Word was just getting around about a year ago that it is possible to run
some carbureted engines lean of peak. It was discovered that using carb heat would improve the mixture distribution. I had a lot of time early in the year to look into this because our O320 H2AD was apart due to premature lifter failure. From what I could learn in this and other discussion groups, most engines like this would not run LOP or even close to peak without shaking. Once I was finished with the full rich break in operation of our rebuilt engine, I tried LOP operation and was surprised how well it worked. Carb heat helped slightly with the predictability of the onset of roughness and how lean the engine could be run with acceptable smoothness. Even with carb heat off however, the engine could be leaned until RPM dropped dramatically and it began to stumble and quit but the roughness would still be something you heard with your ears rather than felt in the airframe. I could understand how there was a lot of variation in mixture distribution among engine models and perhaps even individual engines but it was hard to reconcile the smoothness of ours with what I was hearing from other owners. Early in the spring, Walter Atkinson of Advanced Pilot Seminars, posted somewhere that any engine that was conforming and without induction leaks, ought to be able to run at the optimum (for a simple engine) 25 degree LOP spot. About a dozen pilots fly our plane and perhaps a quarter of them fly it the way I do now. About 180 hours since rebuild, the engine intermittently has stopped showing RPM rise when leaned for ground operations. Other indications support that this is almost certainly a minor induction leak. I finally caught it in a bad mood and was able to take it up to try it out in cruise. At 4500 feet, full rich EGT is 50 - 75 degrees hotter so it does look as if it is leaner. It starts to sound rough well before reaching peak. By peak it is objectionably rough and, anywhere past peak, you can feel the vibrations in the seat and see the glareshield dance. It was this rough before, even leaned for 200 RPM drop and stumbling. I then turned the mixture back to about 150 degrees ROP. The engine was perfectly smooth. This is the way I used to fly it and the way I know many pilots fly these planes. If I didn't look for or ignored the lack of RPM rise in ground leaning, I could fly it this way for months or years without suspecting there was a problem. From this experience, I conclude that many or most engines out there actually have minor induction leaks. This might also be part of the reluctance of manufactures and shops to recommend LOP operation. LOP any minor air leakage in the numerous hoses and joints of the induction system will be a "problem" and something wrong with the engine. ROP, minor leaks are not an issue and do not reflect on either the builder or the repair shop. I want my engine to run right and I now add to the list of LOP advantages the fact that any problems with the engine will become apparent early. This is especially important to those of us who must fly without and engine analyzer. -- Roger Long |
Oops. Sixth paragraph, last line is supposed to read: It was *never* this rough before, even leaned for 200 RPM drop and stumbling. -- Roger Long |
Get those sparkplugs checked by someone with a plug tester and an ear
for the job. We have had considerable roughness caused by bad plugs recently. We used to use nothing but Auburn plugs until Champion bought them up and shut them down, and had to use Champs even though they fail internally after only a couple hundred hours. When Unison brought out the Autolite plugs, which are based on the old Auburn design, we got good service until lately when we've been finding the plugs' internal resistance going up and causing arcing in the connector barrel. You have to know what to listen for when testing them. The spark in the cylinder gets weak and much more sensitive to mixture inconsistencies and changes. When is someone going to bring out a reliable aircraft engine plug? Dan |
"Roger Long" wrote
Early in the spring, Walter Atkinson of Advanced Pilot Seminars, posted somewhere that any engine that was conforming and without induction leaks, ought to be able to run at the optimum (for a simple engine) 25 degree LOP spot. That's way too broad. Some engines simply have poor fuel/air distribution, and will never run LOP until this is fixed. That's how GAMI makes money - bandaiding poorly designed engines so that they are somewhat less poorly designed. That's not a slam on GAMI, BTW - they do as much as the FAA will let them do. However, the small 4-cylinder Lycomings have very good fuel/air distribution, and run LOP just fine stock - assuming, of course, there are not other problems such as bad plugs, intake leaks, clogged injectors, injector line leaks, etc. I run my IO-320's LOP routinely. I've had the plane well over 700 hours, the engines have 1500 hours and 14 years on them, and I have changed one jug. In fact, the compressions were all over the place when I bought the plane, and operating this way brought them up to 78 or better on ALL cylinders and kept them that way until long past the 1000 hour mark. And every time I failed to get smooth operation well LOP, it was an indication of a problem that I was able to catch early. I had always assumed that fuel injection was a must for this, but upon reflection this is just stupid. As long as the carb does a good job of atomizing/vaporizing the fuel, it should not matter. That would explain why carb heat makes a difference, though - hotter air means more complete vaporization. So basically, I agree with your premise - just understand that it won't work for EVERY make and model engine/induction system combination. Clearly works for yours, though. Michael |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| Rotax 582 engine problems | L. Darte | Home Built | 6 | May 9th 04 02:49 AM |
| My Engine Fire!! | [email protected] | Owning | 1 | March 31st 04 02:41 PM |
| Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 04:03 PM |
| Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 05:29 AM |
