t-hangar and ice
Old October 13th 04, 10:59 PM
Bob Noel
Default t-hangar and ice
In preparation for winter, I have a question.
the situation: T-hangar with bi-fold doors. Run-off from the roof
collects in front of the hangar door (because the tarmac doesn't
slope away from the hangar - in fact there is a slight dip in
front of the hangar). In the winter, water collects and then
freezes. Eventually the water penetrates under the door and
freezes inside the hangar. The result is a patch of ice about
4 to 6 feet wide, about half inside and half outside the door.
(imagine walking into a dark hangar and having black ice just
inside the door - weeeeee!!! splat!)
The best that Massport has come up with to date is to leave
the door slightly up so that the door won't freeze to the ground.
This does nothing with respect to being able to push/pull the
airplane in/out of the hangar.
Are there any suggestions on how to deal with ice in front
of the door?
Bob Noel
Seen on Kerry's campaign airplane: "the real deal"
oh yeah baby.
Old October 13th 04, 11:09 PM
Dave Stadt
"Bob Noel" wrote in message
of the door?
Bob Noel
oh yeah baby.
Buy an east facing hangar. In IL we have the same problem. Only known cure
is an east facing door. The morning and early afternoon sun keeps them free
of ice while west facing have a constant battle to get rid of the ridge of
ice. I would guess north facing would have the same problem. South facing
should be fine also.
Old October 14th 04, 01:32 AM
Bob Noel
In article , "Dave
of the door?
Buy an east facing hangar. [snip]
unfortunately, it is an east facing hangar. Well, it's more
like northeast. :-(
Bob Noel
oh yeah baby.
Old October 13th 04, 11:13 PM
Ben Jackson
of the door?
You could get a rubber matt with relatively open grid/hex pattern that's
thicker than the expected ice accumulation so that even if 1/2" of ice
builds up there is some bit of rubber sticking through.
Ben Jackson
http://www.ben.com/
Old October 14th 04, 02:18 AM
john smith
Get a couple bags of pea gravel and sand, spread it in the low spot to
deflect the water away from the hangar.
of the door?
Old October 14th 04, 05:24 AM
Jay Honeck
Under NO circumstances should you spread pea gravel or sand in front of your
hangar door.
Our hangar neighbor did that last year, and that damned stuff ended up all
over our tarmac. Can you say "sandblasted"?
You can get the same result with a few bags of asphalt patch, which is more
durable and won't blow away.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 14th 04, 06:43 AM
BTIZ
more durable and won't blow away.
I don't think MASSPORT would appreciate him modifying the local tarmac.
Maybe some kitty litter for the inside.. and sweep it up as soon as the ice
is gone.. save it for re-use. Put nothing down outside you would not want
another aircraft to blow into your airplane.
JM2C
BT
Old October 16th 04, 04:07 PM
john smith
If you get crushed limestone, water and pressure (roll it) will cause it
to compact into a solid mass.
hangar door.
Old October 14th 04, 07:04 AM
Roger
On Wed, 13 Oct 2004 21:59:28 GMT, Bob Noel
When I had the Deb in a hanger like that I picked up a couple pieces
of carpet. When needed I'd throw them down in front of the plane, or
where ever they were needed. They even gave my little tug good
traction.
www.rogerhalstead.com
of the door?
