slightly high aluminum in an IO-360
Old May 25th 04, 12:54 AM
Robert M. Gary
Default slightly high aluminum in an IO-360
I've had slightly high aluminum for the last year. I'm not happy about
it but everyone says its not high enough to spend real money pulling
cylinders or boroscoping. I'm curious what the group thinks...
IO-360-A3B6
SFNEW 682
At each 50 hours change I've had...
7, 10, 25, 13 (short sample), 24, 23 ppm
I don't think I have an alumimum dip stick (at least my A&P says I
don't). I'm not finding anything in the filter.
I'm in California so everything is pretty pricey. Should I spend a
grand or so having the cylinders boroscoped?
-Robert
Old May 25th 04, 02:17 AM
Kyle Boatright
The cylinder bores are steel. You might pull all of your plugs (top and
bottom) and rotate the prop by hand so you can get a good look at the
pistons and part of the cylinder walls. Shining a flashlight through one
plug hole and looking through the other hole works pretty well.
The obvious place for aluminum is the pistons or the piston wrist pin caps,
and you cant see the caps without pulling the jug.
KB
om...
IO-360-A3B6
SFNEW 682
-Robert
Old May 25th 04, 03:13 AM
rip
A grand or so? Borescoping is now considered a standard part of the
compression check for Continental engines, and I do it regularly on
every annual. Borescoping involves little more than pulling a spark plug
out of each cylinder, and shouldn't cost any $1000 or so! Unless you
have a piston disintegrating, borescoping won't tell you much in your
case, either.
IO-360-A3B6
SFNEW 682
-Robert
Old May 25th 04, 01:24 PM
Rich
I've had slightly high potassium, but instead of borescoping, my AME put
me on a diuretic.
Rich
Old May 25th 04, 02:05 PM
Bob Chilcoat
You should stop peeing in your engine.
Bob (Chief Pilot, White Knuckle Airways)
I don't have to like Bush and Cheney (Or Kerry, for that matter) to love
America
"Rich" wrote in message
me on a diuretic.
Rich
Old May 26th 04, 05:50 PM
Robert M. Gary
(PaulaJay1) wrote in message ...
(Robert M. Gary) writes:
IO-360-A3B6
SFNEW 682
Robert,
The IO360 in my Archer has about the same hours and the last three readings
have been 14, 10, 12 for the Al. Cleve Tech Center ( and my A&P) say that is
OK. Yours is a little higher but if the "experts" say OK the watchfull waiting
seems to be in order. The Troubleshooting Guide from Cleve Tech suggests less
than 10 and the sources can be from "Bushings, Some Bearings, Pistons, Turbo
Charger, Compressor Wheels". Seems to me (no expert) that the borscope would
not answer your question anyway.
I just called Lycoming. To my surprise, they were very helpful to me
considering I bought the engine from them 8 years ago. They said to
check the oil screen. I didn't even know the IO-360 had a screen. They
said that if I found any metal in the filter or the screen that I
could send it to them. They said they could tell EXACTELY what part of
the engine was making it. Apparently different parts of the engine's
aluminum have different alloys. So the piston pins have a different
aluminum than the dip stick, etc. He also said there was no charge for
this.
I've checked the filter beofre and not found anything. However, I've
never checked the screen. I'm not sure if my IA is doing that during
annual or not.
-Robert
Old May 26th 04, 07:05 PM
G.R. Patterson III
annual or not.
The screen should be checked every 50 tach hours. If the shop is changing the oil as
part of the annual, they almost certainly are checking the screen. If they aren't I
would wonder what else they're skipping.
George Patterson
I childproofed my house, but they *still* get in.
Old May 27th 04, 12:02 AM
Robert M. Gary
"G.R. Patterson III" wrote in message ...
annual or not.
I'm sure the shop is doing it but I do most of the oil changes myself
(except the one at annual). I'm not checking the screen. I'll have to
schedule some time with the A&P to have him show me how to do it. The
Lycoming guy said they've seen cases where a filter has come out clean
because there were so many chunks of big metal plugging up the screen.
-Robert
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
