remodel & upgrade or buy an upgraded plane?
Old August 17th 04, 02:40 AM
Dico Reyers
Default remodel & upgrade or buy an upgraded plane?
Hi,
I have a 1967 m20e super 21. It has little for instrumentation and
the radio stack is pretty weak. It certainly isn't near IFR. The
interior is original and the paint is 5/10. It'll cruise at 130kts
2200 rpm and 23"
I'm looking for opinions on whether to upgrade and have a sharp, but
old plane... or should I just wait a couple more years and purchase a
newer plane that would meet my requirement and would potentially be
faster?
I'm just wondering about the resale. If I had an old house and built
a swimming pool outside for 20,000$... if I went to sell the whole
place I'd never get that money back out of the pool. Is it the same
with airplanes?
Any advice would be appreciated.
Thanks,
-Dico
Old August 17th 04, 03:46 AM
Ben Jackson
with airplanes?
It's worse with airplanes. The value of an airplane goes up roughly
by the used value of the installed avionics. After you factor in the
cost of the radios and the installation cost you probably only get
about 50% back. If you upgrade a plane beyond its typical mission
(eg if you put a CNX-80 in a Cessna 150, or if I put weather radar in
my Comanche) you will probably recoup even less.
Plus a major upgrade like that will have the plane down for months.
It's likely you could sell it and then buy a different plane and have
less downtime.
Ben Jackson
http://www.ben.com/
Old August 17th 04, 02:19 PM
Ron Natalie
"Dico Reyers" wrote in message ...
faster?
Yep it's the same with airplanes.
If you're talking about economics, it's almost universally easier to find a plane
that's already configured the way you want it and buy that than to do the mods
yourself. Avionics and other aircraft mods have a high initial depreciation.
If you want to make sure you get it right, and you're airframe is reasonably
good, modding yours will give you more control and perhaps a better finished
product at a higher cost.
Finally, if you could find a J or later model, it will be faster.
Old August 17th 04, 06:52 PM
Rutger
"Ron Natalie" wrote in message m...
faster?
yourself.
Also keep in mind that there will likely be an enhanced market for
selling good used planes down in Florida once their insurance checks
start coming in.
Sad and cruel, but true.
There will also be a lot more good used engines, avionics and other
salvageable parts hitting the market too :-(
Old August 17th 04, 02:57 PM
G.R. Patterson III
with airplanes?
It's the same with airplanes.
George Patterson
If you want to know God's opinion of money, just look at the people
he gives it to.
Old August 17th 04, 05:16 PM
PaulH
I elected to upgrade my 69 Arrow with Garmin 430, Stec autopilot, and
Stormscope. I love the airplane to begin with, I know what I have,
and if I fly it for 5 years I figure I get my money's work even with
50% return. Used airplanes often contain nasty surprises. I did it a
year at a time, during annual, midwinter when midwest flying weather
is grim anyway. The gradual approach also lets you learn as you go
and enjoy one new piece of equipment each year.
I believe you get better return on engine and cosmetics as long as you
don't go overboard.
Old August 17th 04, 05:17 PM
PaulH
don't go overboard.
Old August 17th 04, 09:14 PM
Mark Astley
AviationConsumer had a recent article which touched on this subject.
Actually, that article was about whether or not you should buy a run
out and overhaul, or buy a plane with a newer engine. They did
mention, however, that in terms of recovering investment dollars,
interior, paint and engine are the best with avionics and other mods
at the bottom of the list. For example, they mention that avionics
typically only recover $0.30 on the dollar at resale time.
I read that to mean that if you only think you'll keep the plane a few
more years, go ahead and redo the interior and get the new paint.
Think longer time (or get out), if you want to do the panel.
good luck,
mark
(Dico Reyers) wrote in message m...
Hi,
2200 rpm and 23"
faster?
with airplanes?
Thanks,
-Dico
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 June 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 08:27 AM
Conspiracy Theorists (amusing) Grantland Military Aviation 1 October 2nd 03 12:17 AM
A Good Story Badwater Bill Home Built 15 September 3rd 03 03:00 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
