c150 rudder stop AD
Old July 9th 04, 12:20 PM
Brendan Grace
Default c150 rudder stop AD
Can anyone describe the way the rudder stop mod on Cessna 150s
should look? I went to rent a 150 and the way the AD was
incorporated didn't look right so I passed on the flight. The
stops were attached to the rudder horn (? the curved metal
portion) by drilling three holes and riveting the stops to the
horn. It looked brutal, but I don't know how it should look. I
was concerned that such a small metal horn had been drilled into
in terms of lost strength. Any insight would be appreciated.
Brendan
Old July 9th 04, 01:19 PM
Matthew P. Cummings
I think it sounds like it was done right. It's not an AD by the way, if
you want more facts on it you can if you're a member of the
http://www.cessna150-152.com/ club actually view the SEB01-1A and there
are two service kits, they are SK152-24 and SK 152-25 and the kit used
depends on whether you have a forged metal bulkhead or a sheet metal
bulkhead.
Old July 9th 04, 05:32 PM
Brendan Grace
Thanks, unfortunately I'm not a member of the group as I only
rent on occasion.
Brendan
"Matthew P. Cummings" wrote in
message
news
I
into
the way, if
and there
kit used
metal
bulkhead.
Old July 9th 04, 05:38 PM
Brendan Grace
I just found this link if anyone was interested:
http://www.tc.gc.ca/tcss/tsb/air/200...AL_2000_04.htm
Brendan
"Brendan Grace" wrote in message
rent on occasion.
Brendan
message
news
look.
I
into
appreciated.
the way, if
and there
kit used
sheet
metal
bulkhead.
Old July 10th 04, 04:23 AM
Matthew P. Cummings
That link is not the SEB that Cessna issued. It does describe why the SEB
was issued later on however.
If you want to see the bulletin, ask the FBO for it. Every owner got one
mailed to them, or should have.
Old July 11th 04, 05:16 AM
Dan Thomas
"Matthew P. Cummings" wrote in message gray.net...
It IS an AD in Canada, for those Canadians lurking here. A Canadian
150 went down around three years ago, with the rudder stop locked over
the stop bolt head during a training spin. The rudder hinge bushings
as well as the stops were all shot and the stop was able to travel far
enough to catch behind the bolt head and lock the rudder at full
deflection. I believe the bellcrank was a bit loose, too.
The new stops are much larger and the stop bolt has a much larger
head on it.
Dan
A Bush C150? With Leading Edge Slats? [email protected] Home Built 33 May 27th 04 05:39 PM
B2 Split Rudder Emilio Military Aviation 8 April 12th 04 10:43 AM
P-51 Rudder Aerodynamics Hawkeye Hughes Home Built 1 March 15th 04 09:24 AM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 02:18 PM
