Under the supervision of my IA, we installed a vor radio. I connected
the vor audio output to one of the Aud-Audio inputs on the RT328D, thinking this would supply audio to the intercom (connected to the RT328 phone output) and the speaker. The VOR radio output only appears to go to the speaker (via RT328D). I expected these aux-audio to go to the rt328 phone output, but that doesn't appear to be the case. I guess I need to get an rt328 instruction manual or schematics to determine the function of the aux-audio inputs. Any help would is greatly appreciated. Mitch |
Thanks for your input John. The plane does not have an audio panel,
and uses a 2 place portable intercom. The RT328 Phone output is tied back to an auxilary input to get to the speaker amp. I think I'll connect the VOR2 audio to the 328 phone output through 100ohm resister. This will feed it to the headset and the speaker output, and avoid loading of the outputs. We will use the volume controls in lieu of audio panel switches. Mitch (John) wrote in message You are correct. The Aux inputs go directly to the 328 speaker amplifier. If you do not have all of the switch positions on the audio panel filled you can add a PCB mount switch to the audio panel to switch in your new audio source. This is what I did for my 2m ham radio that I installed in my Cessna. The only place I have found the schematic for the audio panel is in the "74 through 76 avionic installations' manual. |
| 1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 04:40 PM |
| Cessna buyers in So. Cal. beware ! | Bill Berle | Aviation Marketplace | 93 | December 20th 04 03:17 PM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 01:57 AM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Owning | 1 | November 4th 03 01:57 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
