I am a watchmaker in Baltimore who specializes in mechanical aircraft clocks
for collectors. It dawned on me that I could do something useful and make my services known to owners and restorers of vintage aircraft. While I can arrange to have clocks needing certification (non-experimental aircraft) sent to a licensed repair facility that would then contract with me, I prefer to look to the owners of exempt aircraft first. My question is, where should I advertise? I just joined EAA to get the magazine and will likely take the Vintage and Warbird mags as well. I have no clue if these mags have classified ads and display ads are not practical for my service. Any thoughts will be appreciated. -- Regards, Dewey Clark http://www.historictimekeepers.com Ebay Sales: Restorations, Parts for Hamilton M21s, Products for Craftsmen Makers of Historic Timekeepers Ultrasonic Clock Cleaning Solution |
for collectors. I could do something useful and make my services known to owners and restorers of vintage aircraft. While I can arrange to have clocks needing certification (non-experimental aircraft) sent to a licensed repair facility that would then contract with me, I prefer to look to the owners of exempt aircraft first. My question is, where should I advertise? I just joined EAA to get the magazine and will likely take the Vintage and Warbird mags as well. I have no clue if these mags have classified ads and display ads are not practical for my service. We are all "experimental" and we sure are "collectors" so don't limit yourself. Ask the question, just that, on this forum: Which airplanes must have a certified clock? Instrument flying would be my guess, but ask. Type clubs. All type clubs I have ever accessed would like to know of the capability, limitations, and prices for overhaul. Examples; Cessna170.com (I think) Cessna140.com (I know) http://www.cessna120-140.org/ (I know) If you go to those sites, you can arrange to discuss ads and such in newsletters and/or on-screen. Most have a search function and you can type in "clock" and find the strings where the question was raised as to where to send them. You can append a new message to the string and that will show up as "new" item in the forums. Trade-A-Plane has both a widely read twice a month printing, and is THE place most owners go to find out where to get something done. Note, especially, the instrument outfits, some of whom would like to have a resource like yours. List what you can do. Do you have the lamps for the mil-spec WWII clocks? I have one by my elbow that does not run long anymore, but its a nice friend to have. Its an aerosonic 8-day clock with the weirdest arrangement of the timer portion reset...beyond my fixing for sure, and has (memory) three volt lamps inside with a power connector to them. Neal |
![]() Ask YOURSELF the question ... where are the requirements for a clock to have some sort of certification? Last I looked, the only requirements were for the clock to have a "sweep second hand", which has later been interpreted to be a digital readout of seconds. Ask YOURSELF the question ... where in the regulations is the definition of "certified" for ANY application. Jim (COUGARNFW) shared these priceless pearls of wisdom: - -Ask the question, just that, on this forum: Which airplanes must have a -certified clock? Instrument flying would be my guess, but ask. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Because if you call the FAA they'll tell you they need certification,
rather than spoil our horologists, let everyone else ask themselves the question of whether or not they're going to put that clock back into the panel of their certificated aircraft after they get it up and running properly. I know I absolutely would never do such a thing, the aircraft may fall out of the sky trying to give time! So for me there is no need to worry about any jerkie certification. The moronic thing is that a CRS will send him clocks to repair and they'll mark them up 5 or 6 times and sell them with a cert. On Wed, 16 Jun 2004 08:13:53 -0700, Jim Weir wrote: Ask YOURSELF the question ... where are the requirements for a clock to have some sort of certification? Last I looked, the only requirements were for the clock to have a "sweep second hand", which has later been interpreted to be a digital readout of seconds. Ask YOURSELF the question ... where in the regulations is the definition of "certified" for ANY application. Jim (COUGARNFW) shared these priceless pearls of wisdom: - -Ask the question, just that, on this forum: Which airplanes must have a -certified clock? Instrument flying would be my guess, but ask. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
![]() Stu Gotts wrote: Because if you call the FAA they'll tell you they need certification, That's not true. There are several battery-powered clocks which are not "certified" that directly replace the old windup models. The only time certification issues come into play is if you tie into the aircraft electrical system. Even that may not be true in all FSDOs (but it is with the clowns at Teterboro). George Patterson None of us is as dumb as all of us. |
Thanks, this is good info. No, I do not have lamps; the WWII A/C clocks I
have serviced (Hamilton/Elgin 37500, Elgin, Waltham CDIA, Lecoultre, etc) must have been lit by light posts; there is no internal lighting. I am certainly going to follow your suggestions. I had called Flt Stds here in Baltimore and they put in touch with SkyTech. While I can likely work through SkyTech for "normal" rated planes (non-experimental class) that require documented instruments for IFR, it is easier to work with those who own exempt aircraft. But most "normal" rated aircraft use electronic clocks these days anyway. As to what I can do. I make parts. In addition to the examples parts manufacture I show on my website, I make mainsprings to replace those broken in service and which are now obsolete. For instance, for the Hamilton/Elgin 37500 elapsed time clock, there is a spring of the correct length and thickness, but too high. I run this through my surface grinder and then spot weld the correct form of barrel attachment on the free end. I did have NOS 60 year old springs for this clock, but they tended to break about two weeks after the clock was returned. Again, thanks. If others have thought, I would like to hear them. I will be out of town for a few days so I won't be able to respond immediately, but I will. -- Regards, Dewey Clark http://www.historictimekeepers.com Ebay Sales: http://cgi6.ebay.com/aw-cgi/eBayISAP...ems&userid=dsc Restorations, Parts for Hamilton M21s, Products for Craftsmen Makers of Historic Timekeepers Ultrasonic Clock Cleaning Solution "COUGARNFW" wrote in message ... I am a watchmaker in Baltimore who specializes in mechanical aircraft clocks for collectors. I could do something useful and make my services known to owners and restorers of vintage aircraft. While I can arrange to have clocks needing certification (non-experimental aircraft) sent to a licensed repair facility that would then contract with me, I prefer to look to the owners of exempt aircraft first. My question is, where should I advertise? I just joined EAA to get the magazine and will likely take the Vintage and Warbird mags as well. I have no clue if these mags have classified ads and display ads are not practical for my service. We are all "experimental" and we sure are "collectors" so don't limit yourself. Ask the question, just that, on this forum: Which airplanes must have a certified clock? Instrument flying would be my guess, but ask. Type clubs. All type clubs I have ever accessed would like to know of the capability, limitations, and prices for overhaul. Examples; Cessna170.com (I think) Cessna140.com (I know) http://www.cessna120-140.org/ (I know) If you go to those sites, you can arrange to discuss ads and such in newsletters and/or on-screen. Most have a search function and you can type in "clock" and find the strings where the question was raised as to where to send them. You can append a new message to the string and that will show up as "new" item in the forums. Trade-A-Plane has both a widely read twice a month printing, and is THE place most owners go to find out where to get something done. Note, especially, the instrument outfits, some of whom would like to have a resource like yours. List what you can do. Do you have the lamps for the mil-spec WWII clocks? I have one by my elbow that does not run long anymore, but its a nice friend to have. Its an aerosonic 8-day clock with the weirdest arrangement of the timer portion reset...beyond my fixing for sure, and has (memory) three volt lamps inside with a power connector to them. Neal |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | December 2nd 04 07:00 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
