In reading a booked called "Design for Safety", by David Thurston, he
advises owners to "turn the propeller over by hand three or four times during preflight if the airplane has been standing for half a day or longer." [p169] His rationale is as follows. "When an engine has been standing for awhile and has not been pulled through by hand prior to starting, an accident could result if fuel or oil has collected in the cylinders. When the engine fires, trapped fluids can cause bent piston rods, cracked cylinders, or a damaged crankshaft. Althouogh such accidents might not cause bodily injury, they surely can harm one's budget and can beavoided by proper preflight procedures. It is also possible for damage of this type to remain hidden until something fails in flight" [pp 147-148]. I am quite surprised that this is the first I have heard such advice. What do folks on this newsgroup think of that advice? Does anyone out there do this routinely? If so, what is the proper procedure? Do you just turn the prop slowly in the direction the prop normally turns? Could fuel actually collect in the cylinders as suggested? Why would the fuel not just evaporate? -Sami M2057M, Piper Turbo Arrow III |
O. Sami Saydjari wrote: In reading a booked called "Design for Safety", by David Thurston, he advises owners to "turn the propeller over by hand three or four times during preflight if the airplane has been standing for half a day or longer." [p169] His rationale is as follows. "When an engine has been standing for awhile and has not been pulled through by hand prior to starting, an accident could result if fuel or oil has collected in the cylinders. When the engine fires, trapped fluids can cause bent piston rods, cracked cylinders, or a damaged crankshaft. Althouogh such accidents might not cause bodily injury, they surely can harm one's budget and can beavoided by proper preflight procedures. It is also possible for damage of this type to remain hidden until something fails in flight" [pp 147-148]. Sounds like the author has been flying with radial engines. I am quite surprised that this is the first I have heard such advice. What do folks on this newsgroup think of that advice? Not necessary if you're flying behind a flat engine. Someone else will have to speak for radials. Does anyone out there do this routinely? If so, what is the proper procedure? Do you just turn the prop slowly in the direction the prop normally turns? Could fuel actually collect in the cylinders as suggested? Why would the fuel not just evaporate? Remove SHIRT to reply directly Dave |
O. Sami Saydjari ) wrote:
Could fuel actually collect in the cylinders as suggested? Why would the fuel not just evaporate? Wouldn't killing the engine by pulling the mixture lever out remove all fuel in the cylinders? -- Peter |
"O. Sami Saydjari" wrote: In reading a booked called "Design for Safety", by David Thurston, he advises owners to "turn the propeller over by hand three or four times during preflight if the airplane has been standing for half a day or longer." [p169] How old is the book? This sounds like something that would be advised for radial engines, where such issues (called hydraulic lock) were indeed a problem. Unless your aircraft manual specifically advises you to do this, I wouldn't. |
The book appears to have been published in 1995. He does not seem to
say anywhere that the advice is unique to radials. -Sami Roy Smith wrote: In article , "O. Sami Saydjari" wrote: In reading a booked called "Design for Safety", by David Thurston, he advises owners to "turn the propeller over by hand three or four times during preflight if the airplane has been standing for half a day or longer." [p169] How old is the book? This sounds like something that would be advised for radial engines, where such issues (called hydraulic lock) were indeed a problem. Unless your aircraft manual specifically advises you to do this, I wouldn't. |
The book appears to have been published in 1995. He does not seem to say anywhere that the advice is unique to radials. Hydraulic lock on radials without clean kits is well understood, but for wet sump boxer engines like we generally fly behind the advice not only makes no sense, it's contrary to Lycoming's current recommendations. With the oil sump under beneath the engine there's simply no mechanism for lock to occur, unless you tend to park your aircraft inverted. About the only mechanism I can imagine for causing something like this would be on some injected engines, where hitting the boost pump and ramming the mixture full forward while the engine is stopped will dump gobs of fuel into the intake runners. While much of it will eventually come pouring out the air cleaner it's not hard to imagine getting unlucky and having one cylinder with an intake valve open. Hardly seems the basis for turning the engine over by hand as a standard procedure. |
Chris Kennedy wrote: While much of it will eventually come pouring out the air cleaner it's not hard to imagine getting unlucky and having one cylinder with an intake valve open. In any engine that has valves and at least four cylinders, at least one of the intake valves will be open when the engine is not running. In a four-banger, there will be one piston on the power stroke and another on the compression stroke, and these two pistons will stop about halfway down the bore (where the compression in each is about equal). One of the other pistons will be halfway down the intake stroke. George Patterson I childproofed my house, but they *still* get in. |
On Mon, 17 May 2004 16:20:27 GMT, Chris Kennedy
wrote: O. Sami Saydjari wrote: The book appears to have been published in 1995. He does not seem to say anywhere that the advice is unique to radials. Hydraulic lock on radials without clean kits is well understood, but for wet sump boxer engines like we generally fly behind the advice not only makes no sense, it's contrary to Lycoming's current recommendations. With the oil sump under beneath the engine there's simply no mechanism for lock to occur, unless you tend to park your aircraft inverted. About the only mechanism I can imagine for causing something like this would be on some injected engines, where hitting the boost pump and ramming the mixture full forward while the engine is stopped will dump gobs of fuel into the intake runners. While much of it will eventually That's the way I start mine. come pouring out the air cleaner it's not hard to imagine getting None of it comes out the air cleaner, but it sure do run out the exhaust stacks. OTOH, Boost pump on for a count of three (or even 10)hardly qualifies for enough to block a cylinder. Course the count of ten might start a fire. :-)) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com unlucky and having one cylinder with an intake valve open. Hardly seems the basis for turning the engine over by hand as a standard procedure. |
I always pull the prop through at least two revolutions - just to make
sure there is compression on all six cylinders. As for there being no need to do so with opposed engines, I vividly recall a pilot telling the story about what happened to him. It seems he had just bought a new (to him) airplane, and was trying it out. It was an early model Cessna 210, with fuel injection. He decided to find out how fast it was, and laid out a course between two points along the Southern California coastline. Then he flew the course with the throttle and prop firewalled. To cancel the efect of wind, he planned to fly it in both directions. The outbound pass went well, but on the way back there was suddenly a loud bang, and the view out the windshield went black (covered with oil). Down he went, sighting out the side windows as best he could. He ditched it in the ocean, and managed to get out before it sank. It gets worse. As there were no boats within sight, he swam to the beach. There was no one there either. Then a boat came along, so he swam out to it. About that time, some rescuers showed up on the beach, so he swam back again. Later, the plane was recovered. They found that a cylinder had blown off the engine, right through the cowling. The analysis was hydraulic lock, caused by a leaky injector. The theory was that the cylinder had filled with gasoline, and was overstressed when the engine was started. It could have happened long before the final flight. Worst of all, he had neglected to obtain insurance for his new toy. The only good news in this event is that he walked (or rather swam) away with only a minor injury. David Johnson |
"O. Sami Saydjari" wrote in message ...
The book appears to have been published in 1995. He does not seem to say anywhere that the advice is unique to radials. -Sami It certainly sounds like the old radial hydro-lock check. Since the oil sump and fuel system of your average horizontally opposed engine are lower than the cylinders, I can't see where this procedure would be applicable. For radials, on the other hand, it's a very common procedure. BTW - Was that you I saw on "Frontline" last week? John Galban=====N4BQ (PA28-180) |
| Thread Tools | |
| Display Modes | |
| Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 11:18 PM |
| Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 04:04 AM |
| "I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 10th 04 12:35 AM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
| IVO props... comments.. | Dave S | Home Built | 16 | December 7th 03 12:43 AM |
