Off Topic - Spruce Goose
Old January 5th 04, 12:59 PM
Steve Beaver
Default Off Topic - Spruce Goose
We have all seen the film of the Spruce Goose lifting off the water for a
few seconds only to be retired to its hangar never to fly again but I
wonder, what would its performance have been? Did Hughes determine in that
brief hop that the aircraft was no good or did ecconomic concerns ground it?
There are all kinds of aircraft performance analysis programs available now.
Has anyone ever plugged in the Goose specifications and determined how it
would fly?
Old January 5th 04, 04:49 PM
VideoFlyer
Good question! I've often wondered about that myself.
Old January 5th 04, 05:10 PM
Richard Isakson
"Steve Beaver" wrote ...
it?
I believe he discovered the airplane didn't have enough power to fly out of
ground effect even at empty weight. Others say that he had to fly one time
to collect the money from the contract. In either case, it's been shown
that it wouldn't have flown with a full load.
Rich
Old January 5th 04, 05:31 PM
Bill Daniels
"Richard Isakson" wrote in message
a
that
it?
of
time
Rich
The prototype Hercules used 8 Pratt and Whitney R-4360 of 3500 HP each - the
wrong engines. The 5000 - 7000 HP Lycoming XR7755, then under development,
was the intended engine. The Convair B-36 and the Northrop B-35 were also
supposed to use the R7755. See:
http://www.aviation-history.com/engines/xr-7755.html
With a total of 56,000 HP instead of "just" 28,000 the "Spruce Goose" would
have been a outstanding success - don't blame the failure on the airframe.
It's interesting to speculate how these huge aircraft would have performed
with the enormous Liquid cooled Lycoming.
Bill Daniels
Old January 5th 04, 05:52 PM
Rich S.
"Bill Daniels" wrote in message
link.net...
development,
would
Are plans available?
Rich "Sharpening my chisel" S.
Old January 5th 04, 06:20 PM
Frank Stutzman
Well, maybe.
According to the website you referanced the R7755 burned 580 gallons per
hour at 5,000 HP. For the Goose that would mean 8*580= 4,640 gallons an
hour or 27,840 pounds an hour. Nothing like burning 13 TONS of fuel an
hour!
However, according to http://www.sprucegoose.org/Specification.htm, the
Goose had a payload of 65 tons (130,000 pounds). It also says that the
cruise speed was supposed to be 175 mph. Lets we were going to fly it
from San Francisco to Honolulu (which seems to me to be a reasonable
mission). We've got a fair tail wind and we are going to get 200 mph
groundspeed. We are going to throttle back to 6 tons an hour. Thats a
2400 mile flight that will take 12 hours and burn 72 tons of fuel. Looks
to me like we were going to need fuel about a hour before we got to
Hawaii.
Now maybe the "payload" number on the sprucegoose website is after full
fuel. Maybe the R7755 were lighter than the R4360. It certainly seems to
me that it was doubtful that the goose could have had met its intended
use.
Indeed.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Old January 5th 04, 08:58 PM
L.D.
Well, maybe.
hour!
Hawaii.
use.
Indeed.
I don't know if it is true or just hanger talk but I've always heard
that aeronautical engineers say it is impossible for a bumble bee to
fly. However we all know they do it well. I would like for someone to
plug in aircraft performance analysis programs a bubble bees
specifications and see if it is possible for him to fly. OH well it
probably won't work because a bumble bee isn't an aircraft, or is he?
Old January 6th 04, 01:47 PM
Corky Scott
On Mon, 05 Jan 2004 14:58:46 -0600, "L.D."
Your information is mistaken. This is a very old story and was
corrected almost immediately.
Here's what constitutes the usual explanation: "It apparently first
surfaced in Germany in the 1930s, and the story was about a prominent
Swiss aerodynamicist. One evening, the researcher happened to be
talking to a biologist at dinner, who asked about the flight of bees.
To answer the biologist's query, the Swiss engineer did a quick
"back-of-the-napkin" calculation.
To keep things simple, he assumed a rigid, smooth wing, estimated the
bee's weight and wing area, and calculated the lift generated by the
wing. Not surprisingly, there was insufficient lift. But that was
about all he could do at a dinner party. The detailed calculations had
to wait.
To the biologist, however, the aerodynamicist's initial failure was
sufficient evidence of the superiority of nature to mere engineering.
The story spread, told from the biologist's point of view, and it
wasn't long before it started to appear in magazine and newspaper
articles."
The further explanation is that once the aerodynamicist got back to
his lab he researched further and examined a bumblebee under a
microscope and realised his initial calculations were way off. He
corrected his error but of course the correction did not get the print
that the original statement got, and folks have been scoffing at
scientists ever since.
Corky Scott
Old January 6th 04, 01:12 AM
Bill Daniels
"Frank Stutzman" wrote in message
development,
also
would
airframe.
Well, maybe.
hour!
Hawaii.
use.
performed
Indeed.
Frank Stutzman
Hood River, OR
I suspect the 580 GPH is a gross error. Assuming a Specific Fuel
Consumption of 0.42 Lbs./HP/Hr., The R7755 would have "only" used 2100
pounds per hour at 5000 HP output. Assuming 70% power at cruise the fuel
consumption drops to 1470 PPH.
If the engine had been developed to put out 7000 HP and the SFC came in at
0.40, the 70% cruise fuel burn would have been 1,960 PPH. All eight
engines would burn 15,680 PPH or "only" 7.84 Tons per hour.
Given the liquid cooling, variable cam timing and gear box the SFC might
have been even lower.
Bill Daniels
Old January 17th 04, 04:54 PM
Corrie
First I've heard that the B-36 was originally designed to use the Lyc.
AFAIK it was always intended to use the Pratt 4360. The B-36 could
carry 84,000 lbs of weapons, on top of fuel and crew.
"Featherweighted" versions could exceed 48,000 ft (and outfly fighters
with heavier wing-loading), come close to 400 MPH over the target, and
flew missions of over 24 hrs (no inflight refueling). Not all at the
same time, of course. Range or payload, pick one.
"Bill Daniels" wrote in message hlink.net...
a
that
it?
of
time
Rich
Bill Daniels
Doug Fir vs: Sitka Spruce Lou Parker Home Built 40 November 10th 03 05:36 PM
Off topic, but Hiarous! Morgans Home Built 1 November 2nd 03 04:24 AM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 04:35 PM
Wood questions - Public Lumber Company, determining species at the lumberyard Corrie Home Built 17 September 17th 03 06:51 PM
Glass Goose Dr Bach Home Built 1 August 3rd 03 05:51 AM
