Cost to install IFR GPS in a basic IFR 172?
Old August 24th 04, 08:15 PM
C Kingsbury
Default Cost to install IFR GPS in a basic IFR 172?
Googling the group yielded little so here goes...
1979 172, overall average condition with mostly original radios and
wiring (one RT-385 recently replaced by a TKM radio, M1 Loran from a
few centuries ago)
The Cessna 300 ADF has gone flaky. The box tests fine on the bench
which suggests a wild goose chase may be in store to find the
gremlins. One of the two ILS approaches at my home field require ADF,
and a few fields I go to are ADF/GPS-only so I need one of the two.
My idea is to find a good used Apollo GX-50/GX-60 unit and replace the
ADF. No need to touch the Loran, it makes a good backup. I'll get
legal ADF and DME capability not to mention a moving map. Trying to
convince 4 other partners this is a good idea b/c it will make it
easier to sell shares in the future and even if they are VFR-only the
moving map is a big plus.
The local flight school says they've been spending an average of $6000
to do this with their birds at the local shop. Those of you who've
done this recently, any thoughts?
Bet,
-cwk.
Old August 24th 04, 08:31 PM
Roy Smith
I wouldn't waste any time or money trying to fix an ADF today.
The GX-50/60 series are perfectly reasonable units, but don't forget to
factor in the cost of maintaining the IFR database. Also, to be IFR
legal, they need to have this funky external annunciator box mounted
somewhere within the pilot's normal scan, which means you need to find a
place in the panel to mount it.
I don't know how much a GX-60 will add to the value of the plane. True,
it is an IFR approach certified GPS, but it's also a generation out of
date and doesn't have much sex appeal anymore.
My club has put in a mix of CNX-80's and GX-50/60's. The CNX is a much
more expensive unit, but it's also a much better box. I guess it all
depends on how deep your wallet is.
Old August 24th 04, 09:14 PM
Steve Robertson
Gee whiz, Roy. Can't you tell the guy how much the installs cost your club?
Steve Robertson
N4732J
Roy Smith wrote:
snip
Old August 25th 04, 01:26 AM
I don't fly IFR but I think I'd consider getting the plane instrument
certified with the least expensive older unit I could find and then
actually fly with one of the new portables such as Garmin GPS296.
Old August 25th 04, 01:41 AM
Hankal
If you are going to spend $$ to have an IFR plane the I would spend the other
10K to get a 430 Garmin GPS
Old August 26th 04, 03:46 AM
Victor J. Osborne, Jr.
Or $12k for the 530. The 480 may be the way to go if you think WAAS &
terrain are important. But these options sound like budget busters.
Thx, {|;-)
Victor J. (Jim) Osborne, Jr.
Old August 25th 04, 04:39 PM
On Wed, 25 Aug 2004 09:18:37 -0400, Dave Butler
I do fly IFR and would like an approach-cert GPS, but I can't convince my
partners. I make do with a Garmin 196, and I have to admit, the difference in
capability of the airplane vs. having an approach-cert unit is very slight.
Having something mounted in the panel vs. yoke mount would be nice.
I think the 296 has approaches. At least they're long runway extension
lines that could be used for a straight-in approach. But not
certified, I'm sure.
Old August 25th 04, 06:01 AM
C Kingsbury
Roy Smith wrote in message ...
My point exactly. Good money after bad IMHO.
A basic 1979 C-172 is not a vehicle for sex appeal. I want no-frills
utility. A 172 with an IFR GPS is a much more marketable beast than
one without, regardless of the GPS in question.
Would you put a 12k GPS install into a plane with a 172 with a 40k-ish
hull value? By the time you're done we're talking about nearly the
cost of an engine overhaul, which at 1800 tach hours may not be far
off. That will add a lot more back to the value, too. You can buy an
engine for the next guy but the avionics are for the current owner.
I guess it all
Figure somewhere between mud-puddle and pothole. Quite frankly I might
just end up repairing that damn fool ADF for just that reason.
-cwk.
Old August 25th 04, 06:50 PM
Mike H
No, no, no.... You DON'T want to try to repair that ADF.
We went that route for close to two years in our Archer, trying to
repair the Narco ADF and Navs/Coms. We just threw good money after bad.
We probably ended up sinking $2000 over a 2 year period before finally giving
in and going for a Garmin 430 and new King Nav/Com. It cost a pretty
penny (about $12000) but sure is nice now!
Mike
I guess it all
-cwk.
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 June 2nd 04 07:17 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
