Wax
Old September 27th 04, 06:14 PM
zatatime
Default Wax
What type of wax do you use on your airplane? I'd like to stay away
from the standard "carnuba" type waxes because its a royal pain to
buff around all the rivets (its a Cherokee). Any one step polishes
out there that don't require the second buffing step?
This plane has not been waxed in at least 6 yesrs so I doubt there's
any build up of old wax to worry about.
Thanks,
z
Old September 28th 04, 05:14 AM
tony roberts
I use Eagle Wax.
It comes in a spray bottle.
You wet the plane,
Spray Eagle Wax on while the plane is still damp,
Wipe the plane with a cloth.
Finished.
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old September 28th 04, 06:26 AM
kage
If you don't have much time and you just want to make a plane look good
FAST!
Hose it down
Use liquid "Turtle Wax"
Rub it all over the WET airplane, rub right over the oil and exhaust stains
with lots of wax.
Hose it off with water, the still wet wax and all
Use leaf blower to dry most of the remainder
Dry leftover small spots with towel.
Karl
"Curator" N185KG
This might not be the longest lasting wax job, but it makes the airplane
clean and shiny FAST!
"tony roberts" wrote in message
news:nospam-D283F1.21145827092004@shawnews...
I use Eagle Wax.
You wet the plane,
Finished.
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old September 28th 04, 04:22 PM
zatatime
On Mon, 27 Sep 2004 22:26:07 -0700, "kage"
FAST!
Hose it down
with lots of wax.
Interesting. Sounds like it would leave a pretty big wax build up
area on what you're trying to mask though. I may give it a try on
part of the cowling that got discolored from a blown exhaust gasket.
Thanks.
z
Old September 28th 04, 04:18 PM
zatatime
On Tue, 28 Sep 2004 04:14:24 GMT, tony roberts
I use Eagle Wax.
You wet the plane,
Finished.
Tony
Sweet. How long do you go between waxings?
Thanks for the reply.
z
Old September 29th 04, 06:42 AM
tony roberts
Once Spring & once Fall.
z
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Old September 28th 04, 08:49 PM
TripFarmer
I regularly use a spray on wet, wipe off wax. It looks great and
only takes 10-15 minutes to do all the upper and side surfaces.
Eagle One is the brand I use.
Trip
In article , says...
Thanks,
z
Old September 29th 04, 02:01 AM
Javier Henderson
zatatime writes:
Wash Wax All is all I've been evangelizing for a while now.
-jav
Old September 29th 04, 04:20 AM
zatatime
On 28 Sep 2004 18:01:40 -0700, Javier Henderson
Choices, choices....Thanks I'll check it out. My only concern is that
I'm starting from scratch, and this may not give the "base protection"
I'm looking for. I'll see what the factory says.
z
