Wet vac pump question
Old July 11th 04, 02:20 AM
JFLEISC
Default Wet vac pump question
In my continuing effort to plug all the oil leaks in my Continental 0-300 I
have a final question about wet vacuum pumps. How much oil out the vent is too
much? This is a '61 C-172 with the factory standard oil recovery system off the
wet vac. About twice as much oil comes out the vacuum vent as out the engine
vent. Is that normal and if not what is the fix? Are there seals in the pump
that wear out or something? Any info would be appreciated.
Old July 11th 04, 02:10 PM
Rip
Wet pumps have no seals, per se, and in fact get their lubricating oil
from the accessory pad they are driven from. On many engines this means
that the seal is removed from the drive pad. Internally, the pumps have
either steel (ARO), or heavy graphite (Pesco, Garwin) vanes that do
eventually wear out, but you would tend to see this wear indicated by
poor vacuum, rather than extra oil. The typical "output" of these pumps
is a lot of air with a fair amount of oil entrained, almost like the
spray from an aerosol can. The engine breather vent should have almost
no oil at all, and at extremely low pressure (inches of water, rather
than PSI). Unfortunately, most air/oil separators don't do a very good
job. I've tried 4 or 5 different units, and only the Airwolf did what it
was advertised to do.
Old July 11th 04, 10:01 PM
JFLEISC
I was afraid of that. Cheaper to go with a dry pump, I think.
Old July 11th 04, 10:27 PM
Newps
"JFLEISC" wrote in message
Then you have no experience with a wet pump. Dry pumps are an absolute
joke. Owners rave about getting 500 hours out of one. I have a Garwin wet
pump on my 182. I give it exactly zero thought. No oil on the belly from
the pump either.
Old July 12th 04, 02:09 AM
JFLEISC
That's right, I don't. What I'm interested in right now is cutting down the oil
usage. It's not likely this plane will be used for IFR except possibly as a
trainer.
Old July 12th 04, 02:15 AM
G.R. Patterson III
trainer.
In that case, make sure you keep the old vacuum pump when you replace the pump with a
dry unit. You ought to be able to get a fair price for it.
George Patterson
In Idaho, tossing a rattlesnake into a crowded room is felony assault.
In Tennessee, it's evangelism.
Old July 12th 04, 02:39 AM
Newps
the oil
a
trainer.
Any wet pump that uses enough oil to be noticeable is in need of overhaul.
Old July 12th 04, 11:04 PM
Matt Whiting
Rip wrote:
Agreed. I won't fly hard IFR with a dry pump, and I laugh each time I
throw one of those Parker Hannafin "mandatory" notices in the trash,
unopened. The last wet pump I had overhauled had over 3000 hours on it,
and the overhaul facility changed the bearings, just so they could say
they had done something.
I agree. Dry pumps should be outlawed! :-)
Matt
Wet vs Dry Vacuum Pump Fastglasair Home Built 1 December 15th 04 05:17 PM
Windmilling Prop & Vacuum Pump Matt Young Instrument Flight Rules 14 October 14th 04 08:08 PM
Wet Vacuum Pump smackey Owning 6 February 24th 04 07:03 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
