Pre-buy Inspection
Old August 29th 04, 02:14 PM
Jon Kraus
Default Pre-buy Inspection
My new partner and I are looking at a 1975 Mooney M20C. It is a nicely
upgraded IFR plane with a 400 hour O-360 engine. It is a rather high
time airplane (7000) hours and the price reflects this fact. It is being
sold by the owner of the FBO we fly out of for one of his friends. They
just finished up an annual inspection on it.
My IFR instructor has owned Mooneys in the past and even had the M20C
for years. He suggested that we fly the plane to Byerly Aviation in
Peoria IL (a little over an hour flight from Indianapolis) and have them
do the pre-buy. He said it would probably cost in the $500.00 range. My
partner and I think it is a good idea too. We are both buying our first
plane and think the money would be well spent.
One of the cylinders has a compression of 62 while the others are in the
70's. This concerns me even though it is within tolerances. Of course we
would hate to buy something that needed immediate major engine work. The
plane has not flown much for the past 2 years so I am wondering if after
flying the thing a while if the compression might come back some
(probably wishful thinking I know).
I am interested in opinions or experiences in first plane purchases.
Experience with Byerly Aviation. Or comments on the engine situation I
described. Thanks!!
Jon Kraus
PP-ASEL-IA
Student aircraft purchaser
Old August 29th 04, 02:28 PM
Kyle Boatright
"Jon Kraus" wrote in message
described. Thanks!!
Jon Kraus
PP-ASEL-IA
John,
A low compression cylinder isn't a big deal, assuming everything else checks
out. Maybe the compression will come back up with use, maybe you'll need to
pull the jug and have something fixed. The pre-buy might give you the
answer to that question. In any case, pulling and repairing a cylinder
isn't *that* big of a deal.
KB
Old August 29th 04, 02:26 PM
Jon Kraus
Thanks Kyle. It would be a haggling point though. JK
described. Thanks!!
Jon Kraus
PP-ASEL-IA
John,
KB
Old August 29th 04, 02:45 PM
Steve Foley
It should not be a haggling point if you were already told about it.
Negotiations come into play when you find something that you didn't know
about.
I'd be pretty annoyed if someone flew my plane 100 miles away for a pre-buy,
and came back only to dicker about something I already disclosed.
described. Thanks!!
Jon Kraus
PP-ASEL-IA
John,
checks
need to
KB
Old August 29th 04, 03:12 PM
Jon Kraus
So as a seller you would lower the price immediately even though you
didn't know why the low reading? Example: Say as the seller you wanted
$50,000 for the aircraft before you knew of a possible engine issue.
When you found out about the low compression but didn't know why you
would lower the price? Just trying to understand why you would be
annoyed. I'm not in this to **** off the seller but I don't want to pay
for something that is already existing either. Thanks !! JK
about.
described. Thanks!!
Jon Kraus
PP-ASEL-IA
John,
checks
need to
KB
Old August 29th 04, 11:12 PM
Mike Rapoport
The seller is generally considered liable for correcting airworthiness
issues. Lower compression in one cylinder is not an airworthiness item.
Mike
MU-2
about.
pre-buy,
being
They
them
My
first
we
The
after
described. Thanks!!
Jon Kraus
PP-ASEL-IA
John,
checks
need to
KB
Old August 30th 04, 05:34 AM
tony roberts
Hi Jon
Here is my take.
I would offer my plane as is where is - faults disclosed for xxx dollars.
If you now make me an offer which I accept, based on the foregoing, I
would not look too kindly on a reduced offer because of a previously
disclosed fault.
However, if you discover a fault that I had not disclosed, then that
would merit discussion. It would not merit that I pick up the tab -
bacause we are talking about an old plane - you cannot expect new
replacements. If for example an instrument was in need of replacement I
may agree to pay up to 50%, but you are not about to get me to pay for a
new instrument.
HTH
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old August 29th 04, 03:13 PM
Jon Kraus
When you found out about the low compression, but didn't know why it was
low, you would lower the asking price say to $48,000? Just trying to
understand why you would be annoyed. I'm not in this to **** off the
seller but I don't want to pay for something that is already existing
about.
described. Thanks!!
Jon Kraus
PP-ASEL-IA
John,
checks
need to
KB
Old August 30th 04, 01:16 AM
Hankal
Not a big deal, but needs to reflect in the purchase price.
Old August 30th 04, 03:51 AM
Jon Kraus
I whole totally agree. Thanks... JK
Home Inspection Listings Patrick Glenn Home Built 4 April 26th 04 11:52 AM
Service Manual - 50 hour inspection O. Sami Saydjari Owning 1 April 8th 04 03:17 PM
51st Fighter Wing betters rating to ‘excellent’ with inspection Otis Willie Military Aviation 0 February 20th 04 11:29 PM
100 Hour Inspection Question FryGuy General Aviation 59 November 19th 03 04:01 AM
