Do you log airborne time, or aircraft moving time?
Old October 15th 04, 11:15 PM
Ron Rosenfeld
Default Do you log airborne time, or aircraft moving time?
On Fri, 15 Oct 2004 22:15:53 +0100, Peter wrote:
I am referring to airframe/engine/propeller logs, not pilot's logbook.
In the US, those times are tach times (times when the engine is running).
It is generally NOT logged at all by pilots (nor is there any requirement
for the pilot to log those times).
Old October 15th 04, 11:41 PM
Fly
U.S. FAR's cite that pilot can log all time in operation of airplane.
Time for maintenance purposes is for purposes of flight and means that time
the wheels are not on the ground.
Some operators have a hobbs meter activated by sqwat switch.
Kent Felkins
Tulsa Oklahoma
"Peter" wrote in message
FAR says one should log the time the aircraft is in motion. However I
understand some people log airborne time only.
Any views?
Here in the UK, under G-reg, we can log airborne time for all
maintenance purposes, and brakes-off to brakes-on in the pilot's
logbook.
Peter.
Return address is invalid to help stop junk mail.
E-mail replies to but remove the X and the Y.
Please do NOT copy usenet posts to email - it is NOT necessary.
Old October 16th 04, 01:59 AM
David Megginson
Any views?
logbook.
That's the same as Canada. Our aircraft journey log has columns for both
flight time (from when the plane starts moving to when it stops) and air
time (wheels up to wheels down). Flight time goes into the pilot's logbook,
and air time goes into the maintenance log.
All the best,
David
Old October 16th 04, 03:12 AM
Bob Noel
In article , Peter
I use tach time.
Bob Noel
Seen on Kerry's campaign airplane: "the real deal"
oh yeah baby.
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
