While I had my panel apart the other day, I noticed the RJ jack in the back
of the 302. Since I had half a Cambridge cable, I plugged it in, powered up, and measured voltage across the red and black leads - 5v! I took a standard USB cable that fits the Mio, cut it, and measured the red and black leads - again, 5v! Tomorrow, I'll connect the two cables together and run the Mio of the ship's batteries. Dan |
Hi Dan,
That is a very bad idea! The RJ connector on the back of the 302 is for connection to the 303 LCD display. The 303 is a low voltage device. Your Mio is not. I'm not certain, but I fear you will fry something in the 302. Best Regards, Paul Remde "Dan Marotta" wrote in message ... While I had my panel apart the other day, I noticed the RJ jack in the back of the 302. Since I had half a Cambridge cable, I plugged it in, powered up, and measured voltage across the red and black leads - 5v! I took a standard USB cable that fits the Mio, cut it, and measured the red and black leads - again, 5v! Tomorrow, I'll connect the two cables together and run the Mio of the ship's batteries. Dan |
Hi,
I meant to state below that the 303 is a low power device. Thanks Dave. Paul Remde "Paul Remde" wrote in message ... Hi Dan, That is a very bad idea! The RJ connector on the back of the 302 is for connection to the 303 LCD display. The 303 is a low voltage device. Your Mio is not. I'm not certain, but I fear you will fry something in the 302. Best Regards, Paul Remde "Dan Marotta" wrote in message ... While I had my panel apart the other day, I noticed the RJ jack in the back of the 302. Since I had half a Cambridge cable, I plugged it in, powered up, and measured voltage across the red and black leads - 5v! I took a standard USB cable that fits the Mio, cut it, and measured the red and black leads - again, 5v! Tomorrow, I'll connect the two cables together and run the Mio of the ship's batteries. Dan |
I bought a 12V-5V DC converter for $10, added a $2 heatsink and wired it into my power lines. Next, I cut off the end of a mini-USB cable and wired that to the converter.
Works great for me, no problems. -John |
Power is NOT the same thing as voltage...
Paul, do you mean "the 303 display is a low POWER device" ? |
I assume you are powering a Mio GPS - if not then ignore the
following. I'd suggest you wire in a 12v accessory socket then plug the Mio charger cable into it. If you use a regular mini USB plug into the Mio I think you will find the Mio will think it is a data cable and stop any software that is running to try and make a data transfer. Allan. |
The 302 manual (pg 25) says pin 4 of the RJ11 is
"+5V = Device power – fuse-limited to 0.9 Amp" pin 6 and 8 of the DB-9 connector are "+5 volt power from 302 to connected device; fuse-limited to 0.9 Amp" I've used the DB-9 connector on my 302 to provide +5V power to an iPAQ for 7 years now. Cambridge and others have sold connectors for that purpose for a long time. I also have a 303 hooked up to the RJ11 plug. Manual is available at the Cambridge website. -Dave On 11/1/2011 6:33 PM, Paul Remde wrote: Hi Dan, That is a very bad idea! The RJ connector on the back of the 302 is for connection to the 303 LCD display. The 303 is a low voltage device. Your Mio is not. I'm not certain, but I fear you will fry something in the 302. Best Regards, Paul Remde "Dan Marotta" wrote in message ... While I had my panel apart the other day, I noticed the RJ jack in the back of the 302. Since I had half a Cambridge cable, I plugged it in, powered up, and measured voltage across the red and black leads - 5v! I took a standard USB cable that fits the Mio, cut it, and measured the red and black leads - again, 5v! Tomorrow, I'll connect the two cables together and run the Mio of the ship's batteries. Dan |
Hi,
I stand corrected. Paul Remde "ZL" wrote in message m... The 302 manual (pg 25) says pin 4 of the RJ11 is "+5V = Device power – fuse-limited to 0.9 Amp" pin 6 and 8 of the DB-9 connector are "+5 volt power from 302 to connected device; fuse-limited to 0.9 Amp" I've used the DB-9 connector on my 302 to provide +5V power to an iPAQ for 7 years now. Cambridge and others have sold connectors for that purpose for a long time. I also have a 303 hooked up to the RJ11 plug. Manual is available at the Cambridge website. -Dave On 11/1/2011 6:33 PM, Paul Remde wrote: Hi Dan, That is a very bad idea! The RJ connector on the back of the 302 is for connection to the 303 LCD display. The 303 is a low voltage device. Your Mio is not. I'm not certain, but I fear you will fry something in the 302. Best Regards, Paul Remde "Dan Marotta" wrote in message ... While I had my panel apart the other day, I noticed the RJ jack in the back of the 302. Since I had half a Cambridge cable, I plugged it in, powered up, and measured voltage across the red and black leads - 5v! I took a standard USB cable that fits the Mio, cut it, and measured the red and black leads - again, 5v! Tomorrow, I'll connect the two cables together and run the Mio of the ship's batteries. Dan |
Why are my posts red (color, at least on my laptop)?
