172 Nosewheel Struts Leak Nitrogen
Old April 8th 04, 04:03 PM
jls
Default 172 Nosewheel Struts Leak Nitrogen
I rebuilt one and the best A&P on the field rebuilt the other one, on 1966
and 1957 172's. Neither will hold nitrogen. What's the secret to getting
them not to leak.
I bought a complete O-ring kit from Trimcraft in Wisconsin. My personal
A&P told me that only one or two large O-rings were leak-prone and crucial
for replacement so I replaced those only, at his urging. Now I think I'll
install the complete kit, which includes at least 6 O-rings. How about it
A&P's who are Cessna savvy? What's the trick here to getting these struts
to stay up and not leak nitrogen? I know they are not leaking around the
Shrader valves. I have done too much testing with soap suds looking for a
bubble to emerge. Besides, both of the Shrader valves and the valve stems
have been replaced and are official Cessna parts.
The flight school A&P on the field says some of the struts just have to be
re-gassed with nitrogen occasionally, but that's not a satisfactory answer,
far as any owner would be concerned.
Thanks in advance for any good advice you can give on this frustrating
problem.
Old April 8th 04, 10:12 PM
MikeM
them not to leak.
problem.
If its leaking around the lower O rings, then oil would be forced out.
As long as there is any oil in the strut, then it will be forced out
first (unless the airplane is laying on its back!) before nitrogen begins
to leak.
The only place nitrogen can leak is at the top, around the Schrader valve
or through it. Another possibility is a leak around the plug/metering
rod at the top (inside) of the strut tube. In this case, the nitrogen would
be leaking down the tube, and exiting through the hole in the fork.
MikeM
Old April 9th 04, 01:01 AM
Dan Thomas
" jls" wrote in message .. .
them not to leak.
problem.
The top of the oleo has a slug with an O-ring on it; the same piece
that has the valve screwed into it. The slug is retained by the
through-bolt that attaches the oleo to the firewall bracket. The
O-ring will deteriorate and leak, and when it's replaced it can get
cut on the edges of the bolt hole as the slug is reinserted. If only
nitrogen is escaping, it's this O-ring or the valve.
Dan
Old April 9th 04, 01:55 AM
JDupre5762
getting
them not to leak.
it
problem.
Dan
Dan is right. Lots of mechanics forget or don't know about the upper o ring on
the Cessna types. In most typical flight school operations it is the lower o
rings 9 times out of ten that fail. But on that tenth time it is the upper o
ring. I have found some that were original from the days when they used to
color code o rings with a dot of colored paint. Most often too that o ring has
worn to a square profile too. Somebody's A&P doesn't know all that he should,
but then who does?
John Dupre'
Old April 9th 04, 06:28 PM
Martin Kosina
the Cessna types.
Same experience here, turned out to be the upper, oft neglected
o-ring. Also inspect the inflation valve, those can slowly leak if
they have never been replaced.
~ DICK GRILLED FOR CIA LEAK - CAN YOU SAY PRISON?! ~ ~ THE CHOKING CHIMP ~ Military Aviation 0 June 6th 04 05:34 AM
Pazmany PL2 strut leak moni nut Home Built 1 April 27th 04 02:24 AM
Nosewheel Shimmy and Scalloped Tire Redux, Plus Larry Smith Home Built 2 September 15th 03 04:03 PM
