Complex / High Performance / Low Performance
Old June 29th 04, 02:23 AM
R.T.
Default Complex / High Performance / Low Performance
Good day all,
After reading some older posts with regards to aircraft purchasing allot of
discussion seems to come up about Complex and High Performance aircraft.
My question is this? Is a 172 RG classified as a Complex aircraft? and a 182
fixed gear classified as a non-complex High Performance?
For my needs a decent payload is going to be important, so I am considering
purchasing a 182 or possibly a Cherokee 6 (which would suit me even better).
Any opinions on either of these aircraft good or bad would be appreciated.
Rob T
Old June 29th 04, 02:59 AM
Tom Sixkiller
"R.T." brt5ATexeculink.com wrote in message
Good day all,
of
182
considering
better).
AIUI, a "complex" aircraft is one with a constant speed prop. A "high
performance" aircraft is one with 200HP or more.
HTH.
Old June 29th 04, 03:46 AM
G.R. Patterson III
And retractable gear. And flaps.
George Patterson
None of us is as dumb as all of us.
Old June 29th 04, 08:00 AM
Troy Towner
Actually it has to have 201 hp or more... 200 is not high perf.
"Tom Sixkiller" wrote in message
Good day all,
of
182
considering
better).
appreciated.
HTH.
Old July 2nd 04, 07:51 PM
Russell Kent
Look, if you're going to nitpick, at least get it right. A high performance
airplane (under US FAA rules) is one which has an engine of greater than 200
HP. So a 200.5 HP engine is high performance, as is a 200.1 HP engine, as
is a 200.00000001 HP engine. The magic number is " 200" not " = 201".
See FAR 61.31
http://www.airweb.faa.gov/Regulatory...R.nsf/0/283B12
B7EA4B82BD86256959004B99F0?OpenDocument
Russell Kent
Old June 29th 04, 03:22 AM
Ron Rosenfeld
On Mon, 28 Jun 2004 21:23:48 -0400, "R.T." brt5ATexeculink.com wrote:
Good day all,
Rob T
A "complex" airplane is an airplane that has a retractable landing gear,
flaps, and a controllable pitch propeller; or, in the case of a seaplane,
flaps and a controllable pitch propeller.
A high-performance airplane is an airplane with an engine of more than 200
horsepower.
So, for example, a Piper Arrow, or an older Mooney like mine, with a 200 hp
engine, is complex but NOT high performance.
Old June 29th 04, 03:27 AM
Joe Johnson
Complex: retractable gear, movable flaps, and constant speed prop (all 3)
High performance: greater than 200 horsepower (200 HP or less is not high
performance)
Old June 29th 04, 03:29 AM
Brenor Brophy
A complex (land) plane has to have retractable gear AND flaps AND a constant
speed prop. If any one is missing then its not a complex plane. So a 172RG
would NOT be a complex plane because it has a fixed pitch prop.
A fixed gear 182 would be high performance but would NOT be complex because
it doesn't have retractable gear.
Here is the FAR:
Sec. 61.31
(e) Additional training required for operating complex airplanes. (1) Except
as provided in paragraph (e)(2) of this section, no person may act as pilot
in command of a complex airplane (an airplane that has a retractable landing
gear, flaps, and a controllable pitch propeller; or, in the case of a
seaplane, flaps and a controllable pitch propeller),
(f) Additional training required for operating high-performance airplanes.
(1) Except as provided in paragraph (f)(2) of this section, no person may
act as pilot in command of a high-performance airplane (an airplane with an
engine of more than 200 horsepower),
-Brenor
Good day all,
of
182
considering
better).
Rob T
Old June 29th 04, 06:04 AM
BTIZ
I was thinking the C172RG I used to fly had a controllable prop... mmmm
yep... sure enough.. here's the old UND check list complete with Prop cycles
on the before takeoff checks.. and MP/RPM for cruise settings.. I can't
find the reference, but it might have been 180HP..
so it would be Complex, but not High Performance.. C 172RG, Cutlass.. it was
a sweet flying Skyhawk.. did not cruise like a standard gear dragger..
BT
"Brenor Brophy" wrote in message
m...
constant
because
Here is the FAR:
Sec. 61.31
Except
pilot
landing
an
-Brenor
Good day all,
of
182
considering
better).
appreciated.
Rob T
Old June 29th 04, 06:03 PM
Newps
"BTIZ" wrote in message
news:hL6Ec.5949$z81.3182@fed1read01...
cycles
was
I was at GFK when UND still had the Cessna's. What years were you there?
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
High Performance Single Engine Choices O. Sami Saydjari Owning 82 January 6th 04 07:32 PM
More on High Performance Insurance Jay Honeck Owning 25 December 15th 03 03:24 AM
High performance homebuilt in the UK NigelPocock Home Built 0 August 18th 03 08:35 PM
FAR:Safety Pilot & High Performance/Complex? Jim General Aviation 51 August 18th 03 03:08 PM
