The Bombardier web page says that a V-220 engine (their next
generation offering for the 200 hp crowd will weigh 419 pounds (see http://www.vaircraftengines.com/en/t...Data_v-220.asp). That's for the whole 'package', who's contents are listed at http://www.vaircraftengines.com/en/thePackage.asp. Is this much more than the standard Lycoming/Continental? Also, the V-220 is supposed to get .42 lbs/hp-hour. How does this compare to the standard aircraft engines? -Much Thanks |
![]() "Charles Talleyrand" wrote in message ... The Bombardier web page says that a V-220 engine (their next generation offering for the 200 hp crowd will weigh 419 pounds (see http://www.vaircraftengines.com/en/t...Data_v-220.asp). That's for the whole 'package', who's contents are listed at http://www.vaircraftengines.com/en/thePackage.asp. TCM TSIO-520-NB, rated at 335 HP for takeoff, 412 lbs. dry, includes turbocharger and exhaust. Is this much more than the standard Lycoming/Continental? Also, the V-220 is supposed to get .42 lbs/hp-hour. How does this compare to the standard aircraft engines? TCM TSIO-520-NB at 75% power/251 HP, 18.5 GPH/108 Lb/hr, = .43 lbs/hp-hour. |
On Wed, 26 May 2004 01:44:26 -0400, "Charles Talleyrand"
wrote: The Bombardier web page says that a V-220 engine (their next generation offering for the 200 hp crowd will weigh 419 pounds (see http://www.vaircraftengines.com/en/t...Data_v-220.asp). That's for the whole 'package', who's contents are listed at http://www.vaircraftengines.com/en/thePackage.asp. Is this much more than the standard Lycoming/Continental? Also, the V-220 is supposed to get .42 lbs/hp-hour. How does this compare to the standard aircraft engines? -Much Thanks Lycoming claims .435 while burning 9.8 gallons/hour with a fixed pitch prop while running the engine at 75% power. This is for a 180 hp engine. The Deltahawk diesel claims a BSFC of .38 while running at 75% power. Some of the larger radial engines used to be able to reduce the BSFC down to under .4 by extreme leaning. Most auto engines, even the modern ones with computerized everything still run at a BSFC of .50 or higher. That's on the street. Put that same engine in an airplane and lean the mixture for max range and it's likely the BSFC will be lower. To get most of this information I used Google, and typed in "BSFC Lycoming". Corky Scott |
402C Specs | Robert Borucki | General Aviation | 0 | February 2nd 05 07:22 PM |
Bombardier V-220 Specs | Charles Talleyrand | Home Built | 2 | May 26th 04 03:33 PM |
Bob the bombardier has passed on | Chris Mark | Military Aviation | 2 | May 13th 04 03:42 AM |
C-141 detailed Specs | Phil M | Military Aviation | 1 | January 27th 04 06:53 AM |
Specs for a B24D Liberator | John T. Slodyczka | Military Aviation | 0 | November 21st 03 02:18 AM |
