Jim Weir wrote:
snip Yes, I know that alcohol left sitting in gasoline will slowly accumulate water from condensation and such, and is a variable. It will probably accumulate quite quickly from the hose the retailer sticks in the tank to sell water at a high price. regards jc LEGAL - I don't believe what I wrote and neither should you. Sobriety and/or sanity of the author is not guaranteed EMAIL - and are not valid email addresses. news2x at perentie is valid for a while. |
Jim -
I wrote an article on winter operation that was published in the Dec 1986 issue of Sport Aviation. In it I posted a chart of the approx max dissolved water in PPM in aromatics and non-aromatic fuels. It was based on some sketchy data I got from Amoco. The amount of dissolved water increases with temperature. The point that I was trying to make in the article was that severe chilling will cause some of the water to precipitate out of solution as snow, which can quickly and effectively clog the fuel screens. It happened to me. Niel Petersen |
Two years of college chemistry does not a chemist make out of me, so let's see
if anybody has the answer to this one: Until we get around to making gaskets and o-rings that will stand up to alcohol, is there a cheap and easy way to chemically (or mechanically) take the alcohol out of gasoline? Yeah, I know that we could use fractional distillation, but that's a little beyond the average home kitty-litter filter process that I was contemplating. Thoughts? Jim Roger Halstead shared these priceless pearls of wisdom: - -It seems to me if they can make the car engines stand up (more -specifically the gaskets and O-rings) then they could do the same in -aircraft systems. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
"Jim Weir" wrote in message
... Two years of college chemistry does not a chemist make out of me, so let's see if anybody has the answer to this one: Until we get around to making gaskets and o-rings that will stand up to alcohol, is there a cheap and easy way to chemically (or mechanically) take the alcohol out of gasoline? Yeah, I know that we could use fractional distillation, but that's a little beyond the average home kitty-litter filter process that I was contemplating. Thoughts? If you figure out a way, don't let Slusarczyk in on it. He'll want to put some in the muzzleloader to dilute it. Rich S. |
"Jim Weir" wrote:
Two years of college chemistry does not a chemist make out of me, so let's see if anybody has the answer to this one: Until we get around to making gaskets and o-rings that will stand up to alcohol, is there a cheap and easy way to chemically (or mechanically) take the alcohol out of gasoline? Yeah, I know that we could use fractional distillation, but that's a little beyond the average home kitty-litter filter process that I was contemplating. Thoughts? I guess you're thinking of something like SilcaGel (which has a high affinity for water), but in this case we need a substance that has a high affinity for ethanol but none for the hydrocarbons. Sounds like you need an Irish liver. :-) No, seriously, you might be able to use some of the laboratory-grade semi-permiable membranes, if you can find one that passes ethanol-sized molecules but not aromatic hydrocarbon-sized ones. Russell Kent |
How about using the differential solubility in water? Add water, shake to
dissolve the alochol in the water, allow to seperate, pour off the gasoline. Lather, rinse, repeat. Dave Russell Kent wrote: "Jim Weir" wrote: Two years of college chemistry does not a chemist make out of me, so let's see if anybody has the answer to this one: Until we get around to making gaskets and o-rings that will stand up to alcohol, is there a cheap and easy way to chemically (or mechanically) take the alcohol out of gasoline? Yeah, I know that we could use fractional distillation, but that's a little beyond the average home kitty-litter filter process that I was contemplating. Thoughts? I guess you're thinking of something like SilcaGel (which has a high affinity for water), but in this case we need a substance that has a high affinity for ethanol but none for the hydrocarbons. Sounds like you need an Irish liver. :-) No, seriously, you might be able to use some of the laboratory-grade semi-permiable membranes, if you can find one that passes ethanol-sized molecules but not aromatic hydrocarbon-sized ones. Russell Kent -- Dave Butler, software engineer 919-392-4367 |
Jim -
Yes, you can remove alcohol from a gasahol mixture, but in so doing you will have a remaining all-hydrocarbon fuel that has substantially less antiknock capability - lower octane. I don't know how much the octane reduction is but I suspect what you have left would be marginal even in a lawnmower. But to separate the mixture, simply mix the gasahol aggressively for several minutes with a substantial volume of water, then allow the mix to settle. This will allow the water to remove most of the alcohol from the mixture so that only the hydrocarbon component is left. The water at the bottom will now have the alcohol in solution. Yes, gasahol has eliminated gas line freezeup problems. But no way would I want to put it in an aircraft. You can test for alcohol in a fuel sample by mixing about 10 parts sample with 1 part of water, shaking the mixture for a minute, let it settle, and see if the apparent volume of the water has increased. If it has, you had alcohol in the original sample. I check each car-filling-station load of fuel I buy in Wisconsin, where gasahol is not mandated. The station dealer is aware of our aircraft use, but of course he is somewhat in the dark with the regulatory climate so we can't really depend on him. Otherwise I try to buy fuel from an FBO that supposedly has a certified load of Mogas. A few filling stations in Minnesota, where gasahol is otherwise mandated, and marinas will have a pump of straight gasoline for "old engines" etc on the side somewhere. Gasahol can work in a processor controlled car engine that has a closed loop system to control spark timing and mixture. An engine properly operating on gasahol will only produce about 95% of the power output of a hydrocarbon fueled engine. Non processor controlled car engines just run a little feebler, although the powers that be say they will emit less bad stuff. There is controversy on this. Airplane engines have no processor, and even if they did, giving up another 5% of the takeoff power would be out of the question for a certificated aircraft. Maybe with a reduction in allowable gross weight? But what about the reduction in octane? Still lower compression? Ugh! It doesn't make for a good solution. At any rate, aircraft fuel systems have not been made tolerant of alcohol laced fuels probably because there are so many other technical and legal obstacles to their successful use. |
The problem isn't the gaskets and o-rings. The real problem is alcohol is a
weak organic acid and corrodes metals. "Jim Weir" wrote in message ... Two years of college chemistry does not a chemist make out of me, so let's see if anybody has the answer to this one: Until we get around to making gaskets and o-rings that will stand up to alcohol, is there a cheap and easy way to chemically (or mechanically) take the alcohol out of gasoline? Yeah, I know that we could use fractional distillation, but that's a little beyond the average home kitty-litter filter process that I was contemplating. Thoughts? Jim Roger Halstead shared these priceless pearls of wisdom: - -It seems to me if they can make the car engines stand up (more -specifically the gaskets and O-rings) then they could do the same in -aircraft systems. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
![]() "Cy Galley" wrote in message news:FkdUc.307087$JR4.216248@attbi_s54... The problem isn't the gaskets and o-rings. The real problem is alcohol is a weak organic acid and corrodes metals. ++++++++++++++++++++++++++++ Isn't it also true, that alcohol dissolves the lacquers built up in the tank and fuel system? Long story short, I got two loads of gasohol (in a row) in a large motor home, and the many hundreds of gallons of gas that had been run through it, and the many times where gas had been allowed to sit for long periods of time, had deposited a large amount of lacquer in the tank. The lacquer was nicely dissolved, then deposited in the large canister filter, until there was not enough gas flow to run it at much more than an idle. It sound like a scenario that could be closely imitated in an airplane. -- Jim in NC --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.737 / Virus Database: 491 - Release Date: 8/11/2004 |
