Oil usage
Old May 14th 04, 02:01 PM
GE
Default Oil usage
Still shopping for my first bird. Curious as to how much oil usage is
considered "normal"?
Old May 14th 04, 03:13 PM
G.R. Patterson III
To some extent, that'll depend on the engine. My O-320 uses about a quart in 10
hours. A radial might use that in 10 minutes.
George Patterson
I childproofed my house, but they *still* get in.
Old May 14th 04, 05:13 PM
Aaron Coolidge
G.R. Patterson III wrote:
: GE wrote:
: Still shopping for my first bird. Curious as to how much oil usage is
: considered "normal"?
: To some extent, that'll depend on the engine. My O-320 uses about a quart in 10
: hours. A radial might use that in 10 minutes.
My O-360 uses about 1qt in 12 hours. It's got about 1000 hours smoh, and
6500 hours TT.
Do keep in mind that too little oil consumption is probably worse than too
much!
Aaron Coolidge (N9376J)
Old May 15th 04, 08:12 AM
Ross Oliver
much!
Could you elaborate on this claim? I have never heard of too little
oil consumption being indicative of any problem.
Old May 15th 04, 09:12 AM
Ben Jackson
Oil has to lubricate the piston ring/cylinder point. Some of that gets
left on the walls and burns during the normal combustion event. A quick
web search turns up 1qt/15h as a rough lower bound.
Ben Jackson
http://www.ben.com/
Old May 14th 04, 10:56 PM
Ben Jackson
Heck on start it might use that in 10 blades...
Ben Jackson
http://www.ben.com/
Old May 14th 04, 09:09 PM
PaulH
"GE" wrote in message ...
Also depends on the engine type. The IO360 used in the Piper Arrow
runs through the first 2 quarts (out of 8) pretty quickly (2 quarts in
10 hours), then levels off.
Old May 14th 04, 11:08 PM
G.R. Patterson III
My Maule will also go through the first quart pretty quickly if I top it off. Which
is why I *never* put more than 7 quarts in the engine. My Cessna 150 also used to
throw the first quart out, and I quit filling it up once I caught on.
George Patterson
Old May 15th 04, 05:46 AM
Tony
In my o540 keep it at 9 and it burns about 1qt every 4 hours. Has 300
SMOH in 1989 and it sat for about 3 year with out flying and now I have
been flying it alot so it just gets better and better. We started off
about 2hrs for every qt.
*** Sent via http://www.automationtools.com ***
Add a newsgroup interface to your website today.
Old May 15th 04, 02:42 PM
GE
The plane I'm looking at has an O-540 that has 300 hrs since overhaul in
1996, so it hasn't been flown a bunch. The owner flew it here in under 2 hrs
and I know that it used at least 1 quart, maybe 1.5. I don't remember how
much he put in to start the trip, so I can't say if any was tossed in
flight. Interesting to hear you say that it gets better over time.
"Tony" wrote in message
Would the AH-6J (Little Bird make a good, low cost, helicopter for force protection? John Hairell Military Aviation 7 May 19th 04 01:04 AM
"Dirty Tricks" and "Both Sides Do It" Leslie Swartz Military Aviation 19 March 29th 04 06:11 PM
Aeronautical Engineering Help needed Marc A. Lefebvre US-775 Home Built 94 January 11th 04 12:33 PM
me-109 overall "76" combat usage? old hoodoo Military Aviation 9 December 16th 03 12:55 AM