Thanks, Paul - I did not consider looking up the specs, which I will do. Dave, I read in the 302 manual about the 0.9A internal fusing in the 302. The cigarette lighter power cord that comes with the Mio is terminated with a mini USB connector so there should be no power/data issues. The data lines are not connected in this case. I will try to find the power requirements of the Mio online. I opened it up and it has a small (physically) battery so I suspect its power needs aren't too big. I could wire a 12v power cord into the main bus of the glider, but that's large and there's not a lot of room inside the LAK's panel. Besides, simply plugging in is so much easier! I'll report back what (if anything) I find. "Paul Remde" wrote in message ... Hi, I stand corrected. Paul Remde "ZL" wrote in message m... The 302 manual (pg 25) says pin 4 of the RJ11 is "+5V = Device power – fuse-limited to 0.9 Amp" pin 6 and 8 of the DB-9 connector are "+5 volt power from 302 to connected device; fuse-limited to 0.9 Amp" I've used the DB-9 connector on my 302 to provide +5V power to an iPAQ for 7 years now. Cambridge and others have sold connectors for that purpose for a long time. I also have a 303 hooked up to the RJ11 plug. Manual is available at the Cambridge website. -Dave On 11/1/2011 6:33 PM, Paul Remde wrote: Hi Dan, That is a very bad idea! The RJ connector on the back of the 302 is for connection to the 303 LCD display. The 303 is a low voltage device. Your Mio is not. I'm not certain, but I fear you will fry something in the 302. Best Regards, Paul Remde "Dan Marotta" wrote in message ... While I had my panel apart the other day, I noticed the RJ jack in the back of the 302. Since I had half a Cambridge cable, I plugged it in, powered up, and measured voltage across the red and black leads - 5v! I took a standard USB cable that fits the Mio, cut it, and measured the red and black leads - again, 5v! Tomorrow, I'll connect the two cables together and run the Mio of the ship's batteries. Dan |
Well... All the Mio specs I could find are that it has a 750 mAH battery
which should last for 2.5 hours (and I know from experience that that is about right). At 5 volts that would indicate a current draw of 288 mA. I called Mio tech support and they confirmed that number so running the Mio from a 900 mA port on the 302 should be no problem at all. Thanks to Paul, for raising a red flag, and to Dave for describing his setup. "Dan Marotta" wrote in message ... Why are my posts red (color, at least on my laptop)? Thanks, Paul - I did not consider looking up the specs, which I will do. Dave, I read in the 302 manual about the 0.9A internal fusing in the 302. The cigarette lighter power cord that comes with the Mio is terminated with a mini USB connector so there should be no power/data issues. The data lines are not connected in this case. I will try to find the power requirements of the Mio online. I opened it up and it has a small (physically) battery so I suspect its power needs aren't too big. I could wire a 12v power cord into the main bus of the glider, but that's large and there's not a lot of room inside the LAK's panel. Besides, simply plugging in is so much easier! I'll report back what (if anything) I find. "Paul Remde" wrote in message ... Hi, I stand corrected. Paul Remde "ZL" wrote in message m... The 302 manual (pg 25) says pin 4 of the RJ11 is "+5V = Device power – fuse-limited to 0.9 Amp" pin 6 and 8 of the DB-9 connector are "+5 volt power from 302 to connected device; fuse-limited to 0.9 Amp" I've used the DB-9 connector on my 302 to provide +5V power to an iPAQ for 7 years now. Cambridge and others have sold connectors for that purpose for a long time. I also have a 303 hooked up to the RJ11 plug. Manual is available at the Cambridge website. -Dave On 11/1/2011 6:33 PM, Paul Remde wrote: Hi Dan, That is a very bad idea! The RJ connector on the back of the 302 is for connection to the 303 LCD display. The 303 is a low voltage device. Your Mio is not. I'm not certain, but I fear you will fry something in the 302. Best Regards, Paul Remde "Dan Marotta" wrote in message ... While I had my panel apart the other day, I noticed the RJ jack in the back of the 302. Since I had half a Cambridge cable, I plugged it in, powered up, and measured voltage across the red and black leads - 5v! I took a standard USB cable that fits the Mio, cut it, and measured the red and black leads - again, 5v! Tomorrow, I'll connect the two cables together and run the Mio of the ship's batteries. Dan |
| Trying again: Collings Foundation B-17 at Newcastle Airport inDelaware - B-17 cockpit.jpg - B-17 cockpit.jpg (1/5) | Jim Breckenridge | Aviation Photos | 1 | August 30th 08 08:36 PM |
| Trying again: Collings Foundation B-17 at Newcastle Airport in Delaware - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) | Go-dot | Aviation Photos | 0 | August 29th 08 12:39 AM |
| Wings of Freedom B-17 Wilmington, DE - B-17 cockpit.jpg - B-17 cockpit.jpg (1/5) | Waldo.Pepper[_2_] | Aviation Photos | 0 | August 28th 08 11:31 PM |
| Wings of Freedom B-17 Wilmington, DE - B-17 cockpit.jpg - B-17 cockpit.jpg (0/5) | Go-dot | Aviation Photos | 0 | August 28th 08 10:37 PM |
| Powering JSF: One Engine Is Enough. | Mike[_7_] | Naval Aviation | 42 | February 14th 08 10:53 PM |
