I think you will find the nico-press sleeves for aircraft are STEEL,not aluminum.
Bob Olds Charleston,Arkansas |
"Bob Olds" wrote in message m... I think you will find the nico-press sleeves for aircraft are STEEL,not aluminum. \I think you'll find that they come in: Stainless steel Copper, tin plated copper, and zinc plated copper. and Aluminum. The stainless ones are not that commonly used by homebuilders. They require a lot of pressure to crimp and only used on stainless cables. Most people use the copper-alloy/plated ones as appropriate for the cable \ |
Mea Culpa! They are zinc not tin plated.
-- Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs or Always looking for articles for the Experimenter "Ron Natalie" wrote in message m... "Bob Olds" wrote in message m... I think you will find the nico-press sleeves for aircraft are STEEL,not aluminum. \I think you'll find that they come in: Stainless steel Copper, tin plated copper, and zinc plated copper. and Aluminum. The stainless ones are not that commonly used by homebuilders. They require a lot of pressure to crimp and only used on stainless cables. Most people use the copper-alloy/plated ones as appropriate for the cable \ |
"Cy Galley" wrote in message news:LhWGb.465476$Dw6.1374811@attbi_s02... Mea Culpa! They are zinc not tin plated. -- No you are right, for stainless cables they are tin plated. It's actually not the tin plating that makes the difference here. They use a different copper alloy in the tin plated version that's compatible with stainless (so says National Telephone, the owners of the Nicopress brand). |
On Thu, 25 Dec 2003 16:34:57 -0500, in rec.aviation.homebuilt you
wrote: "Drew Dalgleish" wrote in message ... At the local farm supply they're selling aluminum nico sleeves. Has anyone had any experience using these ? This is not surprising. The press type swaging for support/guy wires and wire fencing long before people thought about using them in airplanes and boats. I'd be careful that these are the ones designed for steel aircraft cable rather than fence wire before risking my life on them. The nicos were being sold beside the stainless and galvanized aircraft cable. I'm not planning on risking my life to them but using them on the check cables and drift cutters on the skis I'm building. Drew |
"Ron Natalie" wrote in message m... "Cy Galley" wrote in message news:LhWGb.465476$Dw6.1374811@attbi_s02... Mea Culpa! They are zinc not tin plated. -- No you are right, for stainless cables they are tin plated. It's actually not the tin plating that makes the difference here. They use a different copper alloy in the tin plated version that's compatible with stainless (so says National Telephone, the owners of the Nicopress brand). My thanks to all for the informative discussion. I am fabricating restraint cables from the shoulder harness mounting back to the tailwheel. I had hoped to get the pieces at Home Depot Aircraft Supplies, but ran into the aluminum fittings. I'll wait until I can get to the Real Aircraft Store. Rich S. |
Unfortunately they are COPPER or COPPER with tin plating.
-- Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs or Always looking for articles for the Experimenter "Bob Olds" wrote in message m... I think you will find the nico-press sleeves for aircraft are STEEL,not aluminum. Bob Olds Charleston,Arkansas |
I used to belong to a group that used a big levelwind reel, hooked to a 350
Chevy V8, to jerk a KA7 into the air. We had a 1000 M of 4mm cable that was spliced with Al sleeves. we never had an Al sleeve fail, although we used to break the cable fairly often. If I remember right all the control cables on the KA7 were joined with Al sleeves. I think they are used on the late model German glass planes too. With two swaged Al sleeves, I think you would break the cable, before the sleeves failed. Bill "Bob Olds" wrote in message m... I think you will find the nico-press sleeves for aircraft are STEEL,not aluminum. Bob Olds Charleston,Arkansas |
"William T Bartlett" wrote in message . com... I used to belong to a group that used a big levelwind reel, hooked to a 350 Chevy V8, to jerk a KA7 into the air. We had a 1000 M of 4mm cable that was spliced with Al sleeves. we never had an Al sleeve fail, although we used to break the cable fairly often. If I remember right all the control cables on the KA7 were joined with Al sleeves. I think they are used on the late model German glass planes too. With two swaged Al sleeves, I think you would break the cable, before the sleeves failed. You better check that the cable and the sleeves are compatible for the long haul. The galvanized cable and stainless steel take different nicopress alloys. |
On Mon, 29 Dec 2003 18:02:26 -0500, "Ron Natalie"
wrote: "William T Bartlett" wrote in message . com... I used to belong to a group that used a big levelwind reel, hooked to a 350 Chevy V8, to jerk a KA7 into the air. We had a 1000 M of 4mm cable that was spliced with Al sleeves. we never had an Al sleeve fail, although we used to break the cable fairly often. If I remember right all the control cables on the KA7 were joined with Al sleeves. I think they are used on the late model German glass planes too. With two swaged Al sleeves, I think you would break the cable, before the sleeves failed. You better check that the cable and the sleeves are compatible for the long haul. The galvanized cable and stainless steel take different nicopress alloys. I checked some different sites on this and found that aluminum sleeves will only carry half the strenth of the cable while copper will develop nearly full strength. Also AL and stainless don't get allong with each other very well. I'm going to use copper or tin plated sleeves. Thanks for the help Drew Dalgleish |
| nicos | Drew Dalgleish | Home Built | 1 | December 25th 03 10:34 PM |
