Winter 57mm Altimeter
Old November 21st 11, 08:58 AM posted to rec.aviation.soaring
Ventus2NZ
Default Winter 57mm Altimeter
I have just had my Winter 57mm altimeter fail it's instrument check.
From what I can ascertain, this is not all that uncommon. Does anyone
have any ideas or suggestions of a suitable 2-1/4" alternative.
Old November 21st 11, 10:53 AM posted to rec.aviation.soaring
Croft Brown
I am not sure there is an alternative. PZL only do the 80mm type.
Croft
Old November 21st 11, 10:54 AM posted to rec.aviation.soaring
Croft Brown
Croft
Old November 21st 11, 12:43 PM posted to rec.aviation.soaring
Paul Remde
Hi,
What was the criteria for the failure of the check? The Winter altimeters
are not, and cannot be as accurate as larger altimeters. Winter doesn't
claim they are. But they are fine for most glider pilots. I sometimes get
complaints about them from instrument rated power pilots, who expect them to
perform like a larger altimeter.
You can see the specifications on my web site he
http://www.cumulus-soaring.com/winter.htm#W-4555
Or perhaps the unit just needs repair at Winter. They support their
products very well. A repair would cost much less than a new unit.
I fly with 2 Winter 4555 altimeters in our DG-1000 and I'm happy with them.
But I suppose I'm biased because I sell and support them.
In the last year I heard of a new brand that offers 57mm altimeters for use
in certificated aircraft. I inquired and found that they cost over
$3000!!!! Wow! That is the only other option I am aware of. I don't
remember the brand name, but I believe United Instruments now offers them as
well for even more money.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Ventus2NZ" wrote in message
Old November 21st 11, 03:22 PM posted to rec.aviation.soaring
Tim Mara
this isn't true..and I don't think Winter would be very pleased to know they
are being misrepresented...the "certified" Winter altimeters (Winter also
does make a variety of instruments without EASA approval) meet and are
certified to EASA standards TS 10.220/48 like and accepted the same as US
TSO and can be used in certified aircraft....there were some modifications
made in recent years to these altimeters to improve performance in that some
older version did have occasionally an issue with jumping a cog in the
barometric adjustment gears but even the older versions can be repaired and
calibrated back to the required specifications.
You can send your altimeter back to the manufacturer (I also accept winter
instruments here that I ship for my customers to the manufacturer for
repairs) for update, overhaul and re-calibration if needed and you'll find
they are very good with their support and service and always stand behind
every product they produce. Winter does recommend periodic re-calibration,
just like nearly all altimeter manufacturers
tim
Please visit the Wings & Wheels website at www.wingsandwheels.com
Winter "Paul Remde" wrote in message
Hi,
get complaints about them from instrument rated power pilots, who expect
them to perform like a larger altimeter.
them. But I suppose I'm biased because I sell and support them.
use in certificated aircraft. I inquired and found that they cost over
as well for even more money.
Best Regards,
Paul Remde
__________ Information from ESET NOD32 Antivirus, version of virus
signature database 6648 (20111121) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 6648 (20111121) __________
http://www.eset.com
Old November 21st 11, 06:12 PM posted to rec.aviation.soaring
Paul Remde
Hi Tim,
Which part of my statement below wasn't true? I love Winter altimeters and
all their products. But the specifications sheet shows that they have less
precision than larger altimeters - which is fine with me and most glider
pilots. I didn't say they were bad, just not as precise. Customers that
understand that are very happy with them - myself included.
Paul Remde
"Tim Mara" wrote in message
they are being misrepresented...the "certified" Winter altimeters (Winter
also does make a variety of instruments without EASA approval) meet and
are certified to EASA standards TS 10.220/48 like and accepted the same as
US TSO and can be used in certified aircraft....there were some
modifications made in recent years to these altimeters to improve
performance in that some older version did have occasionally an issue with
jumping a cog in the barometric adjustment gears but even the older
versions can be repaired and calibrated back to the required
specifications.
find they are very good with their support and service and always stand
behind every product they produce. Winter does recommend periodic
re-calibration, just like nearly all altimeter manufacturers
tim
Hi,
altimeters are not, and cannot be as accurate as larger altimeters.
Winter doesn't claim they are. But they are fine for most glider pilots.
I sometimes get complaints about them from instrument rated power pilots,
who expect them to perform like a larger altimeter.
Best Regards,
Paul Remde
http://www.eset.com
http://www.eset.com
Old November 21st 11, 10:49 PM posted to rec.aviation.soaring
Tim Mara
the statement "not as precise" and compared to?
tim
Hi Tim,
and all their products. But the specifications sheet shows that they have
less precision than larger altimeters - which is fine with me and most
glider pilots. I didn't say they were bad, just not as precise.
Customers that understand that are very happy with them - myself included.
Paul Remde
as US TSO and can be used in certified aircraft....there were some
with jumping a cog in the barometric adjustment gears but even the older
specifications.
winter instruments here that I ship for my customers to the manufacturer
for repairs) for update, overhaul and re-calibration if needed and
you'll find they are very good with their support and service and always
stand behind every product they produce. Winter does recommend periodic
tim
Hi,
pilots. I sometimes get complaints about them from instrument rated
power pilots, who expect them to perform like a larger altimeter.
them as well for even more money.
Best Regards,
Paul Remde
http://www.eset.com
http://www.eset.com
signature database 6649 (20111121) __________
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 6649 (20111121) __________
http://www.eset.com
Old November 21st 11, 01:42 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Recertification of altimiters is only required if you plan on doing
some IFR flying, not likely in a glider. Just check it against all
the other altitude indicators you have in the modern cockpit, GPS,
Transponder, computer. I find the small altimiter a bit hard to read
at a glanse, so I leave the SN-10 cursor on altitude (double spaced)
on my home page. The small altimiter is just in there to comply with
the requirement to have a pressure altimiter in the cockpit. BTW, I
use the UMA non certified altimiter from Aircraft Spruce for about
$200 bucks.
Cheers,
JJ
Old November 21st 11, 06:55 PM posted to rec.aviation.soaring
sisu1a
Does anyone have any ideas or suggestions of a suitable 2-1/4" alternative.
Aerosonic makes some really nice 2-1/4 units.
-Paul
Old November 21st 11, 07:08 PM posted to rec.aviation.soaring
Ventus2NZ
Thank you for all your replies.
My Ventus 2cT is operated under the manufacturers type certificate in
New Zealand, therefore it has to have certified instruments fitted.
The instruments must pass the 2 yearly calibration checks. At 18,000
ft mine is 320 feet out. The calibration table requires it to be +/-
120 ft at that altitude. At sea level to around 10,000 ft it is good
then the calibration goes way out and come right again through 21,000
ft. (I know they are only certified to 20,000 ft).
Thanks again, I think I may just order a new one and get a calibration
check done before I install it in my glider.
Winter 57mm Altimeter for sale Juanman Soaring 0 May 13th 10 08:06 PM
Winter altimeter for sale [email protected] Soaring 3 January 25th 10 09:39 PM
WTB: used 57mm Altimeter OR swap for 80mm Altimeter joesimmers Soaring 0 November 3rd 09 11:59 AM
Winter altimeter error bumper Soaring 6 October 29th 04 03:32 PM
WTB: Winter 2 1/4" altimeter Greg Arnold Soaring 1 May 1st 04 07:35 PM
