thinking, or possibly an EDM-800. I'd like to have
MP/RPM because the primary gauges for those are wayyy out of my scan.
Right now I'm trying to figure out if I can put it where I want: Right
where the stock EGT is now.
Ben Jackson
http://www.ben.com/
Old April 5th 04, 03:57 AM
Jay Honeck
The 800 looks cool. We've got the 700, and upon installation it rapidly
became a primary flight instrument.
We use it for leaning, we use it for diagnosis, we use it for early warning,
and we use it for peace of mind. It's a wonderful tool.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old April 5th 04, 04:02 AM
Tom Sixkiller
news:7P2cc.76725$JO3.41027@attbi_s04...
a
set of GAMIjectors.
That's usually where they go. I'd suspect that (??) some of the wiring would
already be in place.
How about the GAMI's?
Old April 5th 04, 04:33 AM
Ben Jackson
I don't think I'd want to re-use one mis-matched EGT probe with the other
five. I dug up a picture of a 'stock' 260 panel (mine is far from stock
on the left side) and lo and behold, no EGT at all. My EGT is where the
stock suction gauge was.
I need the multi-channel EGT to know if I need those!
Ben Jackson
http://www.ben.com/
Old April 5th 04, 07:54 AM
Tom Sixkiller
news:eA3cc.182477$1p.2161124@attbi_s54...
would
I wasn't thinking of the probe wires, but now that you mention it that's
makes sense.
In a Bonanza, it fits into the standard EGT readout slot.
(Oh believe me, if you have Fuel Injection, you NEED them. :~)
From what I gather, you can't get a proper reading from a multi-channel EG
with stock injectors. Check of John Deakin's articles in AvWeb about that.
What's more, better CHT's, fuel savings, SMOOTHER running...
Tom
Life is not a journey to the grave with the intention of arriving
safely in a pretty and well preserved body, but rather to skid
in broadside, thoroughly used up, totally worn out, and loudly
proclaiming - - WOW - - WHAT A RIDE!"
Old April 5th 04, 05:18 AM
G.R. Patterson III
My aircraft has a list of mandatory (AKA "standard") equipment and a list of optional
equipment. If you can get the same lists for your aircraft, and if the EGT is not
listed as mandatory equipment, it can be removed.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Replacing Generator with Alternator Thomas Ploch Owning 2 October 11th 03 04:36 AM
