Hi All,
I have been looking for my first aircraft, and I came across one that looked promising, except that it is registered outside the U.S. Is this something that I should completely avoid? How do you go about getting it registered in the U.S.? Are there certain countries that are better than others (ie. a drug cartel plane from Columbia vs. a plane from Canada)? The plane is in Portugal. The seller is paying for freight. Should I investigate or run the other way? Thanks, Adam |
You may check the archives, but I think the amount of scariness factor is
pretty high. One definite - They bring the plane here BEFORE you pay, and it is subject to inspection. Also, you can't likely borrow money on the plane until after it has an N number. You will want someone with a GREAT reputation to go through the logs and do the inspection. Your seller has got to understand that some repairs he made over seas may have to be redone due to improper log entries or records. Also, someone with good experience will likely be needed to even get the N number. Other ugly stuff could be in this deal as well depending on the type of plane. I am assuming since this is your first that this is a popular model? Rare planes have rare parts, and can make ownership interesting. So, in the end, why this particular plane? The euro is high, so I find it hard to believe this is a great deal for the seller. "The Weiss Family" wrote in message ... Hi All, I have been looking for my first aircraft, and I came across one that looked promising, except that it is registered outside the U.S. Is this something that I should completely avoid? How do you go about getting it registered in the U.S.? Are there certain countries that are better than others (ie. a drug cartel plane from Columbia vs. a plane from Canada)? The plane is in Portugal. The seller is paying for freight. Should I investigate or run the other way? Thanks, Adam |
![]() So, in the end, why this particular plane? The euro is high, so I find it hard to believe this is a great deal for the seller. Its a 172 Hawk XP 500SMOH 3000TT for $12K. I've been looking at older 172's for $30K. If it really is as advertised. I couldn't afford an XP any other way! |
![]() "The Weiss Family" wrote in message ... So, in the end, why this particular plane? The euro is high, so I find it hard to believe this is a great deal for the seller. Its a 172 Hawk XP 500SMOH 3000TT for $12K. I've been looking at older 172's for $30K. If it really is as advertised. I couldn't afford an XP any other way! If you cannot afford a Hawk any other way, you likely cannot afford this Hawk. The list of things that can go wrong can quickly add up over the 20k savings. You really cannot afford the risk that comes with trying to save the money. Leave this kind of deal to an A&P or shady broker with a cousin at the FSDO.. IMO you would be better off borrowing the money for a Hawk of more known value, or reexamining if you really need a Hawk. Assuming you want the Hawk for short field work, perhaps you could buy a used homebuilt that would fit the bill. Also, remember that a 172 is really a much more expensive plane. You are buying old to save costs, but the parts still costs the same (you just need more of them). Buying a 30k old plane can easily mean another 10k to keep it flying safely! Perhaps you should look into a really nice 152, or cherokee 140? Get a partner? |
![]() If you cannot afford a Hawk any other way, you likely cannot afford this Hawk. The list of things that can go wrong can quickly add up over the 20k savings. You really cannot afford the risk that comes with trying to save the money. Leave this kind of deal to an A&P or shady broker with a cousin at the FSDO.. I'm starting to realize that just getting it registered could involve a bit of work. Your probably right here. IMO you would be better off borrowing the money for a Hawk of more known value, or reexamining if you really need a Hawk. Assuming you want the Hawk for short field work, perhaps you could buy a used homebuilt that would fit the bill. Also, remember that a 172 is really a much more expensive plane. You are buying old to save costs, but the parts still costs the same (you just need more of them). Buying a 30k old plane can easily mean another 10k to keep it flying safely! Perhaps you should look into a really nice 152, or cherokee 140? Get a partner? I fly out of MEV, which is at 4700 MSL. In the summer the density altitude can be much higher, and it is surrounded by mountains. I would really like the extra horsepower. A 152 probably wouldn't fit my needs. A 140 (maybe with the 160 conversion) would be better. I've also been looking at a Musketeer. It needs radios, but it has 5 SMOH on the IO-346. Any opinions about this bird? Thanks, Adam |
![]() "The Weiss Family" wrote in message ... If you cannot afford a Hawk any other way, you likely cannot afford this Hawk. The list of things that can go wrong can quickly add up over the 20k savings. You really cannot afford the risk that comes with trying to save the money. Leave this kind of deal to an A&P or shady broker with a cousin at the FSDO.. I'm starting to realize that just getting it registered could involve a bit of work. Your probably right here. IMO you would be better off borrowing the money for a Hawk of more known value, or reexamining if you really need a Hawk. Assuming you want the Hawk for short field work, perhaps you could buy a used homebuilt that would fit the bill. Also, remember that a 172 is really a much more expensive plane. You are buying old to save costs, but the parts still costs the same (you just need more of them). Buying a 30k old plane can easily mean another 10k to keep it flying safely! Perhaps you should look into a really nice 152, or cherokee 140? Get a partner? I fly out of MEV, which is at 4700 MSL. In the summer the density altitude can be much higher, and it is surrounded by mountains. I would really like the extra horsepower. A 152 probably wouldn't fit my needs. A 140 (maybe with the 160 conversion) would be better. I've also been looking at a Musketeer. It needs radios, but it has 5 SMOH on the