Panel lights failure in Piper WarriorII
Old September 22nd 04, 09:56 AM
Piperflyer
Default Panel lights failure in Piper WarriorII
After the hurricane, I found the panel lights on the left side which should
go on with the Nav lights, are out. Nav lights do come on. Circuit braker is
in.What could be the problem? Someone might know the answer outright.
Couldn't be the bulb since all of them don't light up (unless they're
connected in series). Probably not the switch either since the wingtip Nav
lights come on. Should it be checked by a mechanic or Avionics shop or if it
is something trivial, maybe I can do it myself. Appreciate any input from
the group.
N2096L.
Old September 22nd 04, 01:40 PM
Michelle P
A ton of things could be wrong. A broken wire for beginners and a fried
dimming transistor for another.
Michelle
the group.
N2096L.
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old September 22nd 04, 04:05 PM
Marco Leon
Michelle is correct, it could be anything. Probably a loose wire though. I
had the panel lights go out on me (on the ground) and I felt around behind
the dimmer pot via under the panel for obvioulsy loose wires. I was able to
find it and my A&P fixed the problem accordingly. YMMV, it could be
something entirely different.
Marco
"Michelle P" wrote in message
ink.net...
Michelle
should
is
Nav
it
the group.
N2096L.
Old September 22nd 04, 03:23 PM
Aaron Coolidge
Piperflyer wrote:
: After the hurricane, I found the panel lights on the left side which should
: go on with the Nav lights, are out. Nav lights do come on. Circuit braker is
: in.What could be the problem? Someone might know the answer outright.
: Couldn't be the bulb since all of them don't light up (unless they're
: connected in series). Probably not the switch either since the wingtip Nav
: lights come on. Should it be checked by a mechanic or Avionics shop or if it
: is something trivial, maybe I can do it myself. Appreciate any input from
: the group.
: N2096L.
Dunno about the Warrior, but on my Cherokee there are 2 dimmers, one for the
overhead light and one for the panel lights. The overhead light dimmer
turns on the NAV lights.
The panel lights draw something like 3 amps. All this current goes through
a little-bitty switch on the dimmer potentiometer. This switch was made
to turn a transistor radio on and off. It burned out on my plane. The
panel lights didn't come on. The fix was to get a new potentiometer/switch
(for $170) and have it installed.
As Michelle P. pointed out, there's a dual transistor dimmer as well. I
have found this to be pretty reliable but others have reported many
problems with it. Lookign through the Google archive should be illuminating
as well.
Aaron Coolidge (N9376J)
Old September 22nd 04, 03:56 PM
Dave Butler
Aaron Coolidge wrote:
...should be illuminating...
Old September 22nd 04, 11:38 PM
tom418
There is a pot, transistor, and possibly, (depending on yr of mfg) a
resistor in the transistor base circuit.
BTW, check to see if the resistor (if any) has been updated . The M/M for
my Seneca says that Piper offered field replacements as an improvement.
"Piperflyer" wrote in message
should
is
it
the group.
N2096L.
Old September 23rd 04, 07:26 AM
Chuck
On Wed, 22 Sep 2004 04:56:34 -0400, "Piperflyer"
the group.
N2096L.
I had a similar problem a few months ago in my Cherokee. Turned out
to be a simple corrosion problem on the dimmer control.
My Cherokee has a three-position switch on the dash with HIGH/OFF/LOW
positions. Either LOW or HIGH turns on the Nav lights, but there is a
difference in how high the dash lights come on. Then, there is an
adjustable dimmer control under the dash.
We cranked that dimmer control all the way back and forth a couple
times - and it was fixed. (That cleaned the corrosion off the
contacts in the dimmer switch).
Hope that helps - good luck.
Chuck
Panel Lights - Need Help Barnyard BOb - Home Built 2 May 29th 04 07:51 PM
Anti collision light mod for Piper Arrow 1968 model? Frode Berg Owning 4 May 20th 04 05:16 AM
Panel Lights Dimmer MII Driver Home Built 3 April 3rd 04 01:56 AM
Building chasing airport lights -- Attn: Jim Weir? Jay Honeck Owning 79 February 29th 04 02:10 PM
replacing plastic panel overlay w/aluminum Dave Owning 7 January 10th 04 10:52 PM
