Cable vs rope pulling glider from field
Old October 12th 11, 04:34 PM posted to rec.aviation.soaring
Auxvache
Default Cable vs rope pulling glider from field
I'd like to make a stout wire cable or rope with proper TOST ring, to
have on hand should I have to tow my 15m glider from mud/soft dirt/
guano.
Is a metal cable necessary/preferable, or would high breaking-strength
rope be sufficient?
My only experience here (Chester loam, Pegase, and stick-shift BMW)
did not end well.
Thanks in advance,
Erik
Old October 12th 11, 05:32 PM posted to rec.aviation.soaring
jcarlyle
Erik,
I don't think pulling your glider out of such a situation via its tow
hook is advisable. The drag from the landing gear and fuselage could
easily exceed the tow hook's structural mounting (read, expensive
repairs).
The one time I landed in a soft field we got the plane out by
disassembling it where it stopped, and carrying the pieces to the
trailer. Messy, and hard work, but I flew the next day (after washing
off the mud).
-John
guano.
rope be sufficient?
did not end well.
Thanks in advance,
Erik
Old October 12th 11, 06:28 PM posted to rec.aviation.soaring
Bill D
guano.
rope be sufficient?
did not end well.
Thanks in advance,
Erik
Steel cable is nasty - use Dyneema rope instead so it can be neatly
rolled up. Use the Tost weak link called out in your glider's manual
to protect the hook and glider from overloads. If that won't get you
out, you're REALLY stuck.
If this is a regular occurrence, consider a small portable 12V
electric winch from a vendor like Warn temporarily fitted to the
receiver hitch on your BMW so the glider can be slowly and gently
pulled out of the muck without stressing the car's clutch. Replace
the steel cable with Dyneema rope.
http://www.amazon.com/Warn-68531-WAR.../dp/B000CQBMMW
http://www.warn.com/truck/winches/VR8000_winch.shtml
Old October 12th 11, 06:43 PM posted to rec.aviation.soaring
kirk.stant
guano.
rope be sufficient?
did not end well.
Thanks in advance,
Erik
You might consider keeping a Tost ring set in your glider, as part of
your landout kit. Nice to have when you want a local to help move
your glider to a different location for derigging, etc. Rope of some
sort is almost always available, but trying to use a rope loop in a
Tost release is an exercise in futility!
Kirk
Old October 12th 11, 08:38 PM posted to rec.aviation.soaring
Ben Watkins
guano.
rope be sufficient?
did not end well.
Thanks in advance,
Erik
Kirk
If you are putting strain on the tow rope make sure you lay something
reasonably heavy (coat, car rug etc.) over the rope more than half from the
car to the glider. That way if the rope does break the rings, weak link
etc. won't end up flying through your back window!
Old October 12th 11, 09:18 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
guano.
rope be sufficient?
did not end well.
Thanks in advance,
Erik
your landout kit. Nice to have when you want a local to help move your
glider to a different location for derigging, etc. Rope of some sort is
almost always available, but trying to use a rope loop in a Tost release
Kirk
the car to the glider. That way if the rope does break the rings, weak
link etc. won't end up flying through your back window!
....and use a rope with as little stretch, which means energy storage, as
possible. A light weight cable is good too for the same reason.
Steel cable is about the worst thing you could use because of the way it
lashed round if it or a fixing breaks under load and, and is harder to
wind up and store than it needs to be. OTOH plastic rope rope,
particularly Dyneema or good quality climbing rope, both have minimal
energy storage and are easy to handle.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old October 13th 11, 01:40 AM posted to rec.aviation.soaring
Bill D
On Oct 12, 2:18*pm, Martin Gregorie
guano.
rope be sufficient?
did not end well.
Thanks in advance,
Erik
your landout kit. *Nice to have when you want a local to help move your
glider to a different location for derigging, etc. *Rope of some sort is
Kirk
martin@ * | Martin Gregorie
org * * * |
Actually for the force required, 2mm Dyneema would be strong
enough. The 12V winch linked above would likely hold 2000 feet or
so. If you landed in a boggy field which wouldn't support a car and
needed to get the glider to its trailer, this would be just the
trick. Mount the winch at the front of a trailer and it could help
get the glider onto its fuselage dolly, then pull the fuselage into
the trailer.
Old October 13th 11, 02:39 PM posted to rec.aviation.soaring
Auxvache
Thanks very much for your answers--sounds like Dyneema with a weak
link and Tost ring would be a good set-up.
And, forewarned, I promise not to dehisce the nose of the glider with
Farmer Brown's tractor.
Or shatter the back window of mum's grocery-getter.
And if it gets to be a regular occurrence, I'll find another hobby.
Erik
Pulling Avionics Boxes. brian whatcott General Aviation 0 November 8th 09 04:42 PM
Short field glider ops [email protected] Soaring 5 June 5th 09 03:21 PM
bicycle wire - glider cable [email protected] Soaring 4 April 6th 08 05:53 AM
Accepting cable/rope at start. Bill Daniels Soaring 26 September 6th 07 01:03 AM
59% increase in pulling power is claimed for an unusual new rotor propeller for airplanes Larry Dighera Piloting 5 November 21st 03 02:13 AM