IO-346. Any opinions about this bird? Thanks, Adam Aha, I forgot the other reason for the extra hp. No opinion about that plane in particular but you have managed to jump right into another ugly territory: "The For Sale Overhaul" You will want to double triple check that the shop doing the overhaul is of the FINEST reputation. Unfortunately, the best way to do this is asking FBO's and aviation shops that may see him as a competitor. It is common for people to have an overhaul done as cheaply as possible before selling a plane. They do this because there are more people willing to buy the plane that way than to buy the runout plane, and because the Blue Book value of a low time engine can easily be higher than the cost of overhauling cheaply. Other than that, the Musketeer is a Beech, so the parts costs can be a Beetch. I am not sure if it has been orphaned, or how easy it is to find parts. By reputation the only downside to a Musketeer seems to be it is a bit slow, which is likely due to the roominess. A fair trade in my opinion. If you have a local EAA chapter, you should seriously consider going to a meeting. EAA folks not only do the homebuilt thing. An EAA chapter can be your best source of info for how to fly cheaply, even in certified planes. |
In article , The Weiss Family wrote:
I've also been looking at a Musketeer. It needs radios, but it has 5 SMOH on the IO-346. The IO-346 is an orphaned engine, and since you were looking at a Hawk XP due to density altitude issues, you'll have the same climb problem with a IO-346 engined Mouse as you would with a regular C172. The Musketeer to look for is actually called a Sundowner, and has a 180hp engine which isn't orphaned. There's also the 200hp Super Musketeer, but these are a bit hard to find. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
![]() How do you go about getting it registered in the U.S.? Assuming the aircraft is a US manufactured plane with a type certificate. First the aircraft is "deregistered" by the governing authority of its country of origin. Next the US buyer presents evidence of this deregistration, a bill of sale, and applies for a US registration. Now the buyer contacts a Designated Airworthiness Representative, or his local FSDO and arranges for a type certificate conformity inspection. An annual inspection must be completed within 30 days of the conformity inspection. Sounds easy huh??? Looks like a weld on the engine mount no 337 huh---- Is that air box original to the airplane?? I don't see any numbers--prove that it conforms to the TC. What kind of a log entry is that for those ADs? it doesn't conform to our regulations, do all the ADs over again What is that sooper--dooper auto pilot doing on this aircraft??? field approval or yank it out. It can be painless or terribly painful I've seen both ways. I've got one sitting behind my garage with the wings pulled. Registration was completed, corrosion on the spar cap discovered during the inspection process---The owner will perhaps part it out--- Another from Canada cost almost as much as the purchase price to certify. The owner could have had a flying plane in half the time for half the money by buying US. Cheers: Paul |
Paul Anton wrote:
How do you go about getting it registered in the U.S.? Assuming the aircraft is a US manufactured plane with a type certificate. First the aircraft is "deregistered" by the governing authority of its country of origin. Next the US buyer presents evidence of this deregistration, a bill of sale, and applies for a US registration. Now the buyer contacts a Designated Airworthiness Representative, or his local FSDO and arranges for a type certificate conformity inspection. An annual inspection must be completed within 30 days of the conformity inspection. Sounds easy huh??? Looks like a weld on the engine mount no 337 huh---- Is that air box original to the airplane?? I don't see any numbers--prove that it conforms to the TC. What kind of a log entry is that for those ADs? it doesn't conform to our regulations, do all the ADs over again What is that sooper--dooper auto pilot doing on this aircraft??? field approval or yank it out. It can be painless or terribly painful I've seen both ways. I've got one sitting behind my garage with the wings pulled. Registration was completed, corrosion on the spar cap discovered during the inspection process---The owner will perhaps part it out--- Another from Canada cost almost as much as the purchase price to certify. The owner could have had a flying plane in half the time for half the money by buying US. Why bother registering it here/ Can't he own and fly a foreign-registered aircraft here? AFter all, plenty of n-number planes are based in and flying around europe, I recall there was a discussion of that in this newsgroup several months ago. http://groups.google.com/groups?hl=e...edu%26rnum%3D1 or http://tinyurl.com/2xntl Why couldn't the same thing be done in reverse? OK, it may be prohibitively expensive or annoying, but still.... |
In article , TTA Cherokee Driver wrote:
Why bother registering it here/ Can't he own and fly a foreign-registered aircraft here? AFter all, plenty of n-number planes are based in and flying around europe, I recall there was a discussion of that in this newsgroup several months ago. The reason it's done quite a lot in Europe is many people go to the US for their pilot certificates. If you have a US certificate, you can fly an N numbered plane anywhere. Because FAA certificates are quite common, and because many people don't want to go through the hassle of getting a JAR instrument rating, so are N numbered planes. Therefore, the support (FAA mechanics and AIs) are also available. Going the other way, virtually no one in the US has a JAA license and virtually no mechanics will be able to work on a Portugese registered aircraft. Therefore you can't get it maintained. You can't fly it on your FAA certificate. If you have a JAA certificate you can only fly it till annual comes up, at which point you'll need a JAA mechanic to work on it, and you won't be able to find one. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
