As many of you know, I am a big proponent of using Lemon Pledge to clean an
airplane. It can be used on the Plexiglas safely, and if you spray the leading edges of the wings with it after each flight, the bugs just swish right off with little effort. In fact, that's ALL we have ever washed the plane with -- Lemon Pledge. No soap and water has ever touched our plane. When we were at Sun N Fun a couple of weeks ago, however, I saw a most peculiar speckle and stripe pattern on our wings and fuselage that was only visible in the direct sunlight. There were obviously cleaner spots and stripes, and Pledge would not touch them. You could spray, wipe and buff till your heart's content, but all you were doing was buffing the surface -- this dirt was much deeper than that. When we got home I hit a spot with some Castrol Super Clean, and *voila!* -- the whole spot became a much whiter, gleaming white. Apparently two years of Lemon Pledging has actually sealed some dirt in, under a layer of Pledge wax that the Pledge itself couldn't dissolve. So, last night my son and I started the arduous task of washing every square inch with Super Clean and diapers, followed immediately by a coat of spray-on Turtle wax (to neutralize the caustic Super Clean). He finished the under-side, while I did the top of both wings -- wow, what a difference! What looked "clean and white" before is now almost blindingly white. The dullness had crept up so slowly that we simply did not notice. So, while we'll still hit the windshield, leading edges, and nose with Pledge after each flight, our days of using it as an "overall" cleaner are over -- although I'd like to find something less harsh than Super Clean. Any suggestions? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay, have you ever tried Wash Wax All? That's what I use and it seems to
work very well. It's made for airplanes, while Lemon Pledge, let's face it, is made for furniture. I've used Lemon Pledge on the windows but wonder if it might also seal dirt in as it apparently did with your airplane fuselage. My old instructor recommended Novus for the windows. I've used that for two years and it also seems to do the job fine. Henry P.S. How much would your son charge to do the underwings and undertailfeathers of a 150? That wrecks my back. Might be worth a trip out to Iowa City. |
Henry Kisor wrote:
: Jay, have you ever tried Wash Wax All? That's what I use and it seems to : work very well. It's made for airplanes, while Lemon Pledge, let's face it, : is made for furniture. I also use wash-all wax-all (or whatever it's called). It comes in a 1-gal jug, dilute 50/50 with water, and it does a spectacular job. It doesn't leave that slight stickiness that pledge seems to leave, which is important if your plane is outside! Get the "red label" super concentrated stuff. I have been using Plexus window cleaner on the windows. It also works quite well. -- Aaron Coolidge |
Aaron,
I have been using Plexus window cleaner on the windows. It also works quite well. We use that, too, but I've read and been told numerous times that Plexus is just the aviation-priced version of Lemon Pledge. No difference at all, it seems. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote:
: Aaron, : We use that, too, but I've read and been told numerous times that : Plexus is just the aviation-priced version of Lemon Pledge. No : difference at all, it seems. Aha, you caught me in a mistake. I actually use a cleaner made by "Prist" for lexan windows. I tried the Plexus but I wasn't happy with it, for the same reasons that I didn't like pledge: it seems to leave a slight sticky film. The "Prist" does not leave such a film. I don't know exactly what part number the "Prist" cleaner is. It is not the de-icing additive used in jet fuel that is also marketed by "Prist"! -- Aaron Coolidge |
I second the Wash Wax All recommendation. Have used it for
years and it works great. "Henry Kisor" wrote in message ... Jay, have you ever tried Wash Wax All? That's what I use and it seems to work very well. It's made for airplanes, while Lemon Pledge, let's face it, is made for furniture. I've used Lemon Pledge on the windows but wonder if it might also seal dirt in as it apparently did with your airplane fuselage. My old instructor recommended Novus for the windows. I've used that for two years and it also seems to do the job fine. Henry P.S. How much would your son charge to do the underwings and undertailfeathers of a 150? That wrecks my back. Might be worth a trip out to Iowa City. |
On Mon, 03 May 2004 16:07:52 GMT, "Otis Winslow"
wrote: I second the Wash Wax All recommendation. Have used it for years and it works great. Streaks for me. I've tried cutting it in various ratios with distilled water, but still no dice. "Henry Kisor" wrote in message ... Jay, have you ever tried Wash Wax All? That's what I use and it seems to work very well. It's made for airplanes, while Lemon Pledge, let's face it, is made for furniture. I've used Lemon Pledge on the windows but wonder if it might also seal dirt in as it apparently did with your airplane fuselage. My old instructor recommended Novus for the windows. I've used that for two years and it also seems to do the job fine. Henry P.S. How much would your son charge to do the underwings and undertailfeathers of a 150? That wrecks my back. Might be worth a trip out to Iowa City. |
Jay Honeck wrote:
As many of you know, I am a big proponent of using Lemon Pledge to clean an airplane. It can be used on the Plexiglas safely, and if you spray the leading edges of the wings with it after each flight, the bugs just swish right off with little effort. Although I've used pledge on the windshields for 17 years, you should note that some of the new plexiglass cleaners, like the product made by Aeroshell, work SIGNIFICANTLY better than pledge. In fact, that's ALL we have ever washed the plane with -- Lemon Pledge. No soap and water has ever touched our plane. I've never understood your obsession on this. Wash your damn plane once in a while. Soap and water gets places, and disolves dirt, that you can't get to with your obsessive use of pledge. When we were at Sun N Fun a couple of weeks ago, however, I saw a most peculiar speckle and stripe pattern on our wings and fuselage that was only visible in the direct sunlight. There were obviously cleaner spots and stripes, and Pledge would not touch them. You could spray, wipe and buff till your heart's content, but all you were doing was buffing the surface -- this dirt was much deeper than that. I've also seen this over the years. You really have not choice but to strip off the wax every so often. I've always been uncomfortable with using things that are too caustic. Sometimes, just a high concentration of dish washing liquid works. You can also get some mild polishes that will strip away the old wax. --- Jay -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
in a while. Soap and water gets places, and disolves dirt, that you can't get to with your obsessive use of pledge. The main reason is that Spam Cans aren't very waterproof. After our plane was parked in Tennessee for three days in a steady rain, the carpet by the door was wet, and our nice, new interior smelled dank. Excess moisture was evident even after we got home, despite "air drying" for three or four days -- and about ten hours in the air. This despite the fact that the plane is air-tight in flight. Cleaning my motorcycles with Pledge -- not water -- has meant that I have a 1988 Gold Wing that looks like it just rolled off the assembly line. No moisture gets into the cracks and crevices, meaning that everything stays fresh and clean longer. (Water works itself into areas that cannot be dried, then attracts dirt and slowly gums up the works or corrodes whatever it's sitting on. In fact, my hangar neighbor with a mid-50s Bonanza just had to replace a chunk of skin metal on the bottom, due to corrosion. The diagnosis: Water got into the area and could not drain. Over the years, it literally ate a hole in the bottom of the plane!) Pledge is still the best day-to-day cleaner polish for the money -- but it's evident that a stronger detergent-type cleaner is needed every so often. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
The main reason is that Spam Cans aren't very waterproof. All you have to do is whip it around the pattern a couple of times after you wash it. It'll be fine. My plane sat outside for years before I finally got my hangar. It was no big deal. You're being overly obsessive. -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
Annual Costs - Take the Pledge | Roger Long | Owning | 25 | February 1st 04 03:41 PM |
I PLEDGE ALLEGIANCE..... | ArtKramr | Military Aviation | 19 | October 24th 03 07:51 PM |
