The pitot heat has failed on our Aztec. No heat, not even warm, no amperage
draw. Circuit breaker, switch, leads, and ground all check ok. Now here's the strange part. We get correct voltage across the leads and we get continuity across the terminals on the tube. No continuity from the terminals to the tube itself, so I don't think the element is shorted out against the tube. If there is continuity across the terminals, one would think that the element is intact. If it's getting adequate voltage, why isn't it heating? The only explanation I can come up with is that the leads are shorted out inside the tube before they get to the element. However, it doesn't pop the circuit breaker. Any other ideas?? Can these old style tubes be repaired? Ours is similar to an AN5812-12 but we have rubber hoses connected to the airspeed and pitot lines rather than 1/4" fittings. The AN5812's seem to run about $1000! Thanks Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.782 / Virus Database: 528 - Release Date: 10/22/2004 |
Jim Burns wrote:
The pitot heat has failed on our Aztec. No heat, not even warm, no amperage draw. Circuit breaker, switch, leads, and ground all check ok. Now here's the strange part. We get correct voltage across the leads and we get continuity across the terminals on the tube. No continuity from the terminals to the tube itself, so I don't think the element is shorted out against the tube. Is this measured with the leads connected to the pitot tube terminals? You have continuity across the terminals, but what is the element resistance? If there is continuity across the terminals, one would think that the element is intact. If it's getting adequate voltage, why isn't it heating? I don't know, but one possibility is that you have internal corrosion that has greatly increased the resistance of the element such that there isn't sufficient current flowing to heat up the element. Matt |
Jim Burns wrote:
: The pitot heat has failed on our Aztec. No heat, not even warm, no amperage : draw. Circuit breaker, switch, leads, and ground all check ok. : Now here's the strange part. We get correct voltage across the leads and we : get continuity across the terminals on the tube. No continuity from the : terminals to the tube itself, so I don't think the element is shorted out : against the tube. If the Aztec is 12V, the resistance of the heater in the pitot tube should be between 0.75 and 1.2 Ohms. If it's greater than that the heater has failed internally. (24V systems would be about twice that resistance, of course.) The leads of most multimeters have 1 to 2 Ohms resistance, so checking a low resistance is troublesome. I'd jumper the pitot tube heater to a 12V battery and see if it sparks when connected or disconnected. -- Aaron Coolidge |
My fluke 189 is that sensitive! You need quality tools or a mechanic with
quality tools. "Aaron Coolidge" wrote in message ... Jim Burns wrote: : The pitot heat has failed on our Aztec. No heat, not even warm, no amperage : draw. Circuit breaker, switch, leads, and ground all check ok. : Now here's the strange part. We get correct voltage across the leads and we : get continuity across the terminals on the tube. No continuity from the : terminals to the tube itself, so I don't think the element is shorted out : against the tube. If the Aztec is 12V, the resistance of the heater in the pitot tube should be between 0.75 and 1.2 Ohms. If it's greater than that the heater has failed internally. (24V systems would be about twice that resistance, of course.) The leads of most multimeters have 1 to 2 Ohms resistance, so checking a low resistance is troublesome. I'd jumper the pitot tube heater to a 12V battery and see if it sparks when connected or disconnected. -- Aaron Coolidge |
NW_PILOT wrote:
: My fluke 189 is that sensitive! You need quality tools or a mechanic with : quality tools. Not just the sensitivity, though. To truly measure a low impedance path you need a 4-wire meter. I traced the mOhms in a prototype PCB to locate the bridge with a 4-wire meter. -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
draw. Circuit breaker, switch, leads, and ground all check ok. Now here's the strange part. We get correct voltage across the leads and we get continuity across the terminals on the tube. No continuity from the terminals to the tube itself, so I don't think the element is shorted out against the tube. If there is continuity across the terminals, one would think that the element is intact. If it's getting adequate voltage, why isn't it heating? The only explanation I can come up with is that the leads are shorted out inside the tube before they get to the element. However, it doesn't pop the circuit breaker. Any other ideas?? Can these old style tubes be repaired? Ours is similar to an AN5812-12 but we have rubber hoses connected to the airspeed and pitot lines rather than 1/4" fittings. The AN5812's seem to run about $1000! Thanks Jim It sounds as though you have corrosion or some other resistance in the circuit. I would check for a voltage drop across the circuit breaker and switch while the circuit is under load. |
![]() It sounds as though you have corrosion or some other resistance in the circuit. I would check for a voltage drop across the circuit breaker and switch while the circuit is under load. Bingo. voltage drops to about 0 played with it enough that the circuit breaker started popping corroded terminal on the switch/lead to the circuit breaker hooked a battery direct to the pitot heat terms and it works fine will try a new switch & lead tomorrow thanks all! Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.782 / Virus Database: 528 - Release Date: 10/22/2004 |
"Jim Burns" wrote in message ...
It sounds as though you have corrosion or some other resistance in the circuit. I would check for a voltage drop across the circuit breaker and switch while the circuit is under load. Bingo. voltage drops to about 0 played with it enough that the circuit breaker started popping corroded terminal on the switch/lead to the circuit breaker hooked a battery direct to the pitot heat terms and it works fine will try a new switch & lead tomorrow thanks all! Jim Bad breakers cost some folks a lot of money. We once replaced a $600 strobe power supply because we got battery voltage at the strobe power plug, but that was with the plug disconnected from the strobe. The relatively high resistance of a bad breaker won't drop voltage detectably with only a voltmeter drawing on it. Learned the hard way that voltage drop measurements across suspect components are much more informative. Dan --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.782 / Virus Database: 528 - Release Date: 10/22/2004 |
It was actually the switch. The switch was shorted out internally and one
terminal was shorted to the exterior case of the switch and ultimately to the panel. Jim "Dan Thomas" wrote in message om... "Jim Burns" wrote in message ... It sounds as though you have corrosion or some other resistance in the circuit. I would check for a voltage drop across the circuit breaker and switch while the circuit is under load. Bingo. voltage drops to about 0 played with it enough that the circuit breaker started popping corroded terminal on the switch/lead to the circuit breaker hooked a battery direct to the pitot heat terms and it works fine will try a new switch & lead tomorrow thanks all! Jim Bad breakers cost some folks a lot of money. We once replaced a $600 strobe power supply because we got battery voltage at the strobe power plug, but that was with the plug disconnected from the strobe. The relatively high resistance of a bad breaker won't drop voltage detectably with only a voltmeter drawing on it. Learned the hard way that voltage drop measurements across suspect components are much more informative. Dan --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.782 / Virus Database: 528 - Release Date: 10/22/2004 --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.782 / Virus Database: 528 - Release Date: 10/23/2004 |
![]() Jim Burns wrote: It was actually the switch. The switch was shorted out internally and one terminal was shorted to the exterior case of the switch and ultimately to the panel. If that's the case, then the breaker's bad, too. A direct short like that should've tripped it immediately. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
Pitot tube question | Doc Font | Home Built | 2 | January 24th 05 04:28 AM |
Pitot tube prices | B2431 | Home Built | 2 | May 16th 04 08:13 PM |
pitot tube down | Emilio | Military Aviation | 16 | March 6th 04 11:37 PM |
Chuck Yeager-pitot tube | Ron | Military Aviation | 44 | October 9th 03 03:13 AM |
"I'll spend as much of YOUR money as I want!" - Bu$h's Sunday Presidential Address | B2431 | Military Aviation | 91 | September 14th 03 10:05 PM |
