Cessna seat rails
Old May 12th 04, 03:19 AM
Javier Henderson
Default Cessna seat rails
May I refer you to:
http://www.kjsl.com/~javier/sb-1.pdf
http://www.kjsl.com/~javier/sb-2.pdf
http://www.kjsl.com/~javier/ad-1.pdf
http://www.kjsl.com/~javier/ad-2.pdf
That deals with the seat rails on Cessna single engine aircraft. It's
pretty straightforward, when the holes on the rails are elongated
beyond certain limits, or if cracks are observed, the rails need to be
replaced.
The deal is, these suckers are riveted, and the outboard rails appear
to be a pain to deal with... there's either a magic bucking bar I don't
know about, or maybe there are little Wichita-born elves that fit in
there.
So the question is, how does one deal with this seat rail replacement?
Removing them is easy enough, and a lot of the rivets are doable, but
some are not. How does one deal with the impossible ones?
Cherrymax rivets? #6 or #8 structural screws? Something else?
In case it matters, my plane is a 1973 182P, but I think the pain is
about the same in all cases.
Thanks,
-jav
Old May 12th 04, 03:35 AM
MikeM
know about,
(Yes, we made one when my AI and I did it to my 182)
there.
I was the designated elf. I still have scars on my hands
About 3 screws per rail...
MikeM
Skylane '1MM
Old May 12th 04, 07:03 AM
Javier Henderson
MikeM writes:
Well, share! Seriously, got pic?
Ouch.
#6?
-jav
Old May 12th 04, 05:08 PM
MikeM
MikeM writes:
Its in my AI's toolbox (I have a key; how many other plane owners
have that?). If I remember, I will take my digital camera out
and snap a pic.
Ouch.
They match the scars on my arms from when I replaced the fuel
bladders in the 182...
#6?
We used #8 MS Cd-plated structural screws with shakeproof
nuts, only in the places where it is impossible to get a
bucking bar...
MikeM
Old May 12th 04, 06:01 PM
Javier Henderson
MikeM writes:
Let's not talk about that right now...
bucking bar...
Honest question: is there a reason to not use screws all around? Are
they heavier? More expensive?
-jav
Old May 12th 04, 06:42 PM
MikeM
MikeM writes:
bucking bar...
My AI is a rivet freak. He loves rivets. Personally, I would have been
inclined to use the screws, cost be dammed, in the event I ever have
to replace the seat rail again. AFIK, Accepted Practices specifically says
that it is ok to use a fastener inplace of a rivet.
ToeCutter? Chime in here.
MikeM
Old May 12th 04, 04:48 AM
Newps
"Javier Henderson" wrote in message
May I refer you to:
replaced.
A crack does not make the rail unairworthy. I forget the exact wording but
it is something like if a crack goes from one hole to another then it is
unairworthy. I have had a crack in one of the copilot rails for the 6 years
I have owned the plane.
Old May 12th 04, 07:04 AM
Javier Henderson
"Newps" writes:
May I refer you to:
replaced.
Yeah, mine aren't cracked, and the holes were ok last year, but we'll
see how it goes this year, annual is next month...
-jav
Cessna buyers in So. Cal. beware ! Bill Berle Aviation Marketplace 93 December 20th 04 02:17 PM
Cessna buyers in So. Cal. beware ! Bill Berle Home Built 73 June 25th 04 04:53 AM
Cessna Steel Landing Gears, J-3 Seat Sling For Auction Bill Berle Home Built 0 February 19th 04 06:51 PM
Cessna Steel Landing Gears, J-3 Seat Sling For Auction Bill Berle Aviation Marketplace 0 February 19th 04 06:51 PM
