OK... question for those in the know. I've got a KNI-520 connected to a
KNS-80 RNAV. The DME, localizer, and RNAV *distance* work fine, but the VOR needle doesn't deflect properly recently. If you try to center it, it won't stay in the center, but rather will twitch from pegged on one side to pegged on the other with a very small (5 degrees) change in the OBS ring. I'm thinking that since the head doesn't have a NAV converter, but rather tells the KNS-80 where the OBS is with encoder lines, that one of those lines might be broken/intermittent. That would mean it would think the head is in 1 of 4 (2?) positions, rather than somewhere in between. Thoughts on this? Anyone fixed such a thing? I haven't torn into the wiring yet and suspect it's intermittent (read: difficult to find). -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Check to see if your KNS80 has Mod 10 (should be stamped on the
back). I don't have the details, but this has to do with inter- mittent contact between the internal circuit boards. Loose internal contacts will produce the effects you mention. I found it cheaper to buy a yellow tagged KNS80 on eBay than to fix my old one - but it needed other repairs as well. David Johnson |
When I bought this from ebay awhile back, I checked on the mods. It
supposedly has 1-4 and 6-11 (I don't have it here in front of me). It just checked out in June on the IFR certification (go figure!). I'm guessing it's one of the connectors on the back. It could be in the radio, but I doubt it's a bad VOR receiver/converter, since the RNAV works. I think the radio's just not getting the right X/Y encoder signal from the OBS knob, so it doesn't know where to put the needle. -Cory David Johnson wrote: : Check to see if your KNS80 has Mod 10 (should be stamped on the : back). I don't have the details, but this has to do with inter- : mittent contact between the internal circuit boards. Loose internal : contacts will produce the effects you mention. I found it cheaper : to buy a yellow tagged KNS80 on eBay than to fix my old one - but : it needed other repairs as well. : David Johnson -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Mode C Indication | Jeff | Owning | 9 | May 5th 04 03:35 AM |
FS: Narco AT-50A Transponder with ACK Encoder | JR | Home Built | 0 | April 29th 04 11:33 AM |
Altitude encoder | Chad Lemmen | Owning | 9 | August 23rd 03 01:13 AM |
